[Plugin] Multiple Offsets (Updated 09-Feb-2014)
Postby sdmitch » Wed Feb 22, 2012 8:28 pm
In response to http://forums.sketchucation.com/viewtop ... 23&t=43426
One last update. Addressed problem of possible conflict with other plugins
and fixed a bug when using a delta values list with multiple faces.
Select one or more faces. Run the plugin and select one of three offset methods.
Constant: Input number of offsets, distance between offsets, direction to
offset, either inside, outside, or both, and whether the selected face(s) and all
created faces are to be deleted, select No to keep faces.
Formula: Enter number of offsets, distance to first offset, direction to offset,
delete faces Yes or No, select operator + or *, and value to add or multiply by.
List: Select direction of offsets, delete faces Yes or No, a list of offsets
separated by commas, choose type of offset either absolute or a delta value
to be added to the last offset value. If the offsets are a repeated sequence,
end the list with *X, where X = the number of repetitions for the offset
sequence entered.
In one test case, the offsets were placed opposite of the direction setting. Why this occurred is still a mystery. The simple solution is to undo, rerun and choose the opposite direction.
The latest version is available from the PluginStore...
Download
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] Multiple Offsets
Postby pilou » Wed Feb 22, 2012 10:04 pm
Maybe it will cool also to keep the surfaces ? (first and news)
Because we can't make surface with the new curves even welded! :?:
Here with the plug "create face"
Speedy Galerie
Top SketchUcator
Postby sdmitch » Wed Feb 22, 2012 10:36 pm
Retracing any segment of the closed curve with the Line Tool should create a face.
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Wed Feb 22, 2012 10:44 pm
Redraw a "big" :rectangle: above the result and intersect all make the trick and very more speedy than all redraw with the :line: ;)
Speedy Galerie
Top SketchUcator
Postby sdmitch » Thu Feb 23, 2012 5:10 pm
New version has been posted
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Thu Feb 23, 2012 5:39 pm
You definitly rocks!!! :thumb: :fro: :enlight:
Speedy Galerie
Top SketchUcator
Postby dtrarch » Thu Feb 23, 2012 10:04 pm
Sam
Good stuff and thank you. :thumb:
dtr
dtrarch
Premium Member
Premium Member
Postby Ben Ritter » Thu Feb 23, 2012 11:10 pm
sdmitch, Thank you!
Ben Ritter
Re: [Plugin] Multiple Offsets (Updated 27-Feb-2012
Postby sdmitch » Mon Feb 27, 2012 8:29 pm
Major update posted today. Offsets can be created by three methods
seperated by commas, choose type of offset either absolute or a delta value
end the list with *X, where X = the number of repititions for the offset
sequence entered.
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] Multiple Offsets (Updated 27-Feb-2012)
Postby simon le bon » Mon Feb 27, 2012 9:16 pm
Thank you Sam,
It's a gem. :thumb:
older version overwritten by the new one ;)
++simon
simon le bon
Postby pilou » Tue Feb 28, 2012 12:00 am
curious nothing append on V7 and V6! :o
All menu appear but nothing is done! Does this normal ?
Work like a charm in V8 ! :fro: (aespecially the * x with a list ! :thumb: ;)
As the "exotic Push Pull" seems have a problem maybe will be a good thing to input it inside this plug during the calculate ?
Or See my new request ;)
Speedy Galerie
Top SketchUcator
Postby simon le bon » Tue Feb 28, 2012 11:03 am
Hi Pilou and Sam,
Multiple Offsets works for me with Su7
However problems with the List Options:
- List:Offset by * 3
Absolute and Delta choice gives the same result:
>> x3 Delta offset (see pict)
(colored after for a better watch)
- List: Offsets: + operator don't work and deletes the offseted faces
simon
simon le bon
Postby pilou » Tue Feb 28, 2012 11:51 am
@Simon
Curious you write 20,30,40,50*3, that must be 20,30,40,50,*3 ;)
Edit : in fact that gives the same result! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby pilou » Tue Feb 28, 2012 12:35 pm
I have added some plugins for another things in V8
All menus Offset Multiples are fine but nothing append! :shock:
Seems there is a conflict with another plugs! :o
Must find the the culprit(s)! (resolved see the next page for see the culprit) ;)
Speedy Galerie
Top SketchUcator
Postby guanjin » Tue Feb 28, 2012 12:47 pm
sdmitch wrote:Major update posted today. Offsets can be created by three methods
sequence entered.
Great tool invention
Can realize line migration, generating surface?
Perhaps we should not be too many requests
thank you sdmitch
:family:
I come from China, is to learn
guanjin
Postby guanjin » Tue Feb 28, 2012 12:54 pm
sequence entered.
DWG files import, Is no surface of
thank you sdmitch
:family:
guanjin
Postby guanjin » Tue Feb 28, 2012 12:55 pm
sequence entered.
DWG files import, Is no surface of ,
thank you sdmitch
:family:
guanjin
Postby pilou » Tue Feb 28, 2012 1:04 pm
Ok for the Conflict in V8 free the culprit is "Windowizer3" ! :enlight:
Speedy Galerie
Top SketchUcator
Postby blajnov » Tue Feb 28, 2012 2:57 pm
Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...:cry:
The previous works perfectly well.
blajnov
Postby guanjin » Tue Feb 28, 2012 4:01 pm
blajnov wrote:Respected sdmitch, the new version of a plug-in, doesn't work in SketchUp 8 Pro M2...:cry:
I also SU8M2, no problem
guanjin
Postby sdmitch » Tue Feb 28, 2012 4:02 pm
blajov, sorry about that but I only have SU8 Free at my disposal so there is no way for me to determine why that is the case.
sdmitch
PluginStore Author
PluginStore Author
Postby ken » Wed Feb 29, 2012 1:13 am
Sam
The multiple offset does not work on my computer,none of the options, constant, formula or list. I have Sketchup, V8, M1. Here is the error message. Hope this helps.
Error: #<ArgumentError: wrong number of arguments (3 for 1)>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in `offset'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in `do_offsets_constant'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:74:in `do_offsets_constant'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:72:in `do_offsets_constant'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:49:in `do_offsets'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:30
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/Multiple Offsets-A.rb:76:in `call'
Thanks in advance for looking at this problem and the plugin.
Ken
ken
Premium Member
Premium Member
Re: [Plugin] Multiple Offsets (Updated 29-Feb-2012)
Postby sdmitch » Wed Feb 29, 2012 8:16 pm
One last update!!!
sdmitch
PluginStore Author
PluginStore Author
Postby mirale999 » Sun Mar 25, 2012 2:54 am
:berserk: Great plugin~
paranoia is a higher form of awareness...
mirale999
Re: [Plugin] Multiple Offsets (Updated 09-Feb-2014)
Postby nmhai » Tue Feb 11, 2014 10:28 am
ERROR FOR ME:
nmhai
Postby Dave R » Tue Feb 11, 2014 11:58 am
Thank you very much for the update, Sam. It does exactly what I needed.
nmhai: That's not an issue with the plugin. You'd get that with the native offset tool as well. The error is in the setup. You can either fix by deleting the unwanted edges or you start with the inner most profile and offset outward. You might also have a look at TIG's Smart Offset.
Global Moderator
Postby cotty » Wed Feb 12, 2014 8:07 pm
Dave R wrote:update
cotty
Top SketchUcator
Return to Plugins
Users browsing this forum: cbaritello, iepanks, thunderxeon, ysw6158sunwoong and 14 guests
