[Plugin] Colors from Style
Postby Jim » Sun May 15, 2011 1:51 pm
What
A small utility that adds colors to the Materials palette from the colors used by the current Style. Colors include:
BackgroundColor
BandColor
ConstructionColor
FaceBackColor
FaceFrontColor
FogColor
ForegroundColor
GroundColor
HighlightColor
HorizonColor
LockedColor
SectionActiveColor
SectionDefaultCutColor
SectionInactiveColor
SkyColor
Colors are named using the Style name followed by the color name: [Default Style].FaceFrontColor
Menu
Plugins > Colors from Style
Download
Jim
Global Moderator
Re: [Plugin] Colors from Style
Postby mitcorb » Sun May 15, 2011 2:19 pm
Hi, Jim:
This tool looks very useful. A couple of questions, if you will. Yes, they may be naive. :)
Can you define BandColor? All the other terms seem self explanatory.
How well, or does this data export into external renderers? Or, is this something you'd want to do?
mitcorb
Top SketchUcator
Postby thomthom » Sun May 15, 2011 2:32 pm
mitcorb wrote:Can you define BandColor?
When you set the aspect ratio of the viewport and you get those shaded areas, which by default is transparent grey.
PluginStore Author
PluginStore Author
Postby Jim » Sun May 15, 2011 2:53 pm
What Thom said.
mitcorb wrote:How well, or does this data export into external renderers? Or, is this something you'd want to do?
I guess that would depend on the exporter used by the renderer. I think all SketchUp-compatible rendering engines have an exporter that supports SketchUp materials. Does that help?
Jim
Global Moderator
Postby function » Sun May 15, 2011 9:52 pm
How about colors from the layer palette? I find myself coloring by layer quite often, it would be nice to transfer those to the model data itself. Thanks for the script!
function
Postby TIG » Sun May 15, 2011 10:35 pm
Access to layer colors is very limited [I wrote a way of getting them from a DXF export but it's pretty lame]... AdamB did come up with a 'possible' solution that never got finalized....
Global Moderator
Return to Plugins
Users browsing this forum: ananan1523, Dienifer, leesnake, muhamadbarkah and 12 guests
