[Plugin] SurfaceGen (0.9.0b) — 28 April 2012
Postby Diggsey » Fri Apr 29, 2011 12:08 am
SurfaceGen v0.9 (Beta)
SurfaceGen is a plugin which allows you to create surfaces from mathematical formulae. There are two modes supported:
Function Mode
The Z coordinates of points in a heightmap are specified as a function of X and Y. There can therefore only be one Z value per X, Y coordinate.
Equation Mode
An equation relating X, Y and Z is given. This mode can graph any 3D surface for which there is a formula, but may take slightly longer. The marching cubes algorithm (wow that one is a pain to implement!) is used to generate a surface around a 3D grid of data generated from the equation.
Instructions
- Select the SurfaceGen tool from its toolbar.
- Click to set one corner of the graph.
- Click again to set the opposite corner on the same level.
- Click a third time to set the height of the graph.
- You can transform the resulting group without causing problems.
- After creating the graph and it becoming selected, the SurfaceGen Options window should appear.
- Set the axis ranges, the SurfaceGen mode and enter an equation.
- Choose if you want to show the graph boundary. This will make a semi-transparent box around the graph. The sides facing the camera will always be invisible as you rotate the camera allowing you to see the surface.
- Choose if you want the graph to be smooth.
- Click generate. This may take a few seconds, so be patient. It will happen asynchronously, so you should still be able to move the camera around.
- You can set the surface material by using the paint bucket on the group. The surface will become the selected material.
- Opening the group will cause the graph to turn into a normal group. The plugin will ask if you really want to do this before it actually happens.
Install
Download and extract the attached zip file to your plugins folder. Please remember this is still in beta! I want to hear about any problems you encounter!
Update 0.6
- Updated to work with SketchUp 6
Update 0.7
- Updated to be more compatible with Macs
Now uses built in functions to locate resources and combine paths. Also uses WebDialog.show_modal on macs to get always-on-top behaviour.
- Added more functions
abs, min, max, clamp can now be used in an expression.
- Allowed expressions in axis ranges
You can now easily graph from -pi to pi etc.
- More error checking
You will be notified if an expression is invalid, and hopefully some useful information about why it was invalid will given.
Update 0.7b
- Added point validation to getExtents for the graph tool
The ruby console shouldn't show any errors when drawing a new graph.
Update 0.7c
- Fixed expression parsing bug
Previously, using the same function twice in a row didn't work: sqrt(sqrt(16)) due to the regex used. Now it does.
Update 0.8
- Changed use of pt units to px units in WebDialog
The font should display at the same size in all browsers.
- Now works from any directory
Resources are looked for starting with the directory containing surfacegen.rb.
- Can more easily change WebDialog size
The width as well as the height are constants in surfacegen.rb
Update 0.9
- Increased speed
Previously "eval" was used to evaluate the expression at each sample point, now it uses "eval" once to create a proc object which is called multiple times.
Reason: Added version number and time of update in title
Diggsey
Re: [Plugin] SurfaceGen
Postby mitcorb » Fri Apr 29, 2011 3:34 am
Hi, Diggsey:
This looks interesting. You are off to a good start.
mitcorb
Top SketchUcator
Postby d12dozr » Fri Apr 29, 2011 6:42 am
Diggsey, this is neat! I just started learning this week how to generate implicit surfaces using equations in Meshlab, and I've been importing them into SU - now I can do it all in Sketchup :thumb: :thumb: While I don't really understand the math, I just play around with equations and see what pops up.
On that note, do you have any ideas I can use as starters/seed equations for generating neat surfaces? What kind of math would I need to brush up on to understand this stuff better?
For now, I'm just playing, but I have dreams of making some beautiful math sculptures like Bathsheba Grossmanmakes.
Here is a little test I did, using the settings shown in the screenshot.
Did I say thank you, Diggsey? :D
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby d12dozr » Fri Apr 29, 2011 7:17 am
Heh, here's a truncated sphere, settings shown...this is fun! :mrgreen:
Some suggestions:
-When switching to "Equation", change the default settings to something that will work just by pressing "Generate"
-Add a random equation/function generator, perhaps using preset equations
-Add an error message when the equation is invalid, pointing out why its invalid if possible
Like Jean says, just ideas...
d12dozr
Top SketchUcator
Postby dedmin » Fri Apr 29, 2011 7:30 am
Diggsey, where have You been so far!! We need You! Keep up surprising Us! Thanks!
dedmin
Postby d12dozr » Fri Apr 29, 2011 8:05 am
Here's a question for you...is there a way to make the SurfaceGen geometry look like the first Meshlab image? I'm using the same equation, and trying to get results like changing the voxel size in Meshlab, but changing the # of cells in SurfaceGen doesn't seem to have the same effect...am I doing something wrong?
