[Plugin] Image 2 Model
• Page 1 of 1
[Plugin] Image 2 ModelLooking for a script to take a folder off the hard drive and batch convert transparent .png files to .skp with a 0,0,0 axis and face camera enabled. A bonus would be if it would hide the perimeter edges of the image. It's not necessary to cut them out for shadows as they will be rendered. Just looking to speed up the conversion process as I have hundreds of plant images that I've taken and isolated and the manual conversion is becoming quite tedious. Not sure if something already exists. Any help would be much appreciated.
EDIT - Much thanks to SDMitch! Most recent plugin attached. Please, register (free) to access all the attachments on the forums.
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: {REQ} Batch Import .png to .skp face cameraAm I correct in assumming that you want each image in its on .skp file and placed at the origin?
Images are included in a model's definitions but I don't think the .behavior.always_face_camera applies. I believe it only applies to components.
Re: {REQ} Batch Import .png to .skp face cameraIn such a case, images should be exploded and the face (bearing the image material) turned into such a component.
You can turn an image entity into a component, too (and face to the camera) but that would cause all sorts of issues with external renderers as not each can recognise image entities at all. Now the ultimate question (if such a script were possible): how to scale those components? Gai...
Re: {REQ} Batch Import .png to .skp face cameraAdam, Would you post an image that I could test. I have been working on your plugin and I want see if it works the same with one of your images as it does with mine.
Gaieus has a point regarding sizing the images/components.
Re: {REQ} Batch Import .png to .skp face cameraYou set the image size as you import it, but you can reset it later after reading its pixel sizes and basing the inch sizes on those, pro-rata...
The basic code to add an image is: image-entities.add_image(path_to_file, insertion_point, width, [height]) The width/height are in inches. The last argument [height] is optional, if omitted it is taken as being in proportion to the width you have set. An added image typically arrives 'flat' at the ORIGIN - if it's a plant or tree you'll probably want to stand it up on its end - you can apply a simple rotation transformation:tr=Geom::Transformation.rotation(ORIGIN,X_AXIS,90.degrees) image.transform!(tr) You might also want to shunt the image so that the center of its bas is at the ORIGIN rather than it bounds.min ? Here a simple translation is needed: tr=Geom::Transformation.translation([image.width/2,0,0].vector_to([0,0,0])) image.transform!(tr) TIG
Re: {REQ} Batch Import .png to .skp face cameraTIG, Great minds think alike. I originally tried moving the Image bottom center to the Model ORIGIN before making it first a Group then a Component but didn't change the point the Image rotated about when Orbiting. I had to move the Component.transformation.origin instead.
One thing that I can't seem to resolve is the fact that although I do a "viewFront:" and a "viewZoomExtents:" before doing the .save, the model, when opened, has not been saved that way.
Here is one of my hi-res .png files for testing. Yes, I did forget to mention a few steps. The routine is - 1. Import and place 'image' in front viewport. 2. Center on axis as pivot point 3. Explode image 4. Select all 5. Make Component (Check always face camera, shadows face sun 6. Enter component edit and select outer edges and hide them. 7. Exit component and 'Save as' image name. Thanks for looking into it Sam and for the help TIG. If something can be manifested it would save hours of tedious work. Please, register (free) to access all the attachments on the forums. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: {REQ} Batch Import .png to .skp face cameraAdam, Your image worked exactly like mine so I have attached Image 2 Model I. When you execute the plugin, The Open panel will allow you to select the source folder for the images. Next, the Save panel will allow you to select the destination folder for the models. An inputbox will let you choose whether the image is to be "stood up" and the width for the images. Since this is a "batch" process these options will be applied to all images in the source folder.
I still haven't resolved the problem of the saved file not being frontview and zoomed extents. It seems that it saves the model however the default template is setup. Check it out and let me know how it worked for you. Please, register (free) to access all the attachments on the forums.
Re: {REQ} Batch Import .png to .skp face cameraWorks great with one exception. Can you perhaps set it to save just the newly created component and not save a copy of "Susan" along with each new .skp? Perhaps that's is the issue you are already referring to. I need to be able to compile these plants through the component folder. Other than that it's working like a charm!!
Also, just noticed that the component is still an "image". Possible to explode that down before the component conversion? Not sure if the final .skp files will work with all render engines with 'images' embedded. A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: {REQ} Batch Import .png to .skp face cameraIf Susan is showing up it because she is in your default template.
I take a look at exploding.
Re: {REQ} Batch Import .png to .skp face cameraYou could always some code at the start to erase all model entities...
Sketchup.active_model.entities.erase_entities(Sketchup.active_model.entities.to_a) [or a Sketchup.active_model.entities.clear [edit]] Then .purge_unused for all model components, materials, layers and styles before adding the new image into the now sanitized model. Surely image.explode will do the desired extra step ? TIG
Re: {REQ} Batch Import .png to .skp face cameraAdded a .clear! to make sure the new file is empty. Exploded the image and hide the edges.
Re: {REQ} Batch Import .png to .skp face cameraThe 'entities.clear' only erases the instance of Susan [and any other stuff placed in the default template].
BUT the definition still remains in the SKP, as do any now-unused related materials, layers etc. It's best to have a '.purge_unused' for these after the '.clear'... TIG
Re: {REQ} Batch Import .png to .skp face cameraI haven't been able to find .purge_unused.
sorry, I did find it for materials and styles. Searching returned no results.
Re: {REQ} Batch Import .png to .skp face cameraYour search tool is faulty...
https://developers.google.com/sketchup/ ... rge_unused https://developers.google.com/sketchup/ ... rge_unused https://developers.google.com/sketchup/ ... rge_unused https://developers.google.com/sketchup/ ... rge_unused TIG
Re: {REQ} Batch Import .png to .skp face cameraI did the search, .purge_unused, at
https://developers.google.com/sketchup/docs/ which is the Ruby API page and it found nothing. Apparently it was the "." that cause the failed search. Lots of results without it.
Re: [Plugin] - Image 2 ModelFirst post updated with [plugin] tag.
Got a bit busy and haven't had a chance to truly say thanks! SDMitch, I owe you a beer! Plugin works great. Thanks again! ![]() A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
I opened the PNG image, the view does not show I come from China, is to learn
Re: [Plugin] - Image 2 ModelJust wanted to say thanks for this plugin, it really is super helpful!
Re: [Plugin] - Image 2 ModelThank you all, I'll try to learn how to use this.
Might be better to place face me comps rather than just placing them in post pro mostly. Does this script function also available in SKM Tools by TIG. Sorry sir, just curious.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
• Page 1 of 1
