[plugin] Clip or Trim Terrain Mesh (Update)
Postby sdmitch » Wed Oct 12, 2011 8:02 pm
http://forums.sketchucation.com/viewtopic.php?f=323&t=40555
When you grab several Google Earth Terrain patches, there is often a problem with how the images overlay each other. To help with this problem, the attached plugin, Clip or Trim Terrain Mesh, allows you to select the mesh which you want to keep and the mesh to be trimmed. Everything from the 2nd mesh that falls within the boundary of the 1st mesh is deleted thus eliminating the problem.
In cases where smaller high resolution meshes are placed on top of larger low resolution meshes, you will often be left with vertical gaps especially in areas with significant elevation change due to the differences in the resolution of the grid and the interpolation of the surface.
Another cause of image mis-match are the border rows and columns even when the terrain patches are of the same scale. To help with this problem, use the Trim option of Clip or Trim Terrain Mesh, to remove them from the selected mesh. Press and release the Shift Key to toggle between clipping and trimming. Hopefully now Mac compatible.
Add Terrain Skirt, adds a skirt to the terrain mesh to give depth and definition to the mesh.
4
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Re: [plugin] Clip Terrain Mesh
Postby Bob James » Wed Oct 12, 2011 10:41 pm
Super!! Thank you sdmitch :thumb:
Bob James
Premium Member
Premium Member
Postby srx » Thu Oct 13, 2011 10:27 am
Great. Thanks Sam.
www.saurus.rs
srx
Postby Panga » Thu Oct 13, 2011 3:34 pm
Thanks for this one Sam !! :thumb:
Panga
Premium Member
Premium Member
Postby driven » Thu Oct 13, 2011 5:26 pm
Love the combo tool,
once I got my head around it EDIT removed potentially misleading comment...
and I found a use for it for me as well. 3D cycle route maps...
anyone got an easy way of using Google Maps as the terrain texture,
this ones manually scaled and aligned with the 'Google Earth Snapshot' then applied as a projected texture onto the Terrain Grid.
Google if your reading, can we have a map option? please...
good work Sam
john
driven
PluginStore Author
PluginStore Author
Postby sdmitch » Thu Oct 13, 2011 6:45 pm
John, You should press and release the Shift key to toggle between clip and trim. Holding down the shift key is not required or advised.
sdmitch
PluginStore Author
PluginStore Author
Postby driven » Thu Oct 13, 2011 6:49 pm
Sam,
doesn't toggle on a mac, I should have pointed that out. EDIT INCORRECT you DON'T need to keep it held down
that's what was doing my head in I checked your code and couldn't see why it wouldn't work, so I guess it's a Mac thing...
john
driven
PluginStore Author
PluginStore Author
Postby driven » Thu Oct 13, 2011 6:52 pm
removed
driven
PluginStore Author
PluginStore Author
Postby sdmitch » Thu Oct 13, 2011 7:03 pm
I wasn't aware of that difference with Macs since I only have windows at my disposal.
sdmitch
PluginStore Author
PluginStore Author
Postby driven » Thu Oct 13, 2011 7:11 pm
No, me neither, I had a search for mac key-codes etc,,, but I might try searching mac 'toggle' as keycode 16 seems to work.
EDIT 16 on it's own dosen't work on mac [I'd left the other in, but opened a copy when checking, what I'd done... sorry]
driven
PluginStore Author
PluginStore Author
Postby AcesHigh » Thu Oct 13, 2011 7:38 pm
great plugin! Thanks a lot!
AcesHigh
Postby thomthom » Thu Oct 13, 2011 8:14 pm
sdmitch wrote:I wasn't aware of that difference with Macs since I only have windows at my disposal.
Don't use VK_ALT, VK_SHIFT etc - for cross platform, use
CONSTRAIN_MODIFIER_KEY = Shift Key
CONSTRAIN_MODIFIER_MASK = Shift Key
COPY_MODIFIER_KEY = Menu on Mac, Ctrl on PC
COPY_MODIFIER_MASK = Alt on Mac, Ctrl on PC
ALT_MODIFIER_KEY = Command on Mac, Menu on PC
ALT_MODIFIER_MASK = Command on Mac, Alt on PC
http://code.google.com/intl/no/apis/ske ... /tool.html (top of this page)
Also - when I use these, I don't try to make Shift or Control match across platforms. Because as you can see from the constant names, the modifier key to make a copy (when you use the Move tool for instance) differ from platform to platform. So just use these to match the norm for each platform.
PluginStore Author
PluginStore Author
Postby sdmitch » Thu Oct 13, 2011 9:29 pm
Thanks ThomThom, I'm still learning and need all the help I can get.
sdmitch
PluginStore Author
PluginStore Author
Postby thomthom » Thu Oct 13, 2011 9:37 pm
No prob! Always good to see more people writing plugins. :)
PluginStore Author
PluginStore Author
Postby driven » Thu Oct 13, 2011 10:28 pm
Sam,
re: 'Clip or Trim' on MAC,
I just went over it all again and on the mac using if key ==16 || 131072 #shift PC || MAC,
makes it work as I believe you intended. [ is it?]
