[Plugin]Hole on Solid tool v1.6.3 upadate Jan 09, 2012
Postby tak2hata » Mon Nov 28, 2011 4:30 pm
Hi,everyone.
This is tool for hole openning tool on solid.
#General disclaimer
#I MAKES NO GUARANTEE OF VALIDITY about this script.
#Please use this script at your own risk.
DONWLOAD:
Get the latest version from the PluginStore:
http://sketchucation.com/resources/plug ... e_on_solid
or AutoInstall from within SketchUp using the SketchUcation Tools
Update in Nov 29 ,2011:
Bug fix:I forgot erase line about "TSTcommon.langconv".
Update in Dec 02 ,2011:
Improved.work on Sketchup ver7( perhaps ver6).And create smooth subtracted faces from face include curve.
Update in Dec 03 ,2011:
Bugfix and small Improved.correct the hole shifted.
Update in Dec 14 ,2011:
Create hole from compoennt that has cut openning option.
Hole on unoccluded faces group(Tentative)
Update in Dec 16,2011
:Bugfix:It happened when select solid by component.
Update in Jan 03,2012
:Add new function,Punching multiple holes.
Modified Topics:Jan 05,2012.Title Did not correct. :)
Update in jan n09,2012.
Bug fix.The hole from polygon mades smoothed side faces. it's improved.
I found from dave's post,and irwanwr's message.Thanks.
This zip file includes "create_hole_on_solid.rb" and "icon_openning_lg.png".
Copy these files to "plugins" folder.
I created this tool for using with Building structure tool.http://forums.sketchucation.com/viewtopic.php?f=323&t=35798
But I think easy to use so It became independent tool.
Hole On Solid v1.6.2update 2012-01-03.
New fucntion video here.
http://youtu.be/vW3Ed2ch8L4
Please watch this video "how to use hole on solid tool"
http://youtu.be/Xgpw3IBuoqU
Where download My Building Smart Modeling tool for sketchup
Hole on Solid Tool
http://forums.sketchucation.com/viewtopic.php?f=323&t=41582
Solid quantify
http://forums.sketchucation.com/viewtopic.php?f=323&t=41120
WHD Parametric Component
Coming soon.
Thanks.
tak2hata
PluginStore Author
PluginStore Author
Re: [Plugin]Hole on Solid tool v1.0-Wed Nov 23, 2011
Postby Rich O Brien » Mon Nov 28, 2011 4:38 pm
:thumb:
Excellent tool thank you
Rich O Brien
Administrator
Postby Vicspa » Mon Nov 28, 2011 4:53 pm
YES, excellent tool, Thank you
Vicspa
Postby gilles » Mon Nov 28, 2011 6:45 pm
Trying to play with it I got this:
Error: #<NameError: uninitialized constant BST_HoleOnSolid::TST_common>
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in `reset'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:31:in `initialize'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:318:in `new'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/create_hole_on_solid.rb:37:in `call'
SU8 Mac 10.6.
gilles
Top SketchUcator
Postby Didier Bur » Mon Nov 28, 2011 9:18 pm
Does this tool "autoloads" when starting sU, since there is no rb file in the Plugins folder ?
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby utiler » Mon Nov 28, 2011 10:45 pm
Hi tak2hata, well done!!!! A good solution to an age old issue among SU'ers...
A few questions:
1. Does the 'profile' need to be a group?
2. Does the tool require a face or edges to create the hole in the resulting group? The reason why I ask is it would be good to extend this tool for edges to cut holes in groups [walls]. Say a window component is inserted; a nested group of edges could create the void in the wall and leave the window geometry.... not sure if this is possible.
:thumb:
utiler
Top SketchUcator
Postby mitcorb » Tue Nov 29, 2011 2:55 am
I like the way this tool rolls. Very effective in the video.
mitcorb
Top SketchUcator
Postby sadyo » Tue Nov 29, 2011 3:17 am
gilles wrote:Trying to play with it I got this:
SU8 Mac 10.6.
this happens to me anyway :?
SU Pro 8.0.4811, Win7/x64
sadyo
Postby Dave R » Tue Nov 29, 2011 3:29 am
Very interesting and useful plugin. It works very well. Thank you.
Global Moderator
Re: [Plugin]Hole on Solid tool v1.01 upadate Nov 29, 2011
Postby tak2hata » Tue Nov 29, 2011 4:25 am
Hi,Gilles and Sadyo.
I forgot fixing the problem.
It corrected in v1.01.
Didier Bur...Thanks for your advice.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby tak2hata » Tue Nov 29, 2011 4:31 am
utiler wrote:Hi tak2hata, well done!!!! A good solution to an age old issue among SU'ers...
A few questions:
:thumb:
Hi utiler.
Your second question is the direction of the this plugin's future.
1st question is No.
It need only face for hole.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby utiler » Tue Nov 29, 2011 4:54 am
FANTASTIC!!!!!! :berserk: :berserk: :sketchstatic: :sketchstatic:
utiler
Top SketchUcator
Postby gilles » Tue Nov 29, 2011 8:49 am
It works fine now.
Great job thank you. :thumb:
gilles
Top SketchUcator
Postby gilles » Tue Nov 29, 2011 9:24 am
Playing with it I notice that it does not detect hole in face, this could be a great improvement.
gilles
Top SketchUcator
Postby pilou » Tue Nov 29, 2011 12:50 pm
New concept of Boolean opérations! :fro:
Speedy Galerie
Top SketchUcator
Postby RichardCherry » Tue Nov 29, 2011 2:46 pm
Wow!
