[Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
Postby macgile » Wed Apr 06, 2011 6:33 pm
This plugin generates smooth animations based on a camera path (bezier spline). Camera keys are editable and saved within the drawing.
How to install: Unzip in Plugins folder.
Shortcuts:
Alt + Q : Add camera key / Update position of key (first press down. see below)
Down : Edit current key.
Left : Previous key.
Right : Next key.
Up : Preview animation.
Enter : Generate Scenes (pages)
Edit camera key mode is available only (top - right - left - front ) view.
Soon:
I want to add an effect to mimic the pitch of the airplane flight.
Known Issues:
1) WARNING ! when you whant generate avi file it crash sketchup (desactivate tool first "click on select tool" )
require bezier.rb
http://rhin.crai.archi.fr/rld/download.php?file=bezier.rb
Update 2011-04-09 (Fixed various errors with large model)
Download english version on ruby library depot (french version translated by Didier Bur is available) : Ruby Library Depot
Direct download : CameraKeyMaker.zip
Tutorial basic:
http://www.youtube.com/watch?v=vZ_V9Txie2A
Demo animation :
Parody
Cloister galleries Thoronet (test advanced animation)
Enjoy!
macgile
Re: [Plugin] CameraKeyMaker 1.0
Postby srx » Wed Apr 06, 2011 6:53 pm
Great! Thank you! :sketchstatic:
www.saurus.rs
srx
Postby Krisidious » Wed Apr 06, 2011 11:30 pm
nice animation. could you describe what makes your animation plugin different from others?
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Pixero » Thu Apr 07, 2011 7:31 am
Wow! I'm stunned. :shock:
This is exactly what I always wanted for SU animation.
Thank you soooo much!
Did I say Wow? :sketchstatic:
Pixero
Postby Pixero » Thu Apr 07, 2011 7:33 am
Just did a quick test and it's supersmooth.
Love it already.
Pixero
Postby Gaieus » Thu Apr 07, 2011 1:49 pm
Yes, apparently very nice, smooth animations. :thumb: :thumb: :thumb:
I wonder how they can be "translated" into 3rd party renderers' camera exporters (this is obviously not your task but of those who write them - hopefully it is feasible).
Postby macgile » Thu Apr 07, 2011 1:56 pm
Pixero wrote:Just did a quick test and it's supersmooth.
Love it already.
Thank you very much Pixero :)
macgile
Postby macgile » Thu Apr 07, 2011 2:00 pm
Gaieus wrote:Yes, apparently very nice, smooth animations. :thumb: :thumb: :thumb:
Yes it's possible.
I know that in LightWave the camera paths are stored in envelopes it's just a spline.
macgile
Postby TIG » Thu Apr 07, 2011 2:37 pm
Excellent idea.
My only suggestion is that you put it in the 'Camera' menu rather than the 'Plugins' [I've already edited my version...] :)
Global Moderator
Postby macgile » Thu Apr 07, 2011 2:42 pm
TIG wrote:Excellent idea.
Of course it's obvious :)
Thank's TIG
best regard.
macgile
Postby jarynzlesa » Thu Apr 07, 2011 9:38 pm
nice and smooth :thumb: .
jarynzlesa
Postby dbalex » Sat Apr 09, 2011 11:56 am
It's a great plugin! I'm testing it right now but I'm trying to edit the path (in top or front view in parallel and perspective) and I can't select and move the points.. Does anyone else have this problem? I'm using sketchup 8 on windows 7
dbalex
Postby macgile » Sat Apr 09, 2011 12:39 pm
dbalex wrote:It's a great plugin! I'm testing it right now but I'm trying to edit the path (in top or front view in parallel and perspective) and I can't select and move the points.. Does anyone else have this problem? I'm using sketchup 8 on windows 7
Thank's for your reply dbalex !
Strange thing!
Check your keyboard shortcuts if it already occupied by another tool (see above in the header of this post to shortcuts)
Check if you have groups or layers in your model.
sometimes when a key is published in conjunction with a group is selected that is problematic.
macgile
Postby dbalex » Sat Apr 09, 2011 3:22 pm
Is there a shortcut key for editing the points? because I can update the keyframes by putting the camera in the right spot and update the keyframe, but I can't select them and move them in the orthographic views.. non of the shortcut your plugin uses is used in my shortcuts so I don't think that's the problem, anyway even like this it's a great tool! thanks for the fast reply
dbalex
Postby dbalex » Sat Apr 09, 2011 3:23 pm
and I have no groups or layers in the scene, just a testscene with a simple cube.
dbalex
Postby macgile » Sat Apr 09, 2011 9:49 pm
dbalex wrote:and I have no groups or layers in the scene, just a testscene with a simple cube.
