[Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
Postby fredo6 » Sun Sep 11, 2011 12:40 pm
ReportLabelArea is a standalone script which provides several services about Areas:
  • Reporting: Compute and display the area of the selection or the whole model, by materials, by components and groups, and by layers. Display is done in a Web dialog box, with possibility to print and Export in CSV format.
  • Browsing: Indicate the Area of faces, components and groups by mouse-over in the model
  • Labelling: Create and Edit text labels with Areas
For all functions, there is a choice of Area formatting (unit and decimal), regardless of the default unit of the model.
This follows a request by vanderlm.
ReportLabelArea is now installed as part of FredoTools.
See the main post for FredoTools for Installation
No user manual (see section Quick Start and Videos below)
  • Language: English, French
  • Menus: by default, it is installed in Tools > FredoTools with 2 submenus: Report on Areas and Label with Areas. It also appears in the Contextual menu when there is at least one face in the current selection
  • Icon toolbar: Fredo6 Tools. By default, the 2 icons are not shown
  • The plugin is free, for private and commercial usage.
Reporting on Areas
Browsing for Areas and Labelling
Reporting on Areas
  • Call the Plugin on the selection (main menu or contextual menu “Report on Areas”). If there is no selection, ReportArea will operate on the whole model
  • A web dialog box appears showing the report
  • You can change the formatting of areas, unit and number of decimals
  • Report is available by Material, by Layer and by Container
  • You can print the report and export it as a CSV file
Browsing the model for Areas
The best is to follow the video
  • Call the menu “Label with Areas”).
  • Mouse over the model to display the area of faces, groups and components. You have several options, like "select single face, as opposed to surface", "select compoents / groups recursively or not"
  • You can change the formatting of areas, unit and number of decimals at any time
  • If you click on elements, they are stored in a temporary selection and the total area of the elements selected is displayed in the top dialog box
Creating and Editing Labels with Areas
  • On a face or Container, Click and Drag to create and position a new label
  • You can drag the text of the label around
  • You can also move the anchor (mouse over it, a small yellow circle appears, click and drag)
  • to change the formatting of the label, change the unit / decimal in the dialog box and click on the label to update it
  • to Edit the text, double-click on the label
ReportArea 3.2a - 05 Feb 20: includes material coming from object painting, when the material on faces is the default material.
ReportArea 3.1e - 02 Nov 19: Refresh buttons, more options for Export, cosmetic adjustments and bug fixing
ReportArea 3.0a - 16 Oct 19: This release introduces a new view / report called Outliner
ReportArea 2.1b - 11 Nov 17: This release fixes a bug in ReportLabelArea when exporting CSV in non-English language
ReportArea 2.1a - 09 Jul 15: This release fixes a major bug. Now the calculated area takes into account the glued component in Cut opening mode.
ReportArea 2.0a - 19 Dec 11: This release includes a Reporting with a Web dialog, by Material, by Layer and by Container. It also includes the Browsing and Labelling features.
ReportArea 1.1a - 11 Sep 11: initial public release
3
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin] ReportArea - v1.1a - 11 Sep 11
Postby srx » Sun Sep 11, 2011 1:44 pm
www.saurus.rs
srx
Postby Panga » Mon Sep 12, 2011 10:27 am
Thanks a lot for this one Fredo !! Really usefull for me. :thumb: :thumb:
Panga
Premium Member
Premium Member
Postby baldaman » Fri Sep 23, 2011 12:41 pm
Thanks FREDO!
Would it be difficult to add "by layer"?
baldaman
Postby Ben Ritter » Fri Sep 23, 2011 5:52 pm
Thank you.
Ben Ritter
Postby fredo6 » Sat Sep 24, 2011 8:27 pm
baldaman wrote:Thanks FREDO!
Do you mean
- compute total area by layer?
- For each layer, gives the details by Material and by container?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby baldaman » Sun Sep 25, 2011 9:01 am
I mean compute total area by layer.
I explain: I am doing a big project. I put each floor's top face on adifferent layer corresponding to the affectation of the floor (for exemple: exhibition, administration, library etc...). Each time I want to check the total area of library's floor for exemple, I select one face, right click, and go into context menu and choose "by layer" to have the sum of all areas of library's floors top faces. I do that 40 times a day.
I think that if we can make a report of all areas of these faces we can produce an automated area table for elements of program.
