[Plugin] Colour N-Gons v1.0 (17/4/12)
Postby Rich O Brien » Tue Apr 17, 2012 3:48 pm
Colour N-Gons
Description:
Paints N-Gons in a selection
Usage:
Run 'Colour N-Gon' from the 'Plugin' menu.
Versions:
1.0 17/4/2012 - First Release
Color_N_Gon.rb
Rich O Brien
Administrator
Re: [REQ] Colour Quad Faces only
Postby thomthom » Tue Apr 17, 2012 3:56 pm
Rich O'Brien wrote:Is it possible to colour only quad faces via ruby?
Yes - but you do mean native quads - or the non-planar ones that works with QuadFace Tools etc?
PluginStore Author
PluginStore Author
Postby thomthom » Tue Apr 17, 2012 3:58 pm
Off-Topic:
You're such a tease! :lol:
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Apr 17, 2012 4:04 pm
Just boring old quads.
Off-Topic:
What are you talking about? I'm using v9 on my iPad every day. Did you not see my post in the corner bar?
Rich O Brien
Administrator
Postby thomthom » Tue Apr 17, 2012 4:12 pm
Code: Select all
for face in Sketchup.active_model.selection
  next unless face
.is_a?( Sketchup::Face )
face.material 'red' if face.edges.length == 4
PluginStore Author
PluginStore Author
Postby thomthom » Tue Apr 17, 2012 4:13 pm
Off-Topic:
Nice Windows UI your iPad has...
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Apr 17, 2012 4:16 pm
Thanks for the code. :thumb:
Off-Topic:
Have you seen Windows 8 on the iPad with touch recognition?
Pretty cool
Rich O Brien
Administrator
Postby Rich O Brien » Tue Apr 17, 2012 4:51 pm
How do I enter this in the console? I tried but I'm getting errors....
Code: Select all
(eval):438
Error: #<SyntaxError: (eval):438: compile error
(eval):438: syntax error, unexpected $end, expecting kDO_COND or ':' or '\n' or ';'
Rich O Brien
Administrator
Postby thomthom » Tue Apr 17, 2012 4:54 pm
Ah, it was just general code.
Here is a one-liner:
Sketchup.active_model.selection.each{|e|e.material='red' if e.is_a?(Sketchup::Face) && e.edges.length==4}
PluginStore Author
PluginStore Author
Postby Khai » Tue Apr 17, 2012 6:44 pm
ohh I can really use this :)
I wish I knew how to give it a UI - so you could select edge count (3,4,5,etc) and colour...
:mrgreen: :mrgreen: :mrgreen: :mrgreen:
Khai
Postby Rich O Brien » Tue Apr 17, 2012 7:45 pm
You're reading my mind Khai. This is beyond my ability but I'll have a stab at it. :?
Rich O Brien
Administrator
Postby TIG » Tue Apr 17, 2012 8:02 pm
Easy-peasy... see the part that says e.edges.length==4
Just change it to any value between 3 and 1000000+
e.edges.length==3 for triangulated faces
e.edges.length==6 for hexagonal faces
etc...
Global Moderator
Postby Khai » Tue Apr 17, 2012 8:23 pm
I get that Tig.. it's having the code handy all the time and where do I enter it?
Khai
Postby TIG » Tue Apr 17, 2012 9:02 pm
A 'one-liner' needs to be copied+pasted+<enter> into the Window > Ruby Console to do its stuff.
In this case it works on the current Selection, and changes the material of all selected faces that have the given number of edges...
Global Moderator
Postby Rich O Brien » Tue Apr 17, 2012 9:06 pm
does this thing need a module/class etc?
Also does it need a def? All this is still greek to me :roll:
Rich O Brien
Administrator
Postby TIG » Tue Apr 17, 2012 9:09 pm
A 'one-liner' stands as it is - it's just like typing any commands into the Ruby Console.
Of course you could make it a 'module' that has a 'menu' item and a 'dialog' for the number of faces etc etc...
