[Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
Postby sdmitch » Sun Feb 19, 2012 6:27 pm
Now SU2014 compatible.
In response to the request of tspco
http://forums.sketchucation.com/viewtop ... 23&t=43332
THE FINAL FINAL UPDATE
Version V Option to create the ceiling tiles added. Added 4X4 size option. Removed the gap
between the cross pieces and main grid members. A few tweaks to hopefully cure the problem
of reversed tiles.
Version IV Corrected selection of longest side and fixed a bug caused by the rotate option.
Version III Option added to use "center" of the face as the grid origin and a "rotate" option if the default orientation is not what you want.
Select a rectangular face that represents the limits of the ceiling grid to be generated. Run plugin and choose tile size either 2X2' or 2X4', the grid origin either corner or center, and rotate yes or no.
Selected face is replaced by generated "tee" grid. The individual members of the grid are components and all are contained in a group.
The grid starts in the corner defined by the longest pair of sides if corner option is selected and is oriented parallel and perpendicular to the longest edge.
Please get the latest version from the PluginStore
Download
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] Generate Ceiling Grid I
Postby mitcorb » Sun Feb 19, 2012 7:26 pm
Hi, sdmitch:
You don't have to believe this, but while reading the thread your name came up in the back of my mind, as someone who might devise a tool like this. I have viewed your collection of very handy tools on occasion. Thanks to you. :thumb: :thumb:
mitcorb
Top SketchUcator
Postby Bob James » Mon Feb 20, 2012 8:52 am
Somewhat off topic, but I use several of your plugins, sdmitch. Would it be possible for you to create icons and "package" some of your plugins into one plugin? :bounce:
e.g.:
EqSegCurve
EdgeFollowMe
Double Line
DashedLine
Comp String
Bob James
Premium Member
Premium Member
Re: [Plugin] Generate Ceiling Grid (Updated 22-Feb-2012)
Postby sdmitch » Thu Feb 23, 2012 5:12 pm
New version has been posted.
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Thu Feb 23, 2012 5:18 pm
can be used with the new Tig Split tool ?
Speedy Galerie
Top SketchUcator
Postby sdmitch » Thu Feb 23, 2012 5:59 pm
Maybe but not sure how. Splitup just sub-divides a face. This plugin acutally creates the suspended ceiling "T" rails and "L" boundaries.
sdmitch
PluginStore Author
PluginStore Author
Postby pilou » Thu Feb 23, 2012 7:35 pm
Seems working together without any problem :)
(Just don't forget to enable Hidden geometry for the Split Tig plug! :oops:
Your plug has absolute measures ? Because it made just a little one grid on the little rectangle on the right!
And not completed trimings on the other surfaces as shown on the image
Does this normal ?
In fact I don't know exactly what is a "Ceiling grid" :oops:
Have you a photo link of that ?
Speedy Galerie
Top SketchUcator
Postby mitcorb » Thu Feb 23, 2012 8:15 pm
Hi, Pilou:
If you are looking for photos, you might look at Armstrong (World Industries), a major ceiling tile and floor tile manufacturer. A ceiling grid is a suspension system to hold acoustical tiles for both decorative and acoustical control purposes. The ceiling grid is suspended by an array of wires attached to structure above. The grid also would support light fixtures designed to fit into the grid. And, as sdmitch said, the elements are inverted T shaped intersecting rails and L shaped perimeter wall members.
mitcorb
Top SketchUcator
Postby sdmitch » Thu Feb 23, 2012 8:20 pm
pilou, Just what are you trying to do?
A ceiling grid is the metal pieces that support ceiling tiles for a suspended ceiling.
sdmitch
PluginStore Author
PluginStore Author
Postby tomot » Thu Feb 23, 2012 11:45 pm
Nice addition! I made a similar 2d grid used for a reflected ceiling plan using AutoLSP. many years ago. One thing missing is some math.
1. A Suspended ceiling tile installer will divide any room by the number of tiles req'd, in length and width.
2. He or she will then divide the left over tiles/2. Meaning leftover/2 tiles will occupy all the perimeter areas of the room, the remainder of the full size tiles fill the rest of the space.
tomot
PluginStore Author
PluginStore Author
Postby pilou » Fri Feb 24, 2012 12:06 am
So this ? :)
Speedy Galerie
Top SketchUcator
Postby mitcorb » Fri Feb 24, 2012 1:41 am
Oui, Monsieur!! ;)
mitcorb
Top SketchUcator
Postby SUFractal » Fri Feb 24, 2012 1:59 am
This looks like a nice little plugin, but if I'm not mistaken, I think the grid "angle" at the perimeter is generated backwards isn't it? The angles should be reversed so that the ceiling 'pad' rests on the horizontal leg of the angle. The attached image shows a corner.