Of course it could be done with materials, but we often want to give the same material to all the floors. The differenciation comes with layers.
Switching to "color by layer" mode gives a more analytical vision.
"color by layer mode" = analytical, programmatic
"textured mode" = realistic, rendering.
Sorry for my frenglish.
baldaman
Postby Chris Fullmer » Wed Oct 05, 2011 1:53 am
Hmm, I just wrote a very simple version of this for myself today. I should have looked here first. oops! Thanks for the script Fredo,
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: [Plugin] FredoTools::ReportLabelArea - v2.0a - 19 Dec 11
Postby fredo6 » Tue Dec 20, 2011 7:29 pm
NEW RELEASE: ReportLabelArea 2.0a - 19 Dec 11
ReportLabelArea is a rework of the previous ReportArea standalone plugin. It provides:
  • More visual features for Reporting and Browsing for Areas
  • Creation, update and Edition of labels with Areas
  • Area formatting (choice of unit and decimals) for all functions
There are two videos to give an idea of the main features of the plugin
ReportLabelArea is now published as part of the FredoTools suite of Plugins
See main post of this thread for more information.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mitcorb » Tue Dec 20, 2011 7:33 pm
Thank you, Fredo6:
An excellent concept. :thumb: :thumb:
mitcorb
Top SketchUcator
Postby boilingsnow » Wed Dec 21, 2011 8:24 am
Fredo is generous.
Thank you.
boilingsnow
Postby boilingsnow » Wed Dec 21, 2011 10:21 am
Could you make them separate to install?
boilingsnow
Postby fredo6 » Wed Dec 21, 2011 10:38 am
boilingsnow wrote:Could you make them separate to install?
What do you mean?
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby tak2hata » Wed Dec 21, 2011 11:33 am
This is nice tool!
Thanks FREDO! :ecstatic:
tak2hata
PluginStore Author
PluginStore Author
Postby boilingsnow » Wed Dec 21, 2011 12:50 pm
What do you mean?
Fredo
I mean you are providing a set of tools and I have to install them all at one time. But I have already installed some of them and made my own icons for them.
Actually I am using sutool of Wikii as a manager of all my plugins. And this set of combined tools doesn't support that.
I konw I can also control display of the icons through your LibFredo6, but it would still be wonderful if you could continue providing these tools als seperate plugins at the same time.
boilingsnow
Postby fredo6 » Wed Dec 21, 2011 6:17 pm
boilingsnow wrote:Actually I am using sutool of Wikii as a manager of all my plugins. And this set of combined tools doesn't support that.
I understand.
I am not a user of Wikii's SUTool. Can you tell me how you bind the icon / command to the Plugin.
I can try to offer an interface which is compliant so that you keep seeing the plugins as standalone.
Fredo
PS: I regrouped the plugins to minimize the footprint in SU, (i.e. have a single menu item). I also provides a Quick Launcher.
fredo6
PluginStore Author
PluginStore Author
Postby boilingsnow » Sat Dec 24, 2011 6:56 am
I understand.
Fredo
Thank you very much for your answer.
boilingsnow
Postby I.Aleks.S » Sat Dec 24, 2011 12:36 pm
Fredo6 wrote:[size=150]NEW RELEASE: [color=#400000]ReportLabelArea 2.0a - 19 Dec 11....
[/bFredo
Hello [b]Fredo6.
Forgive for my bad English.
I use many yours Plugins. I give an appreciation on these workings out.
I address to you with the request, to make calculation function on length;
Millimetres running
Centimetres running
Metres running.
Probably to execute it?
I thank you.
I.Aleks.S
Postby jorge2011 » Mon Jan 02, 2012 3:04 am
fredo excellent tool. thank you very much.
A query. You can add a tool to measure length of vectors, curves, polylines etc ...?
jorge2011
Postby cyb » Fri Jan 06, 2012 4:00 pm
Fredo. Great Tool.
One question. The sorting is by either Material or by Layer.
Any chance to add By Layer then by Material?
Something like this?
