[Plugin] Grow
[Plugin] Grow
Postby TIG » Sat Apr 23, 2011 2:07 pm
There have been several threads about 'Grow' [they keep growing :roll: ]... so it's been decided to make one new central point where it'll be based - and that right HERE!
Usage:
Move/Place Objects,Select them and pick Grow.
Pick Point.
Enter desired data in dialogs and see results.
Undo is in 1 step.
Note that non-grouped Faces and Edges can stick together after 'Growing'.
Play around to see types of results...
Shape, location, scale, order all produce different results...
Linear Scaling goes 1 2 3 4 5 6 7... on any scaling factor
Exponential + goes 1 2 4 8 16 32... on any scaling factor != 1
Exponential - goes 1 1/2 1/4 1/8 1/16 1/32... on any scaling factor != 1
Fibonacci + goes 1 1 2 3 5 8 13... on any scaling factor
Fibonacci - goes 1 1 1/2 1/3 1/5 1/8 1/13... on any scaling factor
Download
Global Moderator
Re: [Plugin] Grow v2.1
Postby Khai » Sat Apr 23, 2011 2:50 pm
..and what does it do?
Khai
Postby Gaieus » Sat Apr 23, 2011 3:07 pm
Khai wrote:..and what does it do?
Grows. Take one every evening (and one extra before sex but never more than two a day)
8-)
Postby TIG » Sat Apr 23, 2011 3:18 pm
Gaieus! :roll:
I've added an explanation to the download page...
It's been around so long that I forgot that it might be new to some of you... :?
Global Moderator
Postby Gaieus » Sat Apr 23, 2011 3:20 pm
Ah well, sorry for the bad joke indeed (I could not resist however)
:D
Postby solo » Sat Apr 23, 2011 3:35 pm
Csaba,you have grow.rb confused with viagra.rb.
http://www.solos-art.com
solo
Global Moderator
Postby Gaieus » Sat Apr 23, 2011 3:44 pm
You know, at my age you take everything whose label says "grow".
:roll:
Postby TIG » Sat Apr 23, 2011 3:50 pm
I've heard that the super-strength-viagra - like you use - is so potent, that if you don't swallow it quickly enough you get a stiff-neck :roll:
Global Moderator
Postby Rich O Brien » Sat Apr 23, 2011 4:00 pm
Keep on topic guys. I'd hate to have to shaft you outta here. So quit the dickin' around. It is easter after all. The time to reflect on what rose from the dead only to disappear again.
Rich O Brien
Administrator
Postby pilou » Sat Apr 23, 2011 4:11 pm
Note that this version [v2.1] is unchanged from the previous one you might have found somewhere else - it's just been rehoused here !
So if I have the last previous one, non need to download this one? :oops:
My favorite one :fro:
Speedy Galerie
Top SketchUcator
Postby TIG » Sat Apr 23, 2011 4:13 pm
So if I have the last previous one, no need to download this one? :oops:
Correct.
I suspect you already have the latest version.
Reinstalling it won't do any harm - it'll just be a waste of two minutes that you'll never see again ;)
Global Moderator
Postby pilou » Sat Apr 23, 2011 4:32 pm
yes old but yet 2.1 2007 01 21 ;)
Speedy Galerie
Top SketchUcator
Postby TIG » Sat Apr 23, 2011 4:39 pm
It IS an 'oldie but a goldie'...
It would probably benefit from a webdialog interface etc etc... BUT four or five years ago when I wrote it it was the best I could do...
It still works!!! :D
Global Moderator
Postby Jim436 » Mon Apr 25, 2011 2:22 pm
A question about "growing" things. No, not that, sketchup things.
To try to explain.
Okay, starting with something 10 units long in the red direction. Say it's just a line. And rotations all zero. Now if I set x copy scaling to 1.1 and xcopy scaling type to exponential, I get copies in the sequence:
11, 12.21, 13.331 ....units length.
What I expected, each new copy is 1.1 times the length of the previous copy. Good.
Now do the same thing only with xcopy scaling set to linear.
(as I am hoping to get copies in the series:
11, 12, 13, 14 ....
But what I get is:
23.1 ,37.51, 53.361 ....units length
I'm just not quite understanding this. The linear scaling.
Help??