Global Moderator
Postby Rich O Brien » Tue Apr 17, 2012 9:15 pm
let's not go there. As much as I need to highlight quads I don't want to tear my hair out. There's not much left after last time :?
Rich O Brien
Administrator
Postby thomthom » Tue Apr 17, 2012 9:42 pm
Code: Select all
# First yeh need this - you just do - so do it!
require 'sketchup.rb'
# Then yeh need a module to group your plugins
# so it doesn't fekk up everyone else's.
module ROB
# Then a smart-arse name for the actual plugin.
  module ColorByNGon
# Add your menu items here, but make sure it's
    # not added multiple times.
    unless file_loaded?( File.basename(__FILE__) )
      # Fetch yourself a handy top-level menu...
      menu = UI.menu( 'Plugins' )
      # ...sprinkle with some menu items...
      menu.add_item( 'Colour N-Gons' ) {
        self.colour_ngon
# You deffo want to add some methods.
    def self.colour_ngon
# Lets ask the user for colour and number
      # of sides in the n-gon:
      prompts  = [ 'Colour', 'N-Gon Sides' ]
      defaults = [ 'Red', 4 ]
      title    = 'Colour N-Gons'
      result = UI.inputbox( prompts, defaults, title )
      return if result == false # User cancelled - the bugger!
      # Do the magic trick!
      color, ngon = result # Extract the user input from the results.
      model = Sketchup.active_model # Get yourself a reference to the model.
      model.start_operation( 'Colour N-Gons', true ) # Because you like a tidy Undo stack
      for face in model.selection
        next unless face
        next unless face.edges.length == ngon
        face
.material = color
      model
.commit_operation # Can you commit - can you?!???
      # Profit???
# module ColorByNGon
end # module ROB
# Mark this file as loaded.
file_loaded( File.basename(__FILE__) )
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Apr 17, 2012 9:52 pm
Do I delete the orange? cause it ain't firing?
Rich O Brien
Administrator
Postby thomthom » Tue Apr 17, 2012 10:00 pm
Rich O'Brien wrote:Do I delete the orange? cause it ain't firing?
The orange is just comments - they do nothing.
I didn't test it before posting - because now I can 'fix' it for a grand fee! :D
Gimme the error message and a wallop of money!
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Apr 17, 2012 10:03 pm
error message below.... :?
Code: Select all
There's none?
Rich O Brien
Administrator
Postby thomthom » Tue Apr 17, 2012 10:08 pm
Ah - found a typo: def self.self.colour_ngon - should be def self.colour_ngon. I updated my post.
PluginStore Author
PluginStore Author
Postby Rich O Brien » Tue Apr 17, 2012 10:10 pm
That little fella was highlighted in Notepad++. So it finds the errors for you.
Rich O Brien
Administrator
Re: [Plugin] Colour N-Gons v1.0 (17/4/12)
Postby Rich O Brien » Tue Apr 17, 2012 10:47 pm
Updated first post with plugin.
Thanks Thom :thumb:
Rich O Brien
Administrator
Postby JClements » Tue Apr 17, 2012 11:20 pm
Ah, neophyte question, what is the defintion of an Ngon?
JClements
Premium Member
Premium Member
Postby Rich O Brien » Tue Apr 17, 2012 11:22 pm
a polygon with n sides
a quad is a 4-gon
a tri is a 3-gon
etc....
Hi John :thumb:
Rich O Brien
Administrator
Postby Gaieus » Tue Apr 17, 2012 11:25 pm
What about a bi? :roll:
Postby JClements » Tue Apr 17, 2012 11:28 pm
Just let bi-gons by bygones.
JClements
Premium Member
Premium Member
Postby Khai » Tue Apr 17, 2012 11:28 pm
Gaieus wrote:What about a bi? :roll:
they go either way
Khai
Postby pilou » Tue Apr 17, 2012 11:31 pm
a bi-gone = a segment line ! :mrgreen:
A one gone = a point ! :)
0 gone = void :D
Speedy Galerie
Top SketchUcator
Next
Return to Plugins
Users browsing this forum: FacundoMarro, Laredo and 13 guests