Layer1
Material 1
Material 2
Material 3
Layer2
Material 1
Material 2
Material 3
Regards.
cyb
Postby castaway » Tue Mar 20, 2012 1:19 pm
Fredo6 wrote:NEW RELEASE: ReportLabelArea 2.0a - 19 Dec 11
Fredo
Is there any way to automatically update existing labels if the area has changed? I could not find a way to do so, but perhaps I am missing something
Thanks for such an amazing plugin btw.
castaway
Postby fredo6 » Tue Mar 20, 2012 10:16 pm
castaway wrote:Is there any way to automatically update existing labels if the area has changed? I could not find a way to do so, but perhaps I am missing something
I thought about it and there is a way. I hesitated because it obliges to store some information as attribute of faces and use an observer (notably not very stable in Sketchup). This latter issue made me hesitate as the plugin could have bad side-effects even if you do not use it at all.
One possibility is that I introduce a "refresh" option to update all labels. Maybe I'll do it in a next release.
Thanks for the suggestion
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby castaway » Wed Mar 21, 2012 9:09 am
You are most welcome. A refresh button but be ideal in my opinion.
I never expected the labels to be updated automatically anyway since that would probably have a negative impact on performance (just wild gessing).
castaway
Postby creaform » Tue Sep 18, 2012 8:19 pm
Once again we thank you Fredo,
for what you bring to the community of SketchUp that is unique.
From France
creaform
Postby caronte01 » Thu Dec 20, 2012 4:38 pm
Hi Fredo,
I downloaded this tool as part of Fredo6 tools pack. Makes Sketchup one of the most useful tools for architectural design. I constantly use it to report areas and update area schedules of projects. I now use sketchup as a 2d tool more and more. Bye autocad!!!
Thanks a lot!!!
caronte01
Postby fredo6 » Thu Dec 20, 2012 9:06 pm
caronte01 wrote:Hi Fredo,
Thanks a lot!!!
Thanks for the comment. If you think there is additional functionality that could be useful, do not hesitate. This is not an area where I am myself familiar.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby vapross » Tue Jan 08, 2013 7:48 pm
Hello, guys.
Finally I've a first post.
Fredo, thanks a lot for your tooling! It really helps!
My question is on exReportArea principle, that I'd like to turn to my needs. I used ReportArea (now ReportLabelArea) for the interior design. It works great. And I just checked this new one.
I'm not a Ruby pro, and maybe you should send me to the Ruby forum section. Now I'd like use SU as a mass-modeling tool, and it seems to me there's no simple plugin to do it (if there is one, please, post a link!). Revit or ArchiCAD methods sometimes are a bit clumsy in mass-modeling. And the cost isn't nice for a such simple task.
What I'd like to get a data structure in csv from SU model is as follows:
- group
-- name
-- material area (e.g. 3 mats = 3 area values)
-- layer
-- volume
-- etc
The data structure appears to be an hierarchical one, because I'd like to get the parameters of each group/component from my model. Materials and naming are the core of the way of information mgmt I use within SU.
Almost the same for a Component. Actually if I get a long unformatted list of data, I could sort it in Excel.
Now I have no idea which code pattern to use -could you guide here? Any advices, links? I bought last week a brand-new book by Alex Schreyer, but it didn't help me.
Thanks in advance!
SketchUp 2015 Pro
vapross
Postby brookefox » Sun Feb 24, 2013 9:25 pm
Just a note of thanks, Fredo, for a typically powerful multifaceted, super-documented and pleasing to behold tool-set. If I could master your tools alone, I would consider that quite a worthwhile accomplishment.
~ Brooke
brookefox
Postby fredo6 » Sun Feb 24, 2013 9:51 pm
brookefox wrote:Just a note of thanks, Fredo, for a typically powerful multifaceted, super-documented and pleasing to behold tool-set. If I could master your tools alone, I would consider that quite a worthwhile accomplishment.
Thanks very much for the encouraging appreciation. This one came from a user request some time ago. It's a little bit complex because there are many options and situations where only the user can decide (like selecting a face, a surface or a component). So I have to leave the options open and provide some documentation.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby JQL » Thu May 02, 2013 2:24 pm
Hello everyone,
I was trying to generate my first report on areas from a project I have and I came across this question.
Is it possible to report the area of a face minus the hole cutting component's areas attached to the face?
The entity info window reports them but I didn't find a way to do that on this tool.
Thank you fredo for all the unbelieveable tools... box stretching... perfect!
JQL
Premium Member
Premium Member
Next
Return to Plugins
Users browsing this forum: filipecadu, gjmm, Kferli13 and 8 guests