Jim436
Postby pyroluna » Tue Apr 26, 2011 3:42 pm
Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! :enlight:
pyroluna
Postby TIG » Tue Apr 26, 2011 5:12 pm
Pyroluna wrote:Dude. Why didn't I discover this plugin sooner? This is the perfect plugin to make a spiral staircase! :enlight:
That IS one of the demos from looooong ago... :roll:
Global Moderator
Postby d12dozr » Tue Apr 26, 2011 9:34 pm
Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! :enlight:
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby TIG » Tue Apr 26, 2011 10:17 pm
d12dozr wrote:Right, but I believe Pyroluna's point is that there are MANY useful ruby 'gems' buried here...we need that official Plugin repository so that they are easy to discover and understand each one's purpose! :enlight:
That's why, after some prompting, I resurrected 'Grow' into the mainstream so you might all know/remember it... :D
Here're some [old] examples...
Grow Examples.zip
Global Moderator
Postby d12dozr » Wed Apr 27, 2011 12:48 am
Thank you for those :thumb: ...now isn't someone working on a video tutorial? ;)
d12dozr
Top SketchUcator
Postby TIG » Wed Apr 27, 2011 11:01 am
Grow is so old that there was only 16mm film back then ;)
Global Moderator
Postby d12dozr » Wed Apr 27, 2011 6:23 pm
So a black and white silent film? That works! :D
d12dozr
Top SketchUcator
Postby Pherim » Wed May 18, 2011 4:06 pm
It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
Pherim
Postby TIG » Wed May 18, 2011 4:40 pm
Pherim wrote:It doesn't work for me if SketchyPhysics 3.2 is installed. If I remove sketchyphysics.rb from the plugins folder, it works fine.
This is a known issue - SP messes with some existing base class methods and thereby affects a few other scripts...
Global Moderator
Postby patricprz » Mon Sep 26, 2011 4:16 am
Thanks for recommending this. It works a treat. :thumb:
patricprz
Postby Sir.Swaffel » Tue Sep 27, 2011 11:46 am
What would be the best way to let it "grow along path"?
Sir.Swaffel
Postby TIG » Tue Sep 27, 2011 3:46 pm
Not this tool...
Look for Chris Fullemr's ComponentStringer and RickW's ComponentAlongPath ...
Global Moderator
Postby Sir.Swaffel » Tue Sep 27, 2011 4:12 pm
Well I do need some kind of scaling. As you can see from the image, I'm trying to make a spiraling tower. I need to make windows in the vertical segments, but the tower is quite large and the vertical segments get smaller as the tower gets higher. So I need the windows to follow the spiraling path upwards AND have them scaled down according to the height. Then I'm going to subtract them from the vertical segments to create the arched openings. It's a total headache :roll:
Sir.Swaffel
Postby TIG » Tue Sep 27, 2011 4:37 pm
Try DrawHelix for the rail[s] - you can have different start/end radii and a straight-curve for the profile...
Here's quick example, worry about the fripperies like the door-arch later...
Global Moderator
Postby mikenon » Wed Sep 28, 2011 8:42 pm
Hi - This is almost exactly what I need, but I would like to use other functions. Is there a way to alter this so that instead of choosing from linear/exponential/fibonacci I have the ability to select my own values. I need some other periodic functions, like sine-wave. I imagine, the easiest way to do this would be to just allow values to be passed in a list. So if I want 100 copies, I pass in a list with 100 numbers for x-offset. Is this possible?
Mike
mikenon
Postby TIG » Thu Sep 29, 2011 8:47 am
Yes IF YOU redo the code.
It's probably easiest to make a new tool that is run in a way that can take arguments - in your case an array of values, which it then uses to do something.
That way the processing is somewhat independent of the outcome...
Do not forget that there are already many tools that process CSV/TSV files so in your case you simply have a file in the format x,y,z [and even rotx,roty,rotz,scalex/,scaley,scalez etc] - one 'point' per line and then do something with the point - add cpoints, join up the points with lines etc, place an instance at every point and rotate it/scale it... You could make the 'table' file from Excel osa...
IF you explain better what it is you want to achieve and supply a typical xyz... data set I might be able to quickly bodge something together, though I am quite busy... :|
Global Moderator
Next
Return to Plugins
Users browsing this forum: betovn, Flipe17, kabi and 8 guests
