[Plugin] RevCloud v1.1 20110727
Postby TIG » Wed Jun 22, 2011 3:30 pm
(c) TIG 2011
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided that the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
RevCloud.rb
Type 'revcloud' in the Ruby Console
or choose 'RevCloud' off the Draw Menu [or shortcut to it].
It draws a Revision Cloud.
Pick a start-point, then hold down the left mouse-button to continue
drawing the revcloud - you release the mouse-button to end it.
It is represented by an orange arced-polyline until it is completed.
The cloud is made 'flat', Z ia determined from the first picked point.
You can (pre)set the 'segment-length' in the VCB; the default is 300mm.
Each segments arc-radius should be approx. half of this.
If you move the mouse very quickly the segment length may be larger.
Move to within the 'segment-length' of the 1st point & release the
button to make a closed loop, the VCB tells you if a 'closed loop' is
possible.
The last segment is then sized to close the remaining 'gap'
Releasing the button before a 'closed loop' is possible makes a broken
loop of the revcloud.
You can then start a new revcloud after releasing the mouse-button.
To exit the Tool select any new tool or Esc+Esc or press <Enter>.
Esc undoes the current revcloud (if any).
Normal Inference Tips may apply.
Draw counterclockwise for outwards 'clouds' arcs & clockwise to make
'spikes'...
The revcloud is made in a group called 'RevCloud#1' - with an
incrementing suffix.
Donations:
info @ revitrev.org via PayPal.com
Version:
1.0 20110622 First Issue.
1.1 20110727 Draw Menu 'RevCloud' added.
Global Moderator
Re: [Plugin] RevCloud v1.0 20110622
Postby Dave R » Wed Jun 22, 2011 3:52 pm
Well, isn't that slick! That's a great tool for those who need to make those sorts of clouds. Thanks, TIG.
Global Moderator
Postby Ben Ritter » Wed Jun 22, 2011 4:31 pm
TIG, thank you for all you've done to improve our workflow.
Ben Ritter
Postby bjornkn » Wed Jun 22, 2011 9:22 pm
I had to look up what revision clouds are, and found this:
Better be careful with them ;)
It is impressive how you create new plugins all the time! Looks like it is just to whisper a wish and within a couple of hours it's ready ;)
Great :)
bjornkn
Postby utiler » Thu Jun 23, 2011 1:35 am
Great work, TIG!! I've wanted something like this for Layout but I don't believe we can write ruby for LO.... is that right?
utiler
Top SketchUcator
Postby prismcnd » Thu Jun 23, 2011 4:19 am
Thanks TIG, you are the best
“Whatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
prismcnd
Postby halroach » Wed Jul 27, 2011 7:20 am
nice!
How can I assign a shortcut for revcloud to work?
halroach
Re: [Plugin] RevCloud v1.1 20110727
Postby TIG » Wed Jul 27, 2011 8:45 am
Here's v1.1 viewtopic.php?p=337237#p337237
It now has a 'Draw' menu item 'RevCloud'.
This can now be shortcutted.
Global Moderator
Postby boilingsnow » Sun Jan 01, 2012 7:28 am
Thanks for this TIG!
How about the idea: converting existing lines or curves to RevCloud?
boilingsnow
Postby TIG » Sun Jan 01, 2012 1:26 pm
boilingsnow wrote:Thanks for this TIG!
You can of course select the lines, add the RevCloud using the selection's vertices as snap points and then press delete to erase the selected lines...
Global Moderator
Postby millerjx » Sat Jul 22, 2017 12:13 am
Can this be used/ adapted for Layout. Layout is where we really need to use it. Thank you
millerjx
Premium Member
Premium Member
Postby TIG » Sat Jul 22, 2017 2:30 pm
Why not make a few assorted RevClouds in a SKP.
White background, plan view etc
Make a new empty Layout file and add them to it [copy+paste].
Explode them [into images].
Then save those into a custom Scrapbook [named RevClouds?] and use that in any Layout file as needed - resizing/scaling them etc as desired...
They'll have a transparent ground and overlay if brought to front etc - layer than as desired too...
Of course you could make your own. entirely within Layout...
Global Moderator
Return to Plugins
Users browsing this forum: gjmm, SketchPuppy and 13 guests