Thanks.
SUFractal
Postby mitcorb » Fri Feb 24, 2012 2:07 am
I have to agree with SUFractal. I have not had the opportunity to download and test it, so I didn't know. The Tees rest on the horizontal leg of the L's
mitcorb
Top SketchUcator
Postby sdmitch » Fri Feb 24, 2012 3:33 am
SUFractal wrote:This looks like a nice little plugin, but if I'm not mistaken, I think the grid "angle" at the perimeter is generated backwards isn't it? The angles should be reversed so that the ceiling 'pad' rests on the horizontal leg of the angle. The attached image shows a corner.
Thanks.
You are correct the perimeter pieces are backwards. It seem that it makes a difference if you are looking at the back or front side of the face. If you reverse the face, I think that will solve the problem. I need to add a statement to check the normal of the face selected to make sure whick way it is facing.
sdmitch
PluginStore Author
PluginStore Author
Postby guanjin » Fri Feb 24, 2012 6:10 am
Why did you choose the negative and positive point of view is not correct, the grid can have a smaller selection.
I come from China, is to learn
guanjin
Postby SUFractal » Fri Feb 24, 2012 3:57 pm
Yes, that does solve the problem sdmitch. I was clicking on a face looking down at it ... more of a 'roof' perspective than looking up at the 'ceiling'.
Is it possible to have the grid generated to be centered on the face in both directions, rather than have it start in one corner?
SUFractal
Postby sdmitch » Fri Feb 24, 2012 6:18 pm
juanjin, I didn't really choose the negative view. As you know when you draw a shape on the xy plane, its' face down and so that how the plugin was created and tested.
SUFractal, I chose starting in a corner to limit the number of partial tiles but there is no reason that the origin counldn't be in the center of the face.
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] Generate Ceiling Grid (Updated 24-Feb-2012)
Postby sdmitch » Fri Feb 24, 2012 6:25 pm
Another day, another update!
sdmitch
PluginStore Author
PluginStore Author
Postby SUFractal » Fri Feb 24, 2012 10:32 pm
Excellent sdmitch!
As you probably know, that is how grids are generally laid out (design and construction). :)
SUFractal
Postby guanjin » Sat Feb 25, 2012 5:21 pm
sdmitch wrote:Another day, another update!
Hallo sdmitch
Freedom to change the size is too important!
But still quite useful :berserk:
guanjin
Postby mitcorb » Sat Feb 25, 2012 5:46 pm
Hi.
Guanjin is suggesting what sounds like a Dynamic Component? Adjust the component with change in room size and the tool inserts additional tees as required, as well as stretches tees and angles. Seems pretty involved, but maybe not.
mitcorb
Top SketchUcator
Postby sdmitch » Sat Feb 25, 2012 9:49 pm
Hallo sdmitch
If you have other standard sizes you would like to use, simply add them to the code. If you don't feel capable of doing that, tell me what you would like to have as size options.
sdmitch
PluginStore Author
PluginStore Author
Re: [Plugin] Generate Ceiling Grid (Updated 28-Feb-2012)
Postby sdmitch » Tue Feb 28, 2012 5:04 pm
Yes, yet another update incorperating two suggested inhancements.
sdmitch
PluginStore Author
PluginStore Author
Postby RonS » Tue Feb 28, 2012 5:10 pm
Thank You Sam. Great plugin
Design is not just what it looks like and feels like. Design is how it works.
Steve Jobs
RonS
RonS
Postby massimo » Tue Feb 28, 2012 5:33 pm
Thanks for the very useful plugin Sam. :thumb:
It would be even more useful if you could select an edge as orientation of the grid and maybe if you could have the possibility to choose the corner wich you want the grid to start from. Now it produces incorrect results with not conventional shapes.
massimo
Postby tomot » Wed Feb 29, 2012 2:28 am
Fantastic!......I like it, its now ready for the actual ceiling tiles to drop into place! :bounce:
tomot
PluginStore Author
PluginStore Author
Postby SUFractal » Wed Feb 29, 2012 3:28 am
Beautiful! Thanks sdmitch.
SUFractal
Re: [Plugin] Generate Ceiling Grid (Updated 29-Feb-2012)
Postby sdmitch » Wed Feb 29, 2012 8:26 pm
One last update I hope.
sdmitch
PluginStore Author
PluginStore Author
Postby mitcorb » Wed Feb 29, 2012 8:34 pm
"Hope springs eternal"
mitcorb
Top SketchUcator
Next
Return to Plugins
Users browsing this forum: ahmadayof, Alexa Bot, catharsiss, danigumz, Fibox, fredo6 and 13 guests
