[Plugin] Crysis plugin - dynamic toolbox
Postby fatihbarut » Mon Feb 13, 2012 8:31 pm
Hi guys,
Using Delphi I developed a dynamic toolbox which may be useful for all sketchup users.
Here is the web site. I hope it makes your jobs easy as it does mine.
http://crysisplugin.weebly.com/
I would be happy to learn ideas about this project.
fatihbarut
Re: [Plugin] Crysis plugin - dynamic toolbox
Postby utiler » Mon Feb 13, 2012 10:44 pm
Interesting Mehmet. Not something I would use though but I like what you have done with it!!
utiler
Top SketchUcator
Postby chrisjk » Tue Feb 14, 2012 9:34 am
I followed your instructions but nothing appears for right click, except the usual context menu.
To try your plugin, I am using Sketchup 8 free version in Parallels on a Mac. Every other Windows program I use in Parallels works perfectly so I think that the problem lies with the plugin or something I am doing wrong.
Chris
chrisjk
Premium Member
Premium Member
Postby fatihbarut » Tue Feb 14, 2012 10:27 am
I think there should be some more arrangments to use this plugin in Mac. Because this plugin uses an .exe file which should compile specially for Mac OS.
However I would be happy if some PC users recommend. Therefore I can differantiate whether this problem is a bug or is really Mac problem.
fatihbarut
Postby fatihbarut » Tue Feb 14, 2012 10:28 am
utiler wrote:Interesting Mehmet. Not something I would use though but I like what you have done with it!!
Thanks, but why you don't use it? You like keyboard shourtcuts?
fatihbarut
Postby srx » Tue Feb 14, 2012 10:33 am
Nice, but shortcuts are faster and they don't cover model on screen.
www.saurus.rs
srx
Postby fatihbarut » Tue Feb 14, 2012 11:05 am
srx wrote:Nice, but shortcuts are faster and they don't cover model on screen.
I won't be so sure about that :)
Firstly it covers the model for seconds or miliseconds (depending your and your machines speed) then disappears.
Secondly, using 2 hands instead of one is much more tiring.
And finally sometimes after several hours of work I really need Independence from keyboard...
even you like, you used to use keyboard shourtcuts, I recommend you to try this one, but I don't take responsibility if you used to new one :)
fatihbarut
Postby Didier Bur » Tue Feb 14, 2012 11:38 am
When double-clicking on the exe file, I got an error message: CrysisPlugin.exe is not an Win32 valid application.
(Tested on WinXP)
Is that only for Vista or Win7 ?
Providing an exe to install is a good idea but may have inconvenients...
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby chrisjk » Tue Feb 14, 2012 11:55 am
I got this working now. The setup file left the file CrysisRigth.rb behind in the installation folder. I moved it manually to the Google plugins folder and everything worked.
I normally use keyboard shortcuts but there is no doubt your plugin is very fast and because I use a Space Navigator, I think with a little practice, I would be faster by using your plugin as then I could keep my left hand on the Space Navigator and my right hand on the mouse.
I think if you could customise what appears in your system it would be even more useful.
Do please port this to the Mac!
Chris
chrisjk
Premium Member
Premium Member
Postby fatihbarut » Tue Feb 14, 2012 12:25 pm
Dear chrisjk, firstly thanks for your effort.
When I have read your message I had already uploaded the new version of setup file (which does not remain the CrysisRight.rb file) and also changed the plugin from 64 bit to 32 bit please redownload the setup file. And change the CrysisPlugin.exe which is under " C:/Crysis Plugin " folder in your computer with the one you newly downloaded.
Thanks again for your attention.
fatihbarut
Postby fatihbarut » Tue Feb 14, 2012 12:57 pm
: Didier Bur
I changed the version of the Crysis Plugin.exe from 64 bit to 32 bit. Please look at my previos message to learn how to change the 64 bit version (which you installed before) with 32 bit one (which you newly downloaded).
fatihbarut
Postby Didier Bur » Tue Feb 14, 2012 1:32 pm
Me again,
Install went well this time, thanks for your efforts.
I'd really like to use this tool but lots of icons don't do anything: explode, make group, make component for instance.
As I'm using extensively these functionalities, this makes the toolbar almost unusable for me.
Note that I've succesfully imported the dat file you provide in the package(anyway, strange idea to create a 'c:\Crysis Plugin' folder outside the SketchUp folder ?)
Thanks for your efforts,
Didier Bur
Didier Bur
Postby fatihbarut » Tue Feb 14, 2012 2:30 pm
I had to. Otherwise windows account user settings would block the program. I experinced it in another computer.
for the other problems which are about not working buttons firstly don't worry, together we can find and solve the problem.
