[Plugin] Drape Materials v1.0 20111003
Postby TIG » Mon Oct 03, 2011 4:15 pm
Copyright 2011, TIG (c)
Permission to use, copy, modify, and distribute this software for any
purpose, and currently without fee, is hereby granted, provided that
this text and the above copyright (c) notice appear in all copies.
This software is provided "as is" and without any express or implied
warranties, including, without limitation, the implied warranties of
merchantability and fitness for a particular purpose.
Menu: 'Plugins' > 'Drape Materials'
OR
Ruby-Console/Code: TIG-drapematerials
Usage:
This tool is designed to drape the materials from the faces you have used
to drape a 'cutout' onto a surface.
First use the Sandbox Tool > Drape to drape the faces onto the surface...
OR EEbyVectorToObject Tool to extrude the faces' edges onto the surface,
then erase unwanted geometry and explode the group to intersect with the
surface.
Preselect the surface's faces that now include the 'cutout' areas - you
need not be too careful as things other than faces in the selection are
ignored & surface-faces not immediately below the upper faces are ignored.
Activate the Tool and the materials from the upper faces are reproduced on
the cutout faces on the surface.
It is one step undoable.
Donations: PayPal.com to info @ revitrev.org
Version:
1.0 20111003 First issue.
TIG-drapematerials.rb
Global Moderator
Re: [Plugin] Drape Materials v1.0 20111003
Postby wyatt » Mon Oct 03, 2011 4:39 pm
This is great! Thank you, TIG.
wyatt
Postby thomthom » Mon Oct 03, 2011 6:38 pm
Ah yes! I've wanted this!
PluginStore Author
PluginStore Author
Postby Dave R » Mon Oct 03, 2011 7:44 pm
Excellent plugin. I broke it already. :D
Actually, I think Drape failed and not the plugin.
231.skp
Global Moderator
Postby TIG » Mon Oct 03, 2011 8:55 pm
Try EEbyVectorToObject for an alternative way of making the 'drape'...
That might work better.
Also please make sure that the objects' size are reasonable - I had to introduce a size limit for checking faces so can you try scaling up and see if that helps... for now...
I plan to look at 'SuperDrape' tomorrow... where it will do the whole draping thing like Sandbox Tools - BUT keeping the draped surface's materials on the drapee surface... watch this space...
Global Moderator
Postby TIG » Tue Oct 04, 2011 5:00 pm
My new 'Super Drape' - that drapes one group onto another, and repeats the materials and texture UVs - is almost ready to publish - watch the forums tonight... Just debugging it... :geek:
Global Moderator
Postby jolran » Tue Oct 04, 2011 5:18 pm
A new hatch tool :o
Ahh, It's for surfaces..
Looks sweet!
jolran
PluginStore Author
PluginStore Author
Postby TIG » Tue Oct 04, 2011 9:58 pm
SuperDrape is here and somewhat makes this tool redundant viewtopic.php?p=358314#p358314
Global Moderator
Postby wq418 » Wed Oct 05, 2011 11:45 am
great!!!!
it's awesome
wq418
Return to Plugins
Users browsing this forum: vietsketch and 16 guests
