[Plugin] Simple Scale Tool Handles v1.2 7-25-2011
Postby kyyu » Thu Jul 21, 2011 10:40 pm
By request, a plugin to make it easier to use the scale tool, on thin sheet parts. Component/group definitions have a property that hides the handles. When the scale tool is used on a modified component/group, the drag handles are reduces from the normal 26 to only 10.
Newest is version 1.2
v1.0 (7-21-2011) initial version
v1.1 (7-23-2011) added Toolbar
v1.2 (7-25-2011) Toolbar now processes selection, with option to only process all.
Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided this notice appears in any copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Author: kyyu (7-25-2011) v1.2
Description: This plugin makes it easier to use the scale tool, on thin sheet parts. When the scale tool is used on a modified component/group, the drag handles are reduces from the normal 26 to only 10. Tested on SU8, and also seems to work with SU7.
Activated from (Plugins menu "[ky] Simple Scale Handles") or (Toolbar). If nothing is selected, than all active groups/components are processed. Toolbar icons are depressed, as a visual indicator when all comp/groups are proccessed. Depressed icons can still be clicked, for example to process a selection. There is an option below, for the toolbar to ignore selection.
Options: There are 3 vaiables at the beginning of the script, whos value can be changed to customize the plugin.
[menu = true] -load "Plugins Menu item"
[toolbar = true] -load Toolbar
[@toolbar_all = false] -if true, Toolbar will ignore selection, and only process all active comp/groups.
Tip: You need to have the z axis, of group/component, aligned with the thickness of the sheet.
simple scale handles_v1.2.zip
kyyu
Re: [Plugin] Simple Scale Tool Handles 7-21-2011
Postby rv1974 » Fri Jul 22, 2011 5:48 am
Oh I'm so tired with the default one. Huge thank you!!!
rv1974
Postby Krisidious » Fri Jul 22, 2011 6:00 am
are you saying this flattens stuff?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby derei » Fri Jul 22, 2011 6:35 am
Simple and Awesome. some things should be by default in SU
DESIGNER AND ARTIST DEREI.UK
derei
Postby ken » Fri Jul 22, 2011 10:58 am
This is nice plugin and needed by me since I work in large size 1/4" thick steel plate. I have added a icon and now trying to make the selection of the icon a toggle, Simple to Default and back.
Thanks for your work
Ken
ken
Premium Member
Premium Member
Postby TIG » Fri Jul 22, 2011 12:22 pm
A very simple yet very clever new tool. :geek:
Which shows us that there are still many new or alternative ideas that can be realized without thousands of lines of code... :D
Global Moderator
Postby jolran » Fri Jul 22, 2011 12:27 pm
Great tool Kyyu! Thanks.
jolran
PluginStore Author
PluginStore Author
Postby thomthom » Fri Jul 22, 2011 12:47 pm
Might want to wrap that up on a start/commit operation so it can be undone in one go.
PluginStore Author
PluginStore Author
Postby Ben Ritter » Fri Jul 22, 2011 1:49 pm
Thank you very much.
Ben Ritter
Postby kyyu » Fri Jul 22, 2011 10:18 pm
Krisidious wrote:are you saying this flattens stuff?
No, it changes the apperance of the skechup native scale tool. The right part in the image shows the change.
kyyu
Postby kyyu » Fri Jul 22, 2011 10:27 pm
thomthom wrote:Might want to wrap that up on a start/commit operation so it can be undone in one go.
I had the start/commit operation in there originally, but no undo was created? So I removed it. Any other benifit of having it in there?
kyyu
Postby Jim » Fri Jul 22, 2011 10:29 pm
Very handy. Thanks.
Jim
Global Moderator
Postby TIG » Sat Jul 23, 2011 10:51 am
kyyu
I see what you mean - it seems that the resetting of the scale-handles happens outside of the undo stack ? The definition.behavior.no_scale_mask= seems weird in this respect ? Fortunately you have a simple reset to 'all' in your dialog choices... :?
Global Moderator
Re: [Plugin] Simple Scale Tool Handles v1.1 7-23-2011
Postby kyyu » Sat Jul 23, 2011 5:46 pm
I added a toolbar. 1st post updated to version 1.1
kyyu
Postby TIG » Sat Jul 23, 2011 6:37 pm
Thanks! :D
Global Moderator
Postby rv1974 » Sun Jul 24, 2011 8:03 am
Hi Kyyu!
Could you please make a simple version of the script without any icons and dropdown options?
Just a distillated simple scale ruby. Please!
Thank you!
rv1974
Postby halroach » Sun Jul 24, 2011 8:53 am
From Plugins Menu: If nothing is selected, than all active groups/components are processed. Run from the Plugins menu: "[ky] Simple Scale Handles"
Nice plugin!
Though it doesn't work for me as described. If I select one component, and run the tool, it still effects all of the components, except for components that are within components. No matter what I select, it always effects everything.
halroach
Postby kyyu » Sun Jul 24, 2011 8:40 pm
rv1974 wrote:Hi Kyyu!
Thank you!
You really want a one way ruby? copy/paste into ruby console or .rb file.
Code: Select all
UI.menu("Plugins").add_item("simple scale handles"){Sketchup.active_model.definitions.each{|e|e.behavior.no_scale_mask=88}}
kyyu
Postby kyyu » Sun Jul 24, 2011 8:52 pm
Nice plugin!