To start in 'Trim' mode:
'grab' grid/s >> select the 'Clip or Trim' from plugins >> press shift key once to activate 'Trim' >> click on 'Terrain' to 'Trim' grid/s in turn.
To start in 'Clip' mode:
'grab' grid/s >> select the 'Clip or Trim' from plugins >>click on 'Terrain' to 'Clip' grid/s in turn.
To switch between modes from either mode, press shift key once >> click on next 'Terrain'
To exit 'Clip or Trim' click outside of all 'Terrain' groups.
This is how it work with that change, I edited my above posts avoid to blind copying of my erroneous prior comments.
I believe this tweak is cross platform, due to the none applicable keycode being ignored, but I don't have a PC easily at hand.
Sorry if any confusion [other than my own] was caused by earlier comments, but I was in and out today without the time to plod through it properly.
john
driven
PluginStore Author
PluginStore Author
Re: [plugin] Clip or Trim Terrain Mesh (Update)
Postby mitcorb » Fri Oct 14, 2011 3:20 am
Hi, sdmitch:
Thank you for your generousity in sharing this tool.
mitcorb
Top SketchUcator
Postby utiler » Tue Dec 13, 2011 2:26 am
Hi Sam, On your blog you have added an impressive list of plugins including these two however there is also a 'terrain tool's plugin that doesn't have a tutorial video. How does this differ from these two listed here?
cheers, thanks for your fantastic work!! :thumb:
utiler
Top SketchUcator
Postby sdmitch » Tue Dec 13, 2011 3:01 am
Terrain Tools is just the collection of all my plugins that pertain to GE Terrain's. Clip or Trim being one of them plus two others. There are no other differences. I just put them all into one to help minimize the entries in the Plugins menu.
sdmitch
PluginStore Author
PluginStore Author
Postby utiler » Tue Dec 13, 2011 3:23 am
Ok, thanks Sam.Just on GE:
I noticed in your Clip or Trim tutorial you merge two terrains of differing proxy. Does GE determine the resolution of your export into SU by your current eye high as well as the maximum resolution you end up with?
I have a situation at the moment where I want to obtain the maximum resolution of of GE however my site covers about 3 hectares and I need to cover it with a GE image.
I wonder if there is a way recall you last selection when exporting GE imagery or even replicate your selection left and right multiplied by how far you want? [See image below...]
Cheers,
utiler
Top SketchUcator
Postby sdmitch » Tue Dec 13, 2011 3:41 am
Thers is no way to "automate" that that I am aware of.
sdmitch
PluginStore Author
PluginStore Author
Postby dinkdesign » Mon Apr 09, 2012 7:28 am
You guys are absolute legends. You take modeling to a whole new level.
I was hesitant to join SketchUcation because i hate useless info, but honestly: you guys rock!
Special thanx to Gaieus and ThomThom for their constant useful contributions.
dinkdesign
Postby Gaieus » Mon Apr 09, 2012 7:43 am
dinkdesign wrote:Special thanx to Gaieus and ThomThom for their constant useful contributions.
Well, I really had to approve this post (even though I have not contributed with anything in this topic). ;)
Postby Ben Ritter » Wed Jun 13, 2012 7:43 pm
Sam, thank you for sharing your efforts.
Ben Ritter
Postby utiler » Sun Sep 23, 2012 11:23 pm
Hi Sam, during your tutorial video at about 1:20 you say, 'If its only zoomed out 3 or 4 clicks....'
What are you referring too here?
:thumb:
utiler
Top SketchUcator
Postby sdmitch » Mon Sep 24, 2012 12:01 am
I viewed the tutorial and I don't hear what you heard but I would assume that I am referring to zooming out from the smallest possible patch 3 or 4 clicks.
sdmitch
PluginStore Author
PluginStore Author
Postby utiler » Mon Sep 24, 2012 4:02 am
Thanks for the reply, Sam.
http://www.youtube.com/watch?v=RP9ZR2xB ... e=youtu.be
At about 1min 20sec you refer to 'if its only zoomed out 3 or 4 clicks [no more than that] the grid of the two patches match....'
Are you referring to zooming in Google Earth:
:thumb:
utiler
Top SketchUcator
Postby sdmitch » Mon Sep 24, 2012 7:49 pm
Yes, the Google Earth get location zoom. I thought you were talking about the clip and trim plugin not the add skirt.
sdmitch
PluginStore Author
PluginStore Author
Postby utiler » Mon Sep 24, 2012 11:11 pm
My bad, Sam. I can see how you would have been ill informed.... :oops:
Thank you. :thumb:
utiler
Top SketchUcator
Postby greatcurve » Wed Dec 26, 2012 5:08 pm
Is there a way to make these plugins work with SU 8?
greatcurve
Postby thomthom » Wed Dec 26, 2012 5:27 pm
greatcurve wrote:Is there a way to make these plugins work with SU 8?
Are you getting errors?
The author uses SU8 - as his profile says - and usually if a plugin doesn't work with a version it's explicitly stated in the plugin description. I believe this should work with SU8.
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: GauthierDk, ivoadriel, naser712, spiteo25, vmask and 12 guests