BTW, I like how the settings are saved for each generated surface!! :enlight:
d12dozr
Top SketchUcator
Postby pilou » Fri Apr 29, 2011 8:19 am
ah very cool! :fro:
Topmod and K3dSurf in a same place! :thumb:
(you can take some formula from K3DSurf ;)
Topmod above is perfect for that ;)
by me :)
By Jotero
Speedy Galerie
Top SketchUcator
Postby d12dozr » Fri Apr 29, 2011 8:38 am
Great links, Pilou! Thank you :thumb: Nice work on the sculpture, too.
d12dozr
Top SketchUcator
Postby thomthom » Fri Apr 29, 2011 8:51 am
Very nice plugin. :thumb:
PluginStore Author
PluginStore Author
Postby pilou » Fri Apr 29, 2011 8:56 am
In the V6 don't works ;)
Error Loading File surfacegen.rb
cannot convert Hash into String
Works fine in the V7 ;)
Speedy Galerie
Top SketchUcator
Postby Diggsey » Fri Apr 29, 2011 11:45 am
Thanks everyone who commented!
@d12dozr
I've no idea how to make such complicated structures as those ones you linked to, but you can get some interesting shapes by just mixing up a few of the built in functions:
sin, cos, tan, sinh, cosh, tanh, asin, acos, atan, asinh, acosh, atanh, atan2, hypot, sqrt, cbrt, log, log2, log10, ln, exp
and constants:
e, pi
I'll just make the default equation something that will work for both modes.
That could be interesting. Perhaps the user could choose a level of complexity and it would use that many operations.
Showing an error would be possible, but it might be difficult to point out where. It depends on how much information ruby gives me. For speed, the equation is converted into ruby code, so I can just eval it for each point instead of running my own interpretter.
I don't know exactly how Meshlab works internally, but it seems like the voxel size is equivalent to the range of values divided by the number of cells. ie:
voxelSize = (max-min)/cells
I'm surprised it should look so different though, just by changing the voxel size.
@Pilou
I've found the problem. It won't let me pass a hash to WebDialog.new.
Diggsey
Postby thomthom » Fri Apr 29, 2011 12:12 pm
Diggsey wrote:@Pilou
Additionally, SU6 only accepts one argument for model.start_operation.
I've used this wrapper:
Code: Select all
def self
.start_operation(name)
model Sketchup.active_model
if Sketchup.version.split('.')[0].to_i >= 7
    model
.start_operation(nametrue)
  else
model.start_operation(name)
The operation will run slower under SU6 - but at least it runs.
PluginStore Author
PluginStore Author
Postby Diggsey » Fri Apr 29, 2011 12:20 pm
Thanks thomthom, but I've just used a rescue statement so it will fallback on the older version if the newer one fails. The first post has the updated version which works with v6.
Diggsey
Postby TIG » Fri Apr 29, 2011 2:54 pm
There are also a few error-messages appearing in the Ruby Console that needs traps or begin/rescue forms [e.g. after you explode a special group]...
Some of them relate to your 'recurve' too...
But it's a neat tool :D
Global Moderator
Postby Diggsey » Fri Apr 29, 2011 4:02 pm
I've tried doing everything possible and can't seem to get any output in the ruby console from either plugin. Can you tell me exactly how to reproduce it?
Diggsey
Postby notareal » Fri Apr 29, 2011 4:23 pm
Nice! Can't wait some more complex math sculptures... and naturally even more functionality, like with K3DSurf.
Little test...
notareal
Thea Render Support
Thea Render Support
Postby TIG » Fri Apr 29, 2011 4:42 pm
Diggsey wrote:I've tried doing everything possible and can't seem to get any output in the ruby console from either plugin. Can you tell me exactly how to reproduce it?
For example...
Error: #<NoMethodError: undefined method `curve' for #<Sketchup::Group:0xa9d06fc>>
C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in `can_select_curve?'
C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:32:in `can_select_curve_selection?'
C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:352
When right clicking a tagged 'surfacegen-group'.
Explode the special surgfacegen-group and right-click gives
Error: #<NoMethodError: undefined method `curve' for #<Sketchup::ComponentInstance:0xb440344>>
C:/Program Files/Google/Google SketchUp 8/Plugins/recurve.rb:17:in `call'
Erase that 'bounds' Instance then Select the surface...
Error: #<NoMethodError: undefined method `curve' for #<Sketchup::Face:0xad7783c>>
These all relate to 'recurve' reaction to 'surfacegen' entities ?
I did have a surgacegen error but I can't get it to reproduce now :?
