[Plugin] LSS Matrix
[Plugin] LSS Matrix
Postby kirill2008 » Sun Apr 08, 2012 8:46 pm
Small Announcement (29-Jan-2017)
Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.
lss_matrix_1_0_beta.zip
About
It is an extension of Sketchup, which allows advanced copying of groups and component instances.
Note: ver. 1.0 runs under MS Windows only.
Installation
- Download «lss_matrix_1_0_beta.zip»
- Unpack contents of «Plugins» subfolder into SketchUp «Plugins» subfolder
- Unpack contents of «Resouces» subfolder into SketchUp «Resources» subfolder
- Enable 'LSS Matrix Toolbar': choose Sketchup Main Menu>> View>> Toolbars>> LSS Matrix Toolbar
Usage
«LSS Matrix» has preprocessing stage:
it is necessary to make an initial copy instance and «controlling» copy instance(s) before «LSS Matrix» dialog launching.
After preparations:
- Choose Plugins>> LSS Matrix>> Lss Matrix Dialog command from the main menu or click appropriate button of «LSS Toolbar»
- Pick the initial instance
- Pick copy instance(s)
- Adjust settings
- Click «Apply» to generate array of copies
kirill2008
PluginStore Author
PluginStore Author
Re: [Plugin] LSS Matrix
Postby pilou » Sun Apr 08, 2012 9:18 pm
Another cool one! :fro:
And with the Random Replacement of Components of Sdmitch you will have some crazzy things! :thumb:
Speedy Galerie
Top SketchUcator
Postby guanjin » Mon Apr 09, 2012 3:08 am
How to change the language environment, Chinese, thank you
I come from China, is to learn
guanjin
Postby kirill2008 » Mon Apr 09, 2012 10:20 am
Pilou wrote:And with the Random Replacement of Components of Sdmitch you will have some crazzy things!
Yes I think that joint use of theese two plugins can make sinergetic effect :)
guanjin wrote:How to change the language environment, Chinese, thank you
For now local resources available only in Russian. I don't know yet how to lokalize to any other language, since I good only in Russian and more or less in English (lower or maybe mid-intermediate level, I guess).
kirill2008
PluginStore Author
PluginStore Author
Postby irwanwr » Mon Apr 09, 2012 10:24 am
this is great, kirill.
good news for me. i hope there'll be some update of LSS Toolbar too :)
irwanwr
Postby unclex » Mon Apr 09, 2012 10:25 am
Brilliant!!!!!!!!!!
unclex
Postby STRANGEZOND » Mon Apr 09, 2012 11:02 am
Классный инструмент! Кирилл, Спасибо огромное!
STRANGEZOND
Postby pilou » Mon Apr 09, 2012 11:17 am
Interpolate Move + Rotation is very cool! :fro:
Exploration will be endless ;)
Speedy Galerie
Top SketchUcator
Postby pilou » Mon Apr 09, 2012 1:00 pm
Seems there is a bug! :o (tested with V7 )
Works fine with Components :enlight:
Don't work with Groups : drawing faces is not effective when pressing Apply! :(
Speedy Galerie
Top SketchUcator
Postby ly871108 » Mon Apr 09, 2012 1:31 pm
I AM CHINESE,TOO.THANKS FOR YOUR SHARING.YOU ARE SO COOL :thumb: .
ly871108
Postby SUFractal » Mon Apr 09, 2012 3:16 pm
Looking forward to experimenting with this!
SUFractal
Postby kirill2008 » Mon Apr 09, 2012 4:31 pm
Pilou wrote:Seems there is a bug! :o (tested with V7 )
Well, I tested attached skp file in SU7, it was processed fine just like in SU8.
Actually, there are no special API methods used in plugin, that requires the latest version of SU, so I think everything has to work fine even in SU6 (I just don't have it now, so it is difficult to find out).
kirill2008
PluginStore Author
PluginStore Author
Postby guanjin » Mon Apr 09, 2012 5:00 pm
Tested, very good,Has been translated in Chinese,Thank you lss :thumb:
guanjin
Postby hebeijianke » Mon Apr 09, 2012 5:11 pm
THX
chinese language
hebeijianke
Postby pilou » Mon Apr 09, 2012 6:56 pm
Yes you right works fine inside the V6 for theGroups :fro:
But now not for the Components! :mrgreen:
So I must have some plugs who make some dysfunctions inside the V7 and V6! :o
I will try to find the culprits! ;)
Speedy Galerie
Top SketchUcator
Postby Oxer » Tue Apr 10, 2012 2:32 am
Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
I use SU 8 for Mac & OSX 10.6.8
http://www.oxervision.blogspot.com/
Oxer
Postby unclex » Tue Apr 10, 2012 5:42 am
So Many Chinese :fro:
unclex
Postby kirill2008 » Tue Apr 10, 2012 5:59 am
Oxer wrote:Hi, I have installed the plugin but when i run SU it appears a Ruby Console Error, this:
Unfortunately the plugin was not tested on mac at all :( And I think, it will not work on mac...
