by thomthom » Mon Jan 09, 2012 11:05 am
OverviewResponse to this thread: http://forums.sketchucation.com/viewtop ... 15&t=42390Will let the user cycle through the five last selection sets. Useful when you for instance accidentally deselects a carefully crafted selection. Important!This plugin has not been tested under OSX! It is not known how it will behave under SketchUp OSX where one process can have multiple models open. Unpredictable behaviour will most likely occur - possibly bugsplats. ModificationTo modify the number of saved sets, modify this constant: SELECTION_STACK_SIZE = 5I recommend you do not change this to a too large number. AccessEdit > Cycle Previous SelectionsFeatures- Cycle Previous Selections
Cycles through the last 5 selection sets. Requirements- SketchUp 8 or newer - ( Other versions untested )
- Might work with older version. Just test for yourself. Either it works or it doesn't.
Download tt_selection_memory.rb Footprint <Sketchup>/Plugins/ +-
- Global Moderator
- Name: thomthom
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by Rich O Brien » Mon Jan 09, 2012 11:23 am
Nice tool Works like a charm
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
- SketchUp use: engineering and mechanical design
by mitcorb » Mon Jan 09, 2012 1:54 pm
Thanks, thomthom: Tested in Sketchup 7, also. Worked on first try.
mitcorb
- Top SketchUcator
- Name: Tim
- License type: Free
by massimo » Mon Jan 09, 2012 2:08 pm
Thanks! It seems not working with edges with the last selection. I mean select a rectangle with a double click-->deselect-->"cycle previous selection" and only the face is selected. But if you've made another selection and go back to the initial selection then it works. SU pro 7.1
massimo
- Global Moderator
- Name: Massimo Siracusa
- SketchUp version: 7
- License type: Pro
- SketchUp use: other
by thomthom » Mon Jan 09, 2012 2:15 pm
When you double click - two selections sets are made. One for the first click on the face - and one on the second click when edges are selected. If you deselect after a doubleclick you need to cycle two times to restore the selection with both borders. It is a bit counter-intuitive some times like that.
Basically how it works: Every times you change the selection - the selection set is stored in the selection stack. Cycle selection advances the internal index and fetches the selection set associated with that index.
The plugin is a bit rough around the edges like that.
- Global Moderator
- Name: thomthom
- License type: Pro
by massimo » Mon Jan 09, 2012 2:16 pm
Oh, I see. Thanks again.
massimo
- Global Moderator
- License type: Pro
by massimo » Mon Jan 09, 2012 2:21 pm
Another thing: it seems not working with selection window from left to right. Is that normal? Also not working with artisan's select brush.
massimo
- Global Moderator
- License type: Pro
by thomthom » Mon Jan 09, 2012 2:26 pm
massimo wrote:Another thing: it seems not working with selection window from left to right. Is that normal?
Seems to work here. SU8? As far as I've seen - it work with any selection. Not sure how Artisan's selection brush works. If it continuously updates the selection then it might cause unexpected behaviour - as the stack will the flushed very quickly. It works by using SketchUp's selection observer...
- Global Moderator
- Name: thomthom
- License type: Pro
by numerobis » Mon Jan 09, 2012 2:27 pm
WOW! This sounds great! I have to test it... thanks!!!
numerobis
- License type: Pro
by massimo » Mon Jan 09, 2012 2:30 pm
I have SU 7.1 and can confirm that here not works with left-->right selection while it works with right-->left selection.
massimo
- Global Moderator
- License type: Pro
by thomthom » Mon Jan 09, 2012 2:35 pm
massimo wrote:I have SU 7.1 and can confirm that here not works with left-->right selection while it works with right-->left selection.
Just tried it myself - I see no problems with Left to Right as oppose to Right to Left... Are you able to make a short video of what you see?
- Global Moderator
- Name: thomthom
- License type: Pro
by massimo » Mon Jan 09, 2012 2:41 pm
Ehm...I'm afraid not. Anyway this is what i do: - Draw a simple rectangle for example; - Select all (edges and face) with a left-->right window. - click anywhere to deselect; - run "cycle previous selection" and nothing happens. EDIT it's not working with right-->left selection either.
massimo
- Global Moderator
- License type: Pro
by thomthom » Mon Jan 09, 2012 2:47 pm
Ah - it's something to do with how it retrieves back the previous selections. What you are experiencing is probably that it retrieves an earlier selection set. Might be empty.
There is five slots of selection sets - always - even when you start a fresh model. Keep cycle through and it will come back. I'll have a look at it. But this plugin isn't on top of my priority list.
- Global Moderator
- Name: thomthom
- License type: Pro
by massimo » Mon Jan 09, 2012 2:50 pm
Ah! That's maybe the reason. Thought that with a fresh model the "memory" would have been deleted.
massimo
- Global Moderator
- License type: Pro
by thomthom » Mon Jan 09, 2012 2:52 pm
Well, it does - but there's a pre-reserved set of slots regardless. Which then are "filled" as you use it.
The plugin was written very quickly so unfortunately it has this behaviour which is illogical from a user point of view. :/
- Global Moderator
- Name: thomthom
- License type: Pro
by massimo » Mon Jan 09, 2012 3:02 pm
Ok, no problem.
massimo
- Global Moderator
- License type: Pro
by thomthom » Mon Jan 09, 2012 3:24 pm
Version 1.0.1 Did a quick tweak to it. I believe it should retrieve the previous selection more predictably now.
- Global Moderator
- Name: thomthom
- License type: Pro
by john2 » Mon Jan 09, 2012 4:24 pm
yeeeeeeeeeaaa
Google SketchUp Pro 8, Vray 1.49, Windows 7 – 32 bit
john2
- Name: John
by Ben Ritter » Mon Jan 09, 2012 6:42 pm
Sweet! Thank you so much, again.
Ben Ritter
by john2 » Tue Jan 10, 2012 7:50 am
thanks a llllot thomthom..great plugin. saves a lot of time during accidents
john2
- Name: John
by EarthMover » Wed Feb 22, 2012 3:01 am
Thanks bro for this great tool. I've always enjoyed having the selection in the undo stack with 3ds Max, now it's possible in sketchup as well! You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller Some of my 3D crap
EarthMover
- Top SketchUcator
- Name: Adam Hails
by thomthom » Wed Feb 22, 2012 9:20 am
EarthMover wrote:You deserve a chocolate fudge covered peanut butter chocolate chip cookie with oreo filling!
- Global Moderator
- Name: thomthom
- License type: Pro
by TomDC » Wed Feb 22, 2012 9:42 am
Thanks, Thom. Most useful.
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
TomDC
by halroach » Wed Feb 22, 2012 12:48 pm
Thanks Thom! You could add it to your already marvelous set of tools in 'selection toys'. That's it! I'm all out of keys on my keyboard for another shortcut for such a good tool. either I scrap some short cut I barely use, or I'll bump it up to them less used Shift+ and Ctrl+ shortcuts
halroach
- Name: Halroach
by VICTOR HUGO » Fri Sep 28, 2012 6:16 pm
Buenos Dias.
If I want to revert the "selection_stack size" to default which number would be; or by removing the plugin it will go back to default?
Thanks.
VICTOR HUGO
- Name: VICTOR
by thomthom » Sat Sep 29, 2012 1:45 am
If you reinstall then it would revert back, yes.
- Global Moderator
- Name: thomthom
- License type: Pro
Return to Plugins