Now coould you open the CrysisPluginShurtcuts.dat file with notepad and then select all in that file copy and paste here please.
fatihbarut
Postby fatihbarut » Tue Feb 14, 2012 3:16 pm
I explained how to change shortcuts manually here
http://crysisplugin.weebly.com/problems ... tions.html
fatihbarut
Postby chrisjk » Tue Feb 14, 2012 3:50 pm
I tried to edit this by adding a couple of extra shortcuts but they do not appear in the circular palette.
One was a shortcut to a plugin, the other a shortcut to a Draw Menu item.
Is there a way to add extra spaces/icon on the palette?
Didier, those things you mention work fine for me.
Chris
chrisjk
Premium Member
Premium Member
Postby fatihbarut » Tue Feb 14, 2012 4:56 pm
In fact, if your sketchup is English, if you just import the CrysisPluginShortcuts.dat properly, it will do all thing for you in one shot.
However if your sketchup's language is different then English you should change your shortcuts manually as I explained it here
To make something clear, this shotcut problem is not because of me. This is because of these things.
1- There is no com object or .dll file for third party programs (Like I made with delphi) to send commands to sketchup via ruby script.
2- The documentation and/or rubby script commands (even for making group) is not enough. I tried not to use shortcuts but there weren't any ruby script command to do some actions.
Finally don't hesitate to contact me, I ll try do my best to help... This is what I can.
fatihbarut
Postby CadFather » Tue Feb 14, 2012 5:57 pm
Thank you Mehmet
the way i'd like see it developing, is by giving the user the possibility to customize the contents..
many 'power users' rely almost exclusively on key-shortcuts for many tools.. so the chance to assign plugins (and icons) to the wheel would definitely make it a must-have. whether or not you may go down that route - great idea and implementation! :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby unclex » Tue Feb 14, 2012 8:42 pm
Brilliant!!!!!
It's So Fun!!!!
Win7x86pro SU8.11pro
and I change the C:\C... to SU's Plugins Catalog
it worked
One Question
I still use my own shortcuts, it would make some problem??
unclex
Postby fatihbarut » Tue Feb 14, 2012 11:52 pm
thanks for encouraging comments.
and about the question, "can I use my shortcuts"
I have used the default shortcuts as much as possible. However I should have assigned new shotcuts.
Actually I explained the answer here more detailed.
fatihbarut
Postby JerzicekX7 » Thu Mar 01, 2012 9:29 pm
didnt work for me, any way to uninstall this plugin?? after instalaltion cant work my right mouse button :?
JerzicekX7
Postby fatihbarut » Sun Mar 04, 2012 9:25 am
it took several months to make that plugin just the way it looks now :)
I think if I spent a couple of another months I may add something like you want :)
However it really needs a professional touch.
therefore I tried to inform Google to add this plugin as a new kind of future to next version (9.0 may be)
I am not sure I achieved that. But if you can, and if you want please inform Google to add this kind of future to their next generation.
fatihbarut
Postby fatihbarut » Tue Apr 10, 2012 6:05 pm
I am wondering if anyone have speed problem with this plugin (pop up time). I am asking because I had made 64 bit version and saving it for these kind of problems.
fatihbarut
Postby Krisidious » Tue Apr 10, 2012 11:56 pm
I think it's a great start... a good idea. I think it should be shortened and not so busy, perhaps levels of tools instead of everything out at once. and perhaps the toolbar could be transparent so that one could still see the model behind.
good work. I'll be following.
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby AcesHigh » Wed Apr 11, 2012 4:34 am
insteresting. So you got the idea for this menu from the game Crysis uh? I think my first experience with radial menus in a game was Independence War 2: Edge of Chaos
AcesHigh
Postby Silverthorn » Fri Oct 12, 2012 7:01 pm
I've been using this for a little while now and thought I should drop by and say I love it!! I do agree that it would be an improvement to be able to rearrange and customise the contents of the tool bar but even so it's a great interface and a pleasure to use!!
Thanks.
Silverthorn
Postby pbacot » Thu Sep 17, 2015 1:31 pm
Yes, I might use it (if it were on Mac) for those tools I use sometimes, but not enough for a shortcut memorization. So I would not be interested in seeing the basic SU tools but some plugins only.
I also like Kris's idea on levels, or at least say 5 categories so that one expands at at time.
Top SketchUcator
Return to Plugins
Users browsing this forum: No registered users and 14 guests
