SketchUcation Premium Membership
[Plugin] TIG.splitdonut v1.1 20120219
Postby TIG » Sat Feb 18, 2012 12:44 pm
(c) TIG 2012
Script:
TIG-splitdonut.rb
Splits 'donut' shaped faces made with followme etc into 'quads'
[four-sided faces].
Select some faces to process.
All other selected entities and any non-compliant faces are discarded.
Only those faces with an outer-loop and just one inner-loop which both have
the same number of vertices are processed.
Lines are then added between 'matching' vertices to divide the 'donut' face
into 'quads' [four-sided faces]...
Type into the Ruby Console: TIG.splitdonut
OR use Tools > Split Tools... submenu item.
It is one step undoable.
Donations: by PayPal.com to info @ revitrev.org
Version:
1.0 20120218 First issue.
1.1 20120219 At the end all new Edges added are selected to let you use
Entity Info to set them soft/smooth or hidden etc as desired.
Error messages added if incorrect selection.
Now in Tools > Split Tools submenu http://forums.sketchucation.com/viewtop ... 58#p386658
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] TIG.splitdonut v1.0 20120218
Postby cotty » Sat Feb 18, 2012 12:55 pm
Very helpful (e.g. for artisan proxy creation), thank you very much!
A picture is worth a 1000 words. A 3D SketchUp model is worth a (1e3)^2 words?!
my little gallery
cotty
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: education
Postby Gaieus » Sat Feb 18, 2012 12:59 pm
Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby TIG » Sat Feb 18, 2012 1:36 pm
Gaieus wrote:Interesting tool and thanks TIG. It only works on donut shapes however. Could it be improved so that it could work on non-circular shapes, too? Like an arch for instance.
Try this viewtopic.php?p=386610#p386610 TIG.splitsausage...
Global Moderator
SketchUp version: 8
License type: Pro
Postby jason_maranto » Sat Feb 18, 2012 3:48 pm
Are these ultimately going to be grouped together on a toolbar?
Best,
Jason.
jason_maranto
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby TIG » Sat Feb 18, 2012 3:56 pm
Like this viewtopic.php?p=386658#p386658
TIG-splitTOOLS toolbar/menu combing all three related tools...
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] TIG.splitdonut v1.1 20120219
Postby TIG » Sun Feb 19, 2012 1:25 pm
Here's v1.1 viewtopic.php?p=386601#p386601
At the end all new Edges added are selected to let you to use Entity Info to set them soft/smooth or hidden etc as desired.
Now in Tools > Split Tools submenu viewtopic.php?p=386658#p386658
Global Moderator
SketchUp version: 8
License type: Pro
Postby d12dozr » Mon Feb 20, 2012 6:11 pm
cotty wrote:Very helpful (e.g. for artisan proxy creation), thank you very much!
Exactly...Thanks TIG! :D
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: product design
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Plugins
Users browsing this forum: dtrarch, isaongt, radiacor and 11 guests