Fantastic tool. Thank you very much :)
RichardCherry
Postby sadyo » Tue Nov 29, 2011 3:01 pm
Great Thanks Tak2Hata, it working like a charm now :berserk:
sadyo
Postby utiler » Wed Nov 30, 2011 6:13 am
tak2hata wrote:Hi utiler.
1st question is No.
Tak2hata, another question:
When you create the whole in the solid it appear to expolde the profile shape; eg: circle / polygon.... Can you force the resulting edges to be hidden?
thanks mate!! :thumb:
utiler
Top SketchUcator
Postby mitcorb » Wed Nov 30, 2011 2:12 pm
Hi. I just tried to extract with Winzip eval version and got this in error output:
>>Extracting file: C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\HoleOnSolidTool_v1_01.zip
Extracting to "C:\Program Files (x86)\Google\Google Sketchup 7\Plugins\"
Use Path: yes Overlay Files: no
Unable to process "HoleOnSolidTool_v1_01\".
Severe Error: Not permitted or able to create an output directory.<<
Anyone have any ideas on this? Perhaps 7zip? Note that I am placing this in x86 where my Sketchup 7 version resides. Is this tool only for Sketchup 8?
mitcorb
Top SketchUcator
Postby RichardCherry » Wed Nov 30, 2011 2:16 pm
So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it :(
Thanks for the great plugin even though I am unable to use it.
RichardCherry
Postby Dave R » Wed Nov 30, 2011 2:25 pm
RichardCherry wrote:So this plugin only works with the "Pro" version? The free version does not have solids so I am unable to use it :(
How did you come to that conclusion? Looking through the thread it appears that other users of the free version of SketchUp have been using the plugin. The free version of SU doesn't have the Solid Tools but it still identifies solid groups and components.
Global Moderator
Postby RichardCherry » Wed Nov 30, 2011 2:35 pm
I tried the plugin with groups and components and it would not pick the solid feature. So I assumed it only worked with the pro solids.
RichardCherry
Postby Dave R » Wed Nov 30, 2011 3:27 pm
Post an example SKP file in which it doesn't work.
Global Moderator
Postby RichardCherry » Wed Nov 30, 2011 4:08 pm
Dave R wrote:Post an example SKP file in which it doesn't work.
Certainly. When I get home this evening I'll post an skp file. Any and all help is appreciated :)
Edit:
I figured out what I was doing wrong :)
You have to have the profile lined up with the solid in order for it to work. I had my profile off to the side. My mistake, sorry.
Gorgeous plugin.
RichardCherry
Postby boilingsnow » Wed Nov 30, 2011 9:36 pm
really powerful tool. thank you very much.
boilingsnow
Postby Dave R » Wed Nov 30, 2011 9:40 pm
RichardCherry wrote:Edit:
Gorgeous plugin.
Yep, that would do it.
Global Moderator
Postby mitcorb » Thu Dec 01, 2011 12:15 am
As a followup on my previous comment, I did manage to extract and copy drag from the Winzip UI into the plugins folder the two files .rb and icon. When I tested in Sketchup 7, selection would not progress beyond the prompt for the first object/ group which was simply a cubic form made into a group and a circle oriented appropriately. Previously, in XP, I could right click on the zip file already in place in the plugins folder, "extract to here" and see the files deployed appropriately. Any thoughts on what I have managed to miss in the provided info?
mitcorb
Top SketchUcator
Postby tak2hata » Thu Dec 01, 2011 4:53 am
mitcorb wrote:As a followup on my previous comment, I did manage to extract and copy drag from the Winzip UI into the plugins folder the two files .rb and icon. When I tested in Sketchup 7, selection would not progress beyond the prompt for the first object/ group which was simply a cubic form made into a group and a circle oriented appropriately. Previously, in XP, I could right click on the zip file already in place in the plugins folder, "extract to here" and see the files deployed appropriately. Any thoughts on what I have managed to miss in the provided info?
Hi mitcorb.
This plugin use property of volume.
Sketchup supports solid in later version of 8.
As matter of fact,I think this script may work ,when it judges the Group(Component) is solid.
I must create the method of that judgment for that purpose.
I inquire later.
Thanks.
by TAK2HATA
tak2hata
PluginStore Author
PluginStore Author
Postby mitcorb » Thu Dec 01, 2011 2:56 pm
Hi,tak2hata:
Here is the Ruby Console error message:
Error: #<NoMethodError: undefined method `volume' for #<Sketchup::Group:0xa789048>>
C:/Program Files (x86)/Google/Google Sketchup 7/Plugins/create_hole_on_solid.rb:298:in `onLButtonDown'
I see your demo suggests that only available in Sketchup version 8 by the fact that the default component in the demo is Susan. Yet your user profile says you use Vista and Sketchup V7. Perhaps in your first post, mention that this is for V8 only?
mitcorb
Top SketchUcator
Postby thomthom » Thu Dec 01, 2011 2:59 pm
mitcorb wrote:Hi,tak2hata:
I'm guessing you are not using SketchUp 8 - group.volume is a method available since SU8 when SU introduced solids.
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: metallicatz16, tparkertom and 4 guests
