[Plugin] Debug tool: run lastloaded ruby
Postby liquid98 » Sun Mar 25, 2012 10:11 am
Hi!
This plugin simplifies the debugging process with a few mouse clicks. It works in conjunction with Jim Foltz' rubytoolbar, which can be found here:
http://sketchuptips.blogspot.com/2007/08/plugin-ruby-toolbar.html
Once you've loaded the script you want to debug through the rubytoolbar, you can simply reload and execute your script in one step.
How does it work?
Lastloaded.rb looks for a line in your code tagged with:
Code: Select all
#loadme
So just put this string after the line in your code that Sketchup has to execute.
For example:
Code: Select all
new_menu = UI.menu("Plugins")
cmd = UI::Command.new("text") {some command} #loadme
new_menu.add_item(cmd)
Lastloaded will now reload your script and automatically runs 'some command' for you. The script has a menu item in the Tools section, so you can assign a shortcut if convenient.
Have fun! I'm open for questions / suggestions
Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
liquid98
Return to Plugins
Users browsing this forum: alanazuquello156, Diamoss, puntoclassic and 15 guests
