by mirale999 » Tue Dec 06, 2011 10:44 am
Hi all,I'm a newbie in ruby, although being here several years... I made a little plugin that lets you give a name upon adding a new scene~ Name : Named_Scene.rb # Date : v1.0 11/12/6 # Description : To Let you rename it upon adding a new scene # Menu Item : View -> Add Named Scene Still have a problem, I want that: when clicking the menu or hot key, give you a small inputbox, and write the name, and create, you can also not change the default name, and add the new scene as normal~ The default name of the new scene can increase each time, I made the "Scene_Num" to do it but everytime it is "scene 1".
Who can teach me how to?  Thanks Thomthom~! I've updated the attachment below! Now it works like this : Hit the hotkey or click the menu item, give you an inputbox, you can choose to give the new a unique name, Or leave it to its default and create like normal: Scene 1- Scene 2- Scene 3-... The first one define the new tab's name according to the number of existing pages: Named_Scene.rb Finally make the second one that do exactly the same thing as the normal scene tool, scene 1 - scene 2 - scene 3 - scene 4 - ... ignoring the number of existing pages, will not have any duplicate names! & Use the - Code: Select all
File::basename(__FILE__)
to ignore its own file name. Named_Scene2.rb - Code: Select all
# mirale999 first release, with Thomthom's help. # Permission to use, copy, modify, and distribute this software for # any purpose and without fee is hereby granted # Freely use # Name : Named_Scene.rb # Date : v1.0 11/12/6 # Description : To Let you rename it upon adding a new scene # Menu Item : View -> Add Named Scene
# It works like this : # Hit the hotkey or click the menu item, give you an inputbox, you can # choose to give the new a unique name, Or leave it to its default and # create like normal: Scene 1- Scene 2- Scene 3-... #----------------------------------------------------------------------------
require 'sketchup.rb'
module Named_Scene # Add menu items. unless file_loaded? File::basename(__FILE__) add_separator_to_menu("View") UI.menu("View").add_item("Add Named Scene") { self.add_namedScene } end
@@scene_i = 1
def self.add_namedScene model = Sketchup.active_model pages = model.pages
# Ask user for page name. list = [] prompts = ["Scene Name:"] defaults = ["Scene"+" "+"#{@@scene_i}" ] input = UI.inputbox( prompts, defaults, list, "Add Named Scene" )
# Check if the user cancelled. return if input==false
# Get data from result array scene_name = input @@scene_i = @@scene_i + 1
status = pages.add( scene_name.to_s ) end end
#----------------------------------------------------------------------------- file_loaded File::basename(__FILE__) #-----------------------------------------------------------------------------
paranoia is a higher form of awareness...
mirale999
by thomthom » Tue Dec 06, 2011 11:09 am
mirale999 wrote:Still have a problem, I want that: when clicking the menu or hot key, give you a small inputbox, and write the name, and create, you can also not change the default name, and add the new scene as normal~ The default name of the new scene can increase each time, I made the "Scene_Num" to do it but everytime it is "scene 1".
'Scene1'.next > Scene2
- Global Moderator
- Name: thomthom
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by thomthom » Tue Dec 06, 2011 11:16 am
Ah - looking at your code now: - Code: Select all
require 'sketchup.rb' Scene_Num=0
module Named_Scene unless file_loaded?('Named_Scene.rb') add_separator_to_menu("View") UI.menu("View").add_item("Add Named Scene") { self.Add_NamedScene } end def self.Add_NamedScene model = Sketchup.active_model pages = model.pages
list=[] prompts=["Scene Name:"] defaults=[("Scene"+ Scene_Num.to_s) ] input=UI.inputbox(prompts, defaults, list, "Add Named Scene" ) return if input==false scene_name = input
status = pages.add scene_name.to_s end Scene_Num=Scene_Num + 1 end
file_loaded('Named_Scene.rb')
Your Scene is a constant. But you are using it as a variable. You need to look into the difference between variables and constants. Initial capital letter means a constant in Ruby. Here's an amended version: - Code: Select all
module Named_Scene unless file_loaded?('Named_Scene.rb') add_separator_to_menu("View") UI.menu("View").add_item("Add Named Scene") { self.add_namedScene } end
list = [] prompts = ["Scene Name:"] defaults = [("Scene#{pages.count}") ] input = UI.inputbox( prompts, defaults, list, "Add Named Scene" )
scene_name = input
status = pages.add( scene_name ) end end
I make the default name of the scene be made out of the number of existing pages in the current model. If you do it your way, with instance variables instead of constants, then it would just keep on counting between models. I also cleaned up your indentation. Always keep your source code clean and organized, good indentation makes it easier to read - which is essential to debug and maintain your code.
- Global Moderator
- Name: thomthom
- License type: Pro
by mirale999 » Tue Dec 06, 2011 12:08 pm
thomthom wrote:Ah - looking at your code now:
Thanks Thomas~!! I use your code and now it's a correct version! And the Scene name is the very same as the normal one~
mirale999
by thomthom » Tue Dec 06, 2011 12:09 pm
But.... if you delete a scene or two you'll end up with duplicate names. So if you want to avoid that, then you need to make some extra checks.
- Global Moderator
- Name: thomthom
- License type: Pro
by mirale999 » Tue Dec 06, 2011 3:52 pm
thomthom wrote:But.... if you delete a scene or two you'll end up with duplicate names. So if you want to avoid that, then you need to make some extra checks.  Done!
mirale999
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp. Premium Members get 20% discount!
- Robot
Return to Plugins
