[Plugin] ClineStyler v1.0 20110822
Postby TIG » Mon Aug 22, 2011 10:02 am
(c) TIG 2011
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Script:
clinestyler.rb
Place it in the ../Plugins/ folder and restart Sketchup...
Usage:
If a selection includes Guide-Lines [clines] then there is a right-click
context-menu item called 'ClineStyle...', which opens a drop-down list of
possible cline-styles - choose one and those selected will now display in
that style; you can revert to the default, which is also the '_' style but
its code is 0 rather than 61680.
Donations:
by PayPal to info @ revitrev.org
Version:
1.0 20110822 First Release.
clinestyler.rb
Global Moderator
Re: [Plugin] ClineStyler v1.0 20110822
Postby srx » Mon Aug 22, 2011 11:43 am
Thank you TIG. :)
www.saurus.rs
srx
Postby Rich O Brien » Mon Aug 22, 2011 12:05 pm
8 downloads and 1 thank you. :(
Anyway, thank you again for this. Nifty tool :thumb:
Rich O Brien
Administrator
Postby 3dsmax9 » Mon Aug 22, 2011 12:15 pm
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
Thank's TIG :)
8 download = 8 Thank's TIG :)
3dsmax9
Postby schnydix » Tue Aug 23, 2011 12:34 am
Thanks Tig but with my screen resolution i cant see the difference
It is possible to make the Clines into Lines (for Printing)and stronger than 1Pixel
An realy working dashed line tool would be very nice.
And a Big Big Thank you for spending so much time in programming for us stupid users
Google and sketchup special programmers like you and all other great guys here are like
little Robin hoods for me. You gife as a tool that is much better and faster than very expensive
Programms. :thumb:
schnydix
Postby utiler » Tue Aug 23, 2011 3:57 am
Rich O'Brien wrote:8 downloads and 1 thank you. :(
oops.... :oops: was directed here from another post and should have :thumb:
so here it is again, TIG. :thumb: :thumb:
utiler
Top SketchUcator
Postby TIG » Tue Aug 23, 2011 10:02 am
schnydix wrote:Thanks Tig but with my screen resolution i cant see the difference
little Robin hoods for me. You gife as a tool that is much better and faster than very expensive Programs. :thumb:
I can't fix your screen resolution!
As long as Clines are not infinitely long you can use my tool 'xLine2Line.rb'
http://forums.sketchucation.com/viewtop ... 67#p274567
which converts selected lines to plain-lines.
Then you could use the LineStyle tool in my 2Dtools
http://forums.sketchucation.com/viewtop ... 60#p185760
to give the line a color/width/dot-dash pattern - remember that then it's no longer a 'line' so snapping etc is no longer possible. The ideas of this ClineStyler is to allow you to change the appearance of selected clines for ease of identification - e.g. center _._._._ instead of ----- ; it's not intended for presentation line styles - where Layout or 2Dtools come in...
Global Moderator
Postby schnydix » Tue Aug 23, 2011 11:25 am
Thanks Tiger fast and helpfull answer.
and yes i see there is a concept behind your works.
Respect from Switzerland
schnydix
Postby seven.sides » Wed Aug 24, 2011 2:24 pm
Thanks TIG. This should be useful for presenting architectural drawings.
seven.sides
Postby matt.gordon320 » Fri Dec 28, 2012 6:02 pm
Thanks TIG!
matt.gordon320
Premium Member
Premium Member
Postby huija » Sun Mar 15, 2015 3:00 pm
thanks TIG!
huija
Postby Titan1286 » Mon Mar 27, 2017 3:31 pm
TIG - Thanks!
Titan1286
Postby pilou » Mon Mar 27, 2017 9:23 pm
Does this the same than Construction Line Styler ? by Tig
Speedy Galerie
Top SketchUcator
Return to Plugins
Users browsing this forum: koi14 and 8 guests
