[Plugin] Autoloader
[Plugin] Autoloader
Postby Diggsey » Sun Apr 24, 2011 4:31 pm
This is mainly useful for when writing plugins. After making a change to a plugin, just click the update scripts button and it will automatically reload any scripts which have been modified since they were last reloaded. It should handle .rb and .rbs files, and will look for scripts in all the paths in the $: global variable.
The plugin will list the files which have been reloaded and the files for which reloading failed in the status bar.
Extract the attached file to your plugins folder to try it out.
Diggsey
Re: [Plugin] Autoloader
Postby dedmin » Sun Apr 24, 2011 4:50 pm
Cool! This is very handy when updating scripts and want to use the new version without restarting SketchUP!
dedmin
Postby Bob James » Sun Apr 24, 2011 5:06 pm
If I have SU open and add a new plugin, will this tool now "see" the new plugin without re-starting SU?
I'm talking new plugin, not revising script on an already loaded plugin.
Bob James
Premium Member
Premium Member
Postby Diggsey » Sun Apr 24, 2011 5:07 pm
Yes it will see new files as well as existing modified ones;)
Diggsey
Postby AndriyG81 » Sun Apr 24, 2011 6:17 pm
works like a dream.
:P
Thank you
AndriyG81
Postby Bob James » Mon Apr 25, 2011 1:24 am
Diggsey wrote:Yes it will see new files as well as existing modified ones;)
Now this is a timesaver :thumb:
Bob James
Premium Member
Premium Member
Postby Didier Bur » Thu Apr 28, 2011 9:51 am
works like a dream
@AndriyG81: does it reload modified files that are in sub-folders of the Plugins folder ? It doesn't do that for me... :cry:
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby Diggsey » Thu Apr 28, 2011 5:01 pm
Currently it only reloads files in the plugins folder.
Diggsey
Postby Bob James » Sat Apr 30, 2011 7:27 pm
Diggsey wrote:Currently it only reloads files in the plugins folder.
But does it "see" new sub-folders?
More precisely, if I've put a new plugin into the plugins folder while SU is open and that new plugin contains a folder, will Autoloader "see" the new sub-folder and allow the new plugin to work?
Bob James
Premium Member
Premium Member
Postby TIG » Sat Apr 30, 2011 7:40 pm
When you get a list of entries in a Directory it will include files and folders.
It loads scripts it finds by files by their extname [.rb etc], but you can also find directories by their filetype.
So it's also possible to get a list of any subfolders and then reiterate through those to get their .rb files etc etc...
Global Moderator
Postby Diggsey » Sat Apr 30, 2011 7:41 pm
Yes, of course. It doesn't affect the way the plugin is loaded, it just loads it.
Diggsey
Postby Jim » Sun May 01, 2011 2:23 am
Hi Diggsey,
Nice idea, thank you. However...
Sketchup::load (if I remember) is an alias for Sketchup::require, and doesn't reload scripts that are already listed in the $LOADED_FEATURES array. In short, I don't think anything is actually getting reloaded.
Also, it would be helpful to wrap the load in begin..rescue..end to catch LoadError's and SyntaxErrors and report them as coming from the file being loaded instead of from autoloader.
Related Topic
Jim
Global Moderator
Postby archipod88 » Tue May 17, 2011 8:20 pm
cool...i tried it thanks a lot..!!! :thumb:
archipod88
Return to Plugins
Users browsing this forum: alanazuquello156, Diamoss, Eduardodor, puntoclassic and 17 guests