Global Moderator
Postby d12dozr » Fri Apr 29, 2011 4:42 pm
Diggsey wrote:I've no idea how to make such complicated structures as those ones you linked to, but you can get some interesting shapes by just mixing up a few of the built in functions:
and constants:
e, pi
Thank you for this, and considering my suggestions too!
d12dozr
Top SketchUcator
Postby pilou » Fri Apr 29, 2011 5:55 pm
In the V6
We can draw the "Box" but dialog's window don't opening ;)
No error message, nothing in the Ruby console
Speedy Galerie
Top SketchUcator
Postby Diggsey » Fri Apr 29, 2011 6:08 pm
@notareal
That's really nice! What's the equation you used?
@TIG
Make sure you have the latest version of Recurve. I fixed that bug with the last update which is why I couldn't reproduce the error. If you ever get the SurfaceGen error again let me know.
@Pilou
Just re-select the group with the select tool. It seems that the SelectionObserver doesn't fire when the selection is changed in code.
Diggsey
Postby TIG » Fri Apr 29, 2011 6:24 pm
You are right, in that when I get v1.4 of 'recurve' I no longer get these errors with 'surfacegen'. However, I had v1.3 [with SUpv8] and there were no major changes except for making it SUpv6 friendly ?
Anyway... no more error messages... I'll try to break it ;)
Global Moderator
Postby Builder Boy » Fri Apr 29, 2011 9:03 pm
Sponge-like object:
Builder Boy
Postby driven » Sat Apr 30, 2011 2:23 am
this is great,
some odd behavior on the Mac... when run from plugins (like you should) I get this
Code: Select all
Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb:266:in `add'
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb:266:in `getExtents'
if I put the surfacegen.rb into the folder do a restart and then load from Ruby Code Editor, I get this
Code: Select all
(eval):428: warning: don't put space before argument parentheses
"Run aborted (error has occurred)"
(eval):10: warning: already initialized constant SURFACEGEN_DIR
(eval):11: warning: already initialized constant GRAPH_SIZE
(eval):12: warning: already initialized constant WINDOW_HEIGHT
(eval):13: warning: already initialized constant ATTR_DICTIONARY
but if I restart again and use as_pluginloader.rb to load it I get
Code: Select all
/Library/Application Support/Google SketchUp 8/SketchUp/plugins/SURFACEGEN_Dir/surfacegen.rb:428: warning: don't put space before argument parentheses
it works, but has no tool button image...
driven
PluginStore Author
PluginStore Author
Postby notareal » Sat Apr 30, 2011 8:25 am
Diggsey wrote:@notareal
Code: Select all
F(x,y,z) = 2-(cos(x+(1+sqrt(5))/2*y)+cos(x-(1+sqrt(5))/2*y)+cos(y+(1+sqrt(5))/2*z)+cos(y-(1+sqrt(5))/2*z)+cos(z-(1+sqrt(5))/2*x)+cos(z+(1+sqrt(5))/2*x))*16/(x*x+y*y+z*z)
[x]: -5, 5
[y]: -5, 5
[z]: -5, 5
There is plenty more at the k3dsurf forum.
notareal
Thea Render Support
Thea Render Support
Postby notareal » Sat Apr 30, 2011 9:20 am
Perhaps you could add some more functionality; like functions min, max and abs. Also allow use of arithmetic operations and pi in axes, like -2*pi.
notareal
Thea Render Support
Thea Render Support
Postby TIG » Sat Apr 30, 2011 9:59 am
You already have 'pi' [in lowercase] as a function?
Global Moderator
Postby thomthom » Sat Apr 30, 2011 11:30 am
The SelectionObserver has always been very buggy: http://www.thomthom.net/software/sketchup/observers/
PluginStore Author
PluginStore Author
Postby Diggsey » Sat Apr 30, 2011 1:42 pm
Just uploaded a fairly major update to the first post!
@driven
This should fix the issues with macs. It now uses cross-platform methods to locate and load resource, and uses show_modal rather than show on macs with the WebDialog.
@notareal
The axes now let you use an expression such as 2*pi
@d12dozr
Helpful error message are now shown when an expression is invalid.
Diggsey
Postby TIG » Sat Apr 30, 2011 1:58 pm
Thanks :D
Code: Select all
C:/Program Files/Google/Google SketchUp 8/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb:270:in `add'
C:/Program Files/Google/Google SketchUp 8/Plugins/SURFACEGEN_Dir/surfacegen_tool.rb:270:in `getExtents'
One minor error in getExtents in surfacegen_tool.rb
Line #270 result.add @p0 if @state >= 0
can raise an error so adjusting it to
return if !@p0 or @p0.class!=Geom::Point3d; result.add @p0 if @state >= 0 might help - you could also add similar validity checks on the other points that are added to the extents ?
Global Moderator
Postby Diggsey » Sat Apr 30, 2011 2:20 pm
Ah, I knew I'd forgotten something :)
I've updated the first post. It shouldn't show those errors anymore.
Diggsey
Next
Return to Plugins
Users browsing this forum: No registered users and 12 guests
