[Plugin] Zero Tilt Camera
Postby odowhacker » Thu Jul 21, 2011 5:43 pm
this is my one and only ruby attempt - a shortcut script to make camera look planar to ground (in which ever direction it is facing). useful for walkthroughs - so all verticals are nicely straight.
tilt0.rb
if put in plugins dir - a command will be added to camera menu at the very bottom.
i use it via shortcut key.
odowhacker
Re: zero tilt camera
Postby mitcorb » Fri Jul 22, 2011 12:23 am
Hi, odowhacker:
I see so far there have been no replies. Everyone must be busy elsewhere? I think you may need to edit your Subject/title line to add "[Plugin]", or perhaps a moderator can do it for you, since this is posted in the Plugins subforum.
Best wishes,
mitcorb
mitcorb
Top SketchUcator
Postby honoluludesktop » Fri Jul 22, 2011 3:52 am
Hi Paul, I didn't download the plugin, but based on your description, how is it different from viewing SketchUp in parallel projection?
honoluludesktop
In Remembrance
Postby Hieru » Fri Jul 22, 2011 12:11 pm
That's what I thought as well.
Hieru
Premium Member
Premium Member
Re: [Plugin]Zero Tilt Camera
Postby Didier Bur » Fri Jul 22, 2011 12:27 pm
This is perspective view with vertical lines parallel (architects like that sort of view!)
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby Dave R » Fri Jul 22, 2011 12:44 pm
Looks similar to Two-Point Perspective without the label in the upper left corner. It's not quite the same though. thank you for this.
I did a quickie example.
Two Point:
Zero Tilt:
Combined:
Global Moderator
Postby bjornkn » Fri Jul 22, 2011 3:10 pm
I don't quite get this..
If the verticals are not parallel, which they obviously are not on the compared 2-point/zero tilt image , the camera does not have 0 tilt. ?
BTW, I typically use the 'position camera' to get 0 tilt, and then Walk to move back/forward and up down.
Works great too.
bjornkn
Postby odowhacker » Fri Jul 22, 2011 4:16 pm
maybe i shouldn't have posted this to plugins - it's rather simple and was meant ironic too.
a beginners try at coding ruby/SUapi...
the script is handy for me with walktrough animations where i would look around during setup (leave eye height and planar view) and also use different 'camera lens' settings.
the effect desired was that of a steady cam (with a weigth underneath and the camera set to 90° from that weight).
the two point perspective is kind of static and for me 'position camera' will often fail without a proper reference line or the axes.
i mainly use the shortcut for setting up scene views - sort of constructing a camera path. transitions look nicer this way (same eye heigth, 0tilt and you can do a rotational move along the way.)
..the diversion in the chair overlay would occur if you choose 0tilt coming from a 2point perspective view. this won't work - i hadn't thought of the possiblity - i never use 2point.
try with a house. inside. use the walk or move tool (hand) to navigate around once you've chosen 0tilt. you'll see.
attached a dennismethod output of some planar view of a few huts..
odowhacker
Postby honoluludesktop » Fri Jul 22, 2011 7:39 pm
honoluludesktop wrote:Hi Paul, I didn't download the plugin, but based on your description, how is it different from viewing SketchUp in parallel projection?
Oops, I meant 2 point perspective. Thanks for the explanation.
honoluludesktop
In Remembrance
Re: [Plugin] Zero Tilt Camera
Postby unclebim » Tue Jul 26, 2011 10:34 am
Thanks, I find this useful, especially when a shortcut is assigned.
unclebim
Postby andre51 » Tue Jul 26, 2011 10:32 pm
Thanks a lot!
Anybody that has battled with shift lenses in architectural photography will appreciated this.
andre51
Postby clifdon » Wed Aug 03, 2011 11:22 pm
It can be a useful plug-in. Thanks :) all the plug-ins are appreciated :)
clifdon
Postby bjornkn » Tue Nov 29, 2011 8:51 pm
Just what I was looking for :-)
It is very useful for rendering spherical/equirectangular panorama with Twilight.
If the camera is not level the panorama will be all wavy.
bjornkn
Postby LanceCampeau » Tue Mar 05, 2013 8:43 pm
Thank you for posting this... this is exactly what I was looking for... Finally, no more "dutch angles" during my transitions. :)
LanceCampeau
Postby sketchuh » Thu Dec 17, 2015 1:07 pm
Thanks!
sketchuh
Premium Member
Premium Member
Postby TAYEBI » Fri Dec 18, 2015 11:47 pm
very good plugin .. very hsady
since some of render engines do not support Su's native '2 point perspective' ..
TAYEBI
Postby tridem » Fri Nov 16, 2018 5:31 pm
:thumb: very useful plugin!
tridem
Return to Plugins
Users browsing this forum: Adam32, mpacey, pee2peem, serenespace, Skchandra and 17 guests
