[Plugin] RandomPushPull v2.5 20110709
• Page 1 of 1
[Plugin] RandomPushPull v2.5 20110709This version is updated and tidied...
Range errors now corrected. Negative pp values now allowed. The max/min now works properly with +/-ve values. The selection now passes to the newly pushpulled faces. Area comparisons added for 're-selection' [thanks kyyu!'] TIG
Re: [Plugin] RandomPushPull v2.0 20110707There is a "judgement" error in the plugin code. That is why did not respect max/min.
The original plugin makes push-pull for this distance:
So, if I input Min(400); Max(600) it will make pushPull for a random value of 200. In order to make pushPull for a random value between 400 and 600 i think, the code should look like this:
In this way, you set the minimum value (@ppmin) to pushpull, then add the random value of 200 (up to 600). But, as rand method doesn't provide 0 or 1, there will not be pieces equal with 400 or 600. DESIGNER AND ARTIST DEREI.UK
rand does return 0 Thomas Thomassen — SketchUp Monkey & Coding addict
I stand corrected ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] RandomPushPull v2.0 20110707Correct
Re: [Plugin] RandomPushPull v2.1 20110707Here's v2.1 viewtopic.php?p=340452#p340452
It now uses the min/max range 'properly'... AND if the random value is actually ==min or ==max then it is used; the accuracy for using the actual max value is set at 1/1000001. On the incredibly rare times it matches exactly or it is exceeded very slightly then 'max' is used, as is 'min' when it's met exactly [rarely]. TIG
Re: [Plugin] RandomPushPull v2.1 20110707Maybe you could add option in input box for push-pulling on negative values too, or force positive.
EDIT: - i'm not sure (as I'm not a programmer), but this code doesn't pushpull between min and max. mx can have values much less than @ppmin, so pp can have very easy a negative value (if rn=10, mx = @ppmax * 0.0001; so what are the odds that between max and min to be a difference of 4 zeroes? In consequence pp = mx(very small) - @ppmin(highly probable much larger) ==> negative value for pp ).
Re: [Plugin] RandomPushPull v2.2 20110707Here's v2.2 viewtopic.php?p=340452#p340452
I think I've sorted the range AND allowed negative values too... TIG
![]() ![]() ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] RandomPushPull v2.3 20110707Here's v2.3 viewtopic.php?p=340452#p340452
It now works properly between the max/min range and allows +/-ve values... ![]() I hope! TIG
Re: [Plugin] RandomPushPull v2.3 20110707Well, good news! It works like a charm
![]() Thank you very much! DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] RandomPushPull v2.3 20110707My brain really hurt with the logic of it... but now it's too obvious
![]() TIG
My brain hurt too trying to "discover" the reason why you tried such complicated ways to do it. Especially because my programming skills are like the result of rand method (yes, between 0 and almost 1 ![]() DESIGNER AND ARTIST DEREI.UK
Re: [Plugin] RandomPushPull v2.3 20110707So it was a true random result!
Re: [Plugin] RandomPushPull v2.3 20110707Always funny and robust!
![]() re-apply on result with the all faces (top and lateral) ![]() result is not too regular? (I took 1 and .1) Does it possible to keep the first selection? (top faces)
Re: [Plugin] RandomPushPull v2.3 20110707Unfortunately when you PushPull a face it disappears - the face that is at the new location isn't the same face - that's been deleted by Sketchup...
So... it's not easy to get a reference to the new face... BUT you could do it... you know the plane of the picked face, you know its pt0=vertices[0].position, you know the pushpull vector, so you can offset the pt0 and then test for the new faces added since the pushpull was done and find the one with the same/reversed normal, parallel plane and coincident vertex at the offset pt0 location... BUT I'm not going to code it ![]() TIG
Re: [Plugin] RandomPushPull v2.3 20110707Except there might be faces with the same area that were not the ones you want - so then things like face.normal / plane becomes relevant too - BUT comparing areas IS a good 'outside-of-the-box' test idea
![]() TIG
As I had started from a sphere and took a minimum measure more large than the big edges on the surface's sphere ![]() that can't be arrived ![]() It was a very particular case ![]()
Re: [Plugin] RandomPushPull v2.4 20110707Here's v2.4 viewtopic.php?p=340452#p340452
The selection now passes to the newly pushpulled faces even though the original faces have been deleted by Sketchup... TIG
Re: [Plugin] RandomPushPull v2.4 20110707Seems selection are not keeping all the initial faces selected!
![]() (tryed with some adjacents facets on a thick sphere ) Does exist a Scale multiple ? (for each facets selected)
Re: [Plugin] RandomPushPull v2.4 20110707As I explained, the original face is lost with a pushpull so I need to find the equivalent new face... At the moment it matches area, face normal and face plane [offset by the pushpull distance] - even the slightest variance in the figures that Sketchup calculates will result in a mismatch - so I suspect that's why some faces are being ignored
![]() Any ideas on a better way to spot newly pushpulled faces is invited... ![]() TIG
TIG, Seems to work 100%, if you account for the tiny area difference of the new face. In line #64, I used "if face.area-e[0].abs < 0.000001" instead of "if face.area==e[0]". Well, at least this worked on a 7 inch diameter sphere. Don't know if it will fail for other scales. [Addition] Ok, I had a chance to check if scaling would make the new area test fail. Looks ok so far. My sphere had 288 faces. Initially 7 inches in diameter. I've scaled it up to 70, 700, and 7000 inch diameter. And even with the larger areas, 0.000001 difference still worked to compare if the faces have the same area. The plugin still kept the selection on all 288 faces, in all the tests. Re: [Plugin] RandomPushPull v2.5 20110709Here's v2.5 viewtopic.php?p=340452#p340452
Kyyu beat me to it with an 'area accuracy check', which now [hopefully] ensures that all of the selected faces that are pushpulled [and thereby get erased] now get their selection passed onto the the newly added face every time... ![]() TIG
Re: [Plugin] RandomPushPull v2.5 20110709Works like a charm
![]() ![]() Again some requests ![]() - does it possible to keep the selection but separated like when you make a normal PushPpull with CTRL ? - make a Scale on each face This last must be asked also for Fredo Scale ![]()
• Page 1 of 1
Users browsing this forum: pingfuanl33 and 16 guests