From the plugin menu? I just double check and it works the way it should. From the toolbar icon, it's supposed to only processes everything (if you look at the next paragraph in the description). The idea was that a depressed icon would indicate, you had processed everything. Although, I could probably set it up so the toolbar can be used with selection and only depress whatever was last all processed. You can still click the icon, when it is depressed. Is that the way people would like to have it set up?
kyyu
Re: [Plugin] Simple Scale Tool Handles v1.2 7-25-2011
Postby kyyu » Mon Jul 25, 2011 6:23 am
Updated to v1.2, see 1st post. The menu item has always processed the selection, if it exsit. Now the toolbar icons do this, too. But there is an option to change it back to only processing all. See the description. Also, I darkened the icons.
kyyu
Postby rv1974 » Mon Jul 25, 2011 6:59 am
Thank you!
Code: Select all
It's gettinng better. There's one last step. Now your simplified script assures that the next scale operation will be with simple handles, correct? What I'd like to get is simplified scale all together at once.
Thank you so much
rv1974
Postby halroach » Mon Jul 25, 2011 8:12 am
kyyu wrote:Updated to v1.2, see 1st post. The menu item has always processed the selection, if it exsit. Now the toolbar icons do this, too. But there is an option to change it back to only processing all. See the description. Also, I darkened the icons.
The last update 1.2 works like expected. It was a bit confusing for me when the menu item was doing something different than what the toolbar was doing.
By what it looks, basically what the plugin does is change the scale properties for each component, right?
1. I think some people may confuse this tool as being a separate scale tool that scales only in the XYZ direction...
but it is actually a tweak for each component to scale differently, with the original scale tool. I guess it is similar to using dynamic component scale attributes (as in the image attached)
2. would this tweak have any effect on model performance? or file sizes!? When I was using dynamic component attributes for this exact same scaling idea, it used to make overall sketchup performance a bit laggy at times.
3. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
thanks!
halroach
Postby halroach » Mon Jul 25, 2011 10:38 am
In the latest version 1.2, there is a problem that the simple scale isn't constrained to only X Y Z, but also one more XY... see attached image.
I used the toolbar to change the properties...
halroach
Postby kyyu » Mon Jul 25, 2011 12:15 pm
Halroach wrote:The last update 1.2 works like expected. It was a bit confusing for me when the menu item was doing something different than what the toolbar was doing.
Yes, the user is selecting or processing all components/groups. And I explained, in basically the 2nd sentence of the 1st post that a property of the comp/group was being modified. I get confused myself about other peoples plugins. It's just the nature of things, the wild west of plugins.
Halroach wrote:1. I think some people may confuse this tool as being a separate scale tool that scales only in the XYZ direction...
The properties in that picture look very familiar: http://code.google.com/apis/sketchup/do ... cale_mask=
I am using those exact properties, from the SU ruby api. So maybe you will get the same limitations? Big models is kinda outside my knowledge zone. I'm still using an old computer, Pentium 4, but it's enough for my need. Just do small home project with SU.
Halroach wrote:3. Is it at all possible to have a separate scale tool that would do just this, without the need to change properties of each or all of the components, a tool that would work on simple un-grouped geometry as well?
Of course, anything is possible, but would you spend the time to do it? Probably not, usless it was very important to you. Even this small pugin, I probably spent an evenings time spread over a few days. And I'm no expert, just slowly learning.
But I see that Fredo6 just put a similar, but real tool mod in his FredoScale plugin. Looks like he is responding to the same request I saw. I just happen to come across a solution and remembered the request. Check it out:
viewtopic.php?f=323&t=17948&start=600#p343978
Halroach wrote:In the latest version 1.2, there is a problem that the simple scale isn't constrained to only X Y Z, but also one more XY... see attached image.
Yes, I have X,Y,Y and (X+Y). The request was for scaling sheet parts. So X+Y coupling is fine and probably wanted. I just removed all z coupling. If you want, just X,Y,Z; it's easy enough to change:
Line#56 where it has "e.behavior.no_scale_mask=88" just change the "88" to "120".
kyyu
Postby halroach » Mon Jul 25, 2011 2:15 pm
thank you for the long reply!
That will definitely be of help! thanks of the pointers!
halroach
Postby jolran » Mon Jul 25, 2011 3:31 pm
Nice icons Kyyu! Very useful plugin.
jolran
PluginStore Author
PluginStore Author
Postby kyyu » Mon Jul 25, 2011 7:59 pm
jolran wrote:Nice icons Kyyu! Very useful plugin.
Thanks, my 1st icons. I think the most time was spent, just making the icons. :lol:
kyyu
Postby jolran » Mon Jul 25, 2011 8:05 pm
He he! Yes I know. It's difficult to make them look good after downscaling so much.
Anyway.. Good job :thumb:
jolran
PluginStore Author
PluginStore Author
Postby rock1 » Sun Aug 14, 2011 1:33 pm
i'm having a problem using this tool. when i click either of the two toolbars button, the default scaling handles remain. they never change to the simple scale tool :? what should i do?
Signature removed by SCF Admin
rock1
Postby kyyu » Sun Aug 14, 2011 3:41 pm
rock1 wrote:i'm having a problem using this tool. when i click either of the two toolbars button, the default scaling handles remain. they never change to the simple scale tool :? what should i do?
Do you have a group or component, in your drawing, for the plugin to modify? You can give it a try under the plugins menu, but no one else has reported a problem with the toolbar?
kyyu
Next
Return to Plugins
Users browsing this forum: arqgabrielcoppola, menchetti, zakevans21 and 13 guests