Sorry for the inconvenience.
Check if you have the file bezier.rb
The plugin has been tested on Sketchup v.7 and v.8 (pro or not)
best regard
macgile
Postby dbalex » Sun Apr 10, 2011 11:21 am
yes I thought of that also so I installed bezier.rb again with no results.. will try it on my other computer when I have time and will let you know if it works on that one. Thanks!
dbalex
Postby mitcorb » Sun Apr 10, 2011 2:58 pm
Would some other Bezier plugin work with this tool? If not, could this be causing the difficulty?
mitcorb
Top SketchUcator
Postby macgile » Sun Apr 10, 2011 3:25 pm
mitcorb wrote:Would some other Bezier plugin work with this tool? If not, could this be causing the difficulty?
thank's mitCorb for reply :)
In the next major update (1.2) the file "bezier.rb" will no be required.
macgile
Postby urgen » Mon Apr 11, 2011 6:32 am
....o-o-o-excellent! :thumb:
--pupil forever...------
urgen
Re: [Plugin] CameraKeyMaker 1.0 (Update 2011-04-09)
Postby Oxer » Thu Apr 14, 2011 5:24 pm
Thanks for the plugin, it's very useful but i work on Mac, the plugin runs but there are problems:
1. On Mac the keys combination (Alt+Q, ...) and the arrow keys don't works so you can't create the Camera Keys.
2. The path to camera_path.html file is invalid and the file don't open when you push Enter key.
Only the first time that i ran the plugin i could create the camera keys (Ctrl+Q on Mac) but the next times no and when i pushed the Enter key this were the Console message:
I have translating the plugin to spanish language, when i finished it i'll upload it here.
Bye and i hope your help for fix these problems.
http://www.oxervision.blogspot.com/
Oxer
Postby TIG » Thu Apr 14, 2011 5:37 pm
Using keys that might be mapped by others to do stuff [I already use Alt+Q to orient-faces] is a bad idea... use just modifiers like Alt or Cmd or Shift etc that can't be used as shortcuts otherwise...
Global Moderator
Postby macgile » Fri Apr 15, 2011 10:35 am
Oxer wrote:Hi,
Thanks for reply Oxy
Sorry for Mac users.
I'll fix these bugs soon and contact you.
macgile
Postby macgile » Fri Apr 15, 2011 10:39 am
TIG wrote:Using keys that might be mapped by others to do stuff [I already use Alt+Q to orient-faces] is a bad idea... use just modifiers like Alt or Cmd or Shift etc that can't be used as shortcuts otherwise...
Thank you for your reply TIG
Yes I do not know why I picked the keys complicated.
macgile
Postby Tiggz1 » Wed Apr 20, 2011 5:44 am
Awesome feature - Thankyou!!
One question - forgive me if I missed it. How do I delete the Camera Key path so I can start from scratch?
Tiggz1
Postby Ecuadorian » Wed Apr 20, 2011 7:16 am
This looks like exactly what I need to smooth out the motion in my LightUp animations.
Thank you! :P
Ecuadorian
Postby macgile » Wed Apr 20, 2011 8:37 am
Tiggz1 wrote:Awesome feature - Thankyou!!
Thank for reply Tiggz1 :)
just delete path in background layers.
best regard :)
macgile
Postby wwwyoose » Mon Apr 25, 2011 9:02 am
hi
I am trying this plugin and it dont work whit the short cut. alt+q.
I have mac are ther some diffrent short cut?
Best Achim
wwwyoose
Postby macgile » Tue May 10, 2011 7:15 pm
wwwyoose wrote:hi
Best Achim
Thank's wwwyoose :)
This bug is fixed in the next version with many other improvements
comming soon!
best regard
macgile
Postby vidy » Thu May 12, 2011 3:53 am
macgile wrote:This bug is fixed in the next version with many other improvements
comming soon!
best regard
:thumb: :bounce: :ecstatic:
still so much to learn..
vidy
Next
Return to Plugins
Users browsing this forum: cbaritello, rifakharc and 14 guests
