[Plugin] Facewarp
[Plugin] Facewarp
Postby Builder Boy » Fri May 13, 2011 9:44 pm
My original post was here. I still got tired of dividing edges(by the way, does anyone know how to do this with ruby?), then welding them back together, then filling out a lot of dialog boxes. So, I made my own plugin to do this. I give you:
Facewarp.rb
Builder Boy
Re: [Plugin] Facewarp
Postby Rich O Brien » Fri May 13, 2011 9:57 pm
Lots of vanishing lines when drawing? And not all faces created?
Rich O Brien
Administrator
Postby TIG » Fri May 13, 2011 10:10 pm
Global Moderator
Postby Builder Boy » Fri May 13, 2011 10:25 pm
Rich O'Brien wrote:Lots of vanishing lines when drawing? And not all faces created?
This plugin does not always work when 2 points have the same location. Also, may give unexpected results when 3 points are collinear.
TIG wrote:http://code.google.com/apis/sketchup/docs/ourdoc/edge.html#split ???
This will only split a line into 2 segments with controllable proportions, I am looking for something more like this:
edge.divide(5) # for 5 equal-length segments
Builder Boy
Postby Didier Bur » Sat May 14, 2011 10:50 am
You can do that with edge.split, just create a loop 0.upto(4) for instance to divide in 5 segments...
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby TIG » Sat May 14, 2011 12:57 pm
It'd be easily enough to make a custom 'divide' method that works as you want - you know the edge's starting length and therefore the length of one divided part. So simply iterate through the edge the number of divisions-1 nibbling off the appropriate proportion as another edge until you are done. I don't recommend extending the Edge class but more like this...
self.divide(edge,5)
calling this
Code: Select all
def divide(edge=nil, num=nil)
  return nil if not edge or edge.class!=Sketchup::Edge
  return nil if not num or not num.class==Fixnum or num<=1
  len=edge.length
  bit=len/num.to_f
  num.times{
    begin
      nedge=edge.split(bit/len)
      if nedge
        edge=nedge
        len=edge.length
      end#if
    rescue
      puts 'Divide Error'
Which splits the specified edge into the specified parts...
Global Moderator
Return to Plugins
Users browsing this forum: EishaAhmad, Jim and Frida and 7 guests