The point is that java-script code (which is used in web-dialog) is made to run properly in IE (because SU for MS Windows uses IE to display web-dialogs). I was hurry to publish LSS Matrix and forgot to mention about this in top post (I'll fix it now). In short current version of LSS Matrix is only for MS Win :(
Pilou wrote:So I must have some plugs who make some dysfunctions inside the V7 and V6!
I hope that LSS Matrix is not a culprit itself :)
All methods encapsulated in classes as recommended to avoid naming conflicts, but maybe somthing was missed :?
kirill2008
PluginStore Author
PluginStore Author
Postby blajnov » Tue Apr 10, 2012 6:13 am
kirill2008....... в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
blajnov
Postby ZFRPS » Tue Apr 10, 2012 6:59 am
So Many Chinese :thumb:
sketchup is bim
ZFRPS
Postby gilles » Tue Apr 10, 2012 7:34 am
unclex wrote:So Many Chinese :fro:
zfrps wrote:So Many Chinese :thumb:
Is this a problem for you?
gilles
Top SketchUcator
Postby guanjin » Tue Apr 10, 2012 9:28 am
Rotating array angle to grasp the difficulties have option positioning point of view better :roll:
Maybe I did not grasp the skills
guanjin
Postby pilou » Tue Apr 10, 2012 10:02 am
Ok Good news for you I have find the culprit ;)
For me in the V7 it was "SketchyPhysics"! Now groups and Component work fine! :fro:
For the V6 I must find more :)
Speedy Galerie
Top SketchUcator
Postby kirill2008 » Tue Apr 10, 2012 10:13 am
Yes, plugin does not provide any helpers for array generation... but SU actually has its own built-in helpers ('Tape Measure' tool and 'Protractor' tool) so I decided not to bother on inventing my own helpers.
Actually plugin looks for 'difference' between transformations of initial and copy instance and then applies detected difference to an initial instance. Simple as that :)
That's why it is necessary to pay careful attention to preprocessing stage. As a hint for more neat rotation array creation I can suggest to make an anchor point, that defines rotation center (using 'Tape Measure' tool for instance).
Another way to make sure, that all single elements will coinside after replication, is to model the whole element, which will be rotated, then apply rotation and shift transformation to set of elements once.
blajnov wrote:в русском переводе не та кодировка, при нажатии на кнопку вызова основного диалога LSS Matrix. Остальные меню на русском.
Постараюсь разобраться как можно быстрее. У меня диалог отображается корректно, пока не знаю, в чем именно может быть дело...
kirill2008
PluginStore Author
PluginStore Author
Postby TIG » Tue Apr 10, 2012 10:23 am
How does this tool differ from my old 'Grow' and 'Matrix' tools ?
Apart from you having to make the first changed copy...
Global Moderator
Postby kirill2008 » Tue Apr 10, 2012 10:58 am
TIG wrote:How does this tool differ from my old 'Grow' and 'Matrix' tools ?
I didn't know about these two plugins :shock: (honestly).
After brief look at 'Grow' description I found out, that 'Grow' plugin provides more functionality, than 'LSS Matrix'...
For example, I was only going to add scaling options, 'Grow' already has exponential and even Fibonacci options aside from linear :thumb: .
As for me I was going to add a kind of adjustment curve (default option is strait line), which will give more power to affect replication results.
Life lesson #1: search for ready made desicions before reinvent a wheel...
kirill2008
PluginStore Author
PluginStore Author
Postby pilou » Tue Apr 10, 2012 11:05 am
One is more "technic" the other is more ergonomic :) (no need to enter number)
Speedy Galerie
Top SketchUcator
Postby guanjin » Tue Apr 10, 2012 3:34 pm
We look forward to the LSS update, thank you for your selfless dedication!
guanjin
Postby pilou » Tue Apr 10, 2012 4:09 pm
For me it's not inside the V6 Plugins folder that avoid Components to work! :shock: Maybe in Resource or other folders :?:
No problem because all works fine in V 7 (disable Sketchyphysics) ;) or with groups inside V6 ;)
Speedy Galerie
Top SketchUcator
Postby blajnov » Tue Apr 10, 2012 4:49 pm
Разобрался, преобразовал в блокноте два файла в кодировку UTF-8
lss_matrix.html
lss_matrix_mini.html
blajnov
Next
Return to Plugins
Users browsing this forum: anugrahrf510, niloofarhojati, Sol_moses, ysw6158sunwoong and 14 guests
