[Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
Postby Aerilius » Sun May 27, 2012 3:05 am
This Plugin allows to draw physically accurate wires and ropes (catenary curves) between two points with only two clicks.
ae_WireTool_1_4_1.rbz
Version: 1.4.1
Date: 06.03.2013
Usage:
(Menu) Plugins → Draw Wires
  • Type a number + s to change the number of curve segments:
    24s
  • Type a number + % to set an arc length (relative to the distance between source and target point):
    120%
  • Type a length to set a fixed arc length:
    72.5m
    30.66"
History:
version 1.4.1: 06.03.2013
- added Spanish translation
- fixed non-convergent numerical approximation for curve lengths near 100% of distance
version 1.4.0: 01.03.2013
- converted into a SketchUp Extension
- image and cursor added
version 1.3: 03.06.2012
- fixed wrong segment length (only noticeable with big sag like 200%)
- changed segments to have equal angles (visually best result, but not all segments have the same length)
- added optional parameter @@segment_distribution_mode in the script to toggle back to equal length segments (edit the ruby file)
version 1.2: 30.05.2012
- now all segments have equal arc length (no more equal x length)
- error with translation in activate didn't properly activate the tool
- @state=0 fixed
version 1.1: 27.05.2012
- translations
- better precision (changed threshold for numerical calculations)
version 1.0: 27.05.2012
Aerilius
PluginStore Author
PluginStore Author
Re: [Plugin] WireTool (Catenary)
Postby Krisidious » Sun May 27, 2012 5:00 am
sweet thanks.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Bob James » Sun May 27, 2012 8:21 am
I can really use this! Thank you. :thumb:
-1
Bob James
Premium Member
Premium Member
Postby thomthom » Sun May 27, 2012 12:18 pm
Aerilius wrote:Type a length to set a fixed arc length:
!!! I tried on this a couple of years ago! Never worked out how to do a fixed length curve. I need to snoop around in your code. I wanted to make a tool that would anchor the end point to other geometry so when you moved of the the object it was attached it the curve would update.
4
PluginStore Author
PluginStore Author
Postby iichiversii » Sun May 27, 2012 12:24 pm
Now this is a great plugin, thanks :thumb:
Bring on the Rain...
iichiversii
Premium Member
Premium Member
Postby gullfo » Sun May 27, 2012 2:39 pm
very cool! this is one of the more useful shapes in acoustics!
gullfo
Postby thomthom » Sun May 27, 2012 3:03 pm
gullfo wrote:very cool! this is one of the more useful shapes in acoustics!
That I wasn't aware of. Guess I need to read up on it again.
PluginStore Author
PluginStore Author
Postby mitcorb » Sun May 27, 2012 3:54 pm
Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
mitcorb
Top SketchUcator
Postby iichiversii » Sun May 27, 2012 7:06 pm
mitcorb wrote:Another good tool concept. By the way, Remus Knowles has another version in the Plugins Index.
Any idea what his version is called?
iichiversii
Premium Member
Premium Member
Postby Aerilius » Sun May 27, 2012 7:22 pm
Remus' plugin is the Simple Catenary Curve. It "just" calculates the curve for a given set of 17 points but it put me on the right path to look on Wikipedia after I had a paper full of integrals that didn't want get further simplified.
Aerilius
PluginStore Author
PluginStore Author
Postby urgen » Sun May 27, 2012 8:35 pm
HA!...cool idea.thanks Aerilius :thumb:
--pupil forever...------
urgen
Postby nektares » Tue May 29, 2012 5:35 am
I always did this with splines, this is a much better and precise way to do it, Thank you!
nektares
Postby sdmitch » Tue May 29, 2012 3:38 pm
When I tried the plugin, I kept getting a canatnary drawn from the origin to my first pick point. Adding a @state = 0 to the def initialize method fixed this problem.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby Aerilius » Tue May 29, 2012 4:37 pm
Hi Sam,
thanks for the tip. I wonder why this happens, although the initialize method does not have @state=0, this should be set when the activate method calls reset.
Is someone else having this problem?
Aerilius
PluginStore Author
PluginStore Author
Postby massimo » Tue May 29, 2012 5:13 pm
Yes the same here. Thanks for the plugin btw. :thumb:
massimo
Postby thomthom » Tue May 29, 2012 5:30 pm
create_geometry and draw_geometry can be refactored into one method that returns an array of point3d objects - the only difference between these methods are the final statement. DRY
PluginStore Author
PluginStore Author
Postby Dave R » Tue May 29, 2012 6:00 pm
I didn't experience the same thing that Sam reported.
Global Moderator
Postby gullfo » Tue May 29, 2012 10:42 pm
i added the @state=0 and it made a difference in terms of being able to select the first point. very nice tool!
gullfo
Postby Dave R » Tue May 29, 2012 10:57 pm
So why don't I have this same problem? I didn't modify the script and it works fine for me.
Global Moderator
Postby wind-borne » Tue May 29, 2012 11:13 pm
Dave R wrote:So why don't I have this same problem? I didn't modify the script and it works fine for me.
Which version are you using?
initial version works fine for me, updated version moves to origin.
"To read between the lines was easier than to follow the text."OSX 10.11.6 _ _ _ _ _ SU 8 pro
wind-borne
Premium Member
Premium Member
Postby Dave R » Tue May 29, 2012 11:19 pm
That would explain it. I didn't catch that there was an update because the thread title wasn't edited to show that as is SOP here.
Global Moderator
Postby Dave R » Wed May 30, 2012 12:15 am
So now I've updated the plugin and added the line as mentioned. I get some rather strange behavior now. See the video.
Global Moderator
Postby TIG » Wed May 30, 2012 12:33 am
I have the original version [that works] if anyone wants it... :?
Global Moderator
Postby Dave R » Wed May 30, 2012 12:34 am
I guess I'd be interested.
Global Moderator
Postby raineysky » Wed May 30, 2012 12:44 am
I would very much like to have it if it makes rope. I tried it but got results like Dave shows in the video.
raineysky
Re: [Plugin] WireTool (Catenary) — updated 30.05.2012
Postby Aerilius » Wed May 30, 2012 8:42 am
Tools normally don't have weird behavior without reason. Running it with the Ruby console open gives often more definable results.
So I found and fixed an unobvious bug with the translations that stirred up all methods and I changed that the x-width of segments is variable to give always the same segment length.
Aerilius
PluginStore Author
PluginStore Author
Postby Dave R » Wed May 30, 2012 10:22 am
That apparently fixed it. Thank you.
Global Moderator
Postby McGyver » Thu May 31, 2012 4:30 pm
This is very cool! Thank you!
Edited to add- This is REALLY cool! I was just messing around with it and it works great for something I was making. THANKS!
McGyver
Postby Michaelv » Sat Jun 02, 2012 7:25 pm
Great Thanks.
There was another catenary tool (and other geometric curves too) here:
viewtopic.php?t=41310
I needed to make them like this though.
See below however, the first segment is much longer and they become smaller as they go on the curve:
Michaelv
Re: [Plugin] WireTool (Catenary) — updated 03.06.2012
Postby Aerilius » Sun Jun 03, 2012 10:36 pm
@Michaelv: Thanks for noticing this! It was not much visible with little sagging (110%) but with big sagging. Sorry that it took some time (it's not easy to do math with curve lengths).
I fixed it now.
I also thought about the problem and find that the corners/endpoints a even less noticeable when I use equal angles between the segments. If you prefer equal segment lengths, you can change the parameter @@segments_distribution_mode to 1 inside the script.
Aerilius
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: FacundoMarro, Laredo and 13 guests
