[Plugin] (TIG) Rotate Plan View v1.1 20110316
Postby leminilab » Thu Mar 03, 2011 4:31 pm
Admin edit:
I have moved the topic to the Plugins folder and added the proper tag. The plugin can be found further down this page in this post.
(Gai...)
Hi everyone,
I'm trying to do something simple but... Can't figure out how... :roll:
I'd like to have this plan view rotated 45 degrees to better fit my screen...
I don't have a clue how to do that... :oops:
- "Live every day as if it were your last and then some day you'll be right."
- "ThomThom rules!!!"
leminilab
Premium Member
Premium Member
Re: rotate plan view
Postby TIG » Thu Mar 03, 2011 4:59 pm
Here some short code to do it
Code: Select all
require 'sketchup.rb'
class Rotateplanview
 def initialize(angle=45.0)
  model=Sketchup.active_model
  view=model.active_view
  camera=view.camera
  up=camera.up
  return if up==Z_AXIS
  eye=camera.eye
  target=camera.target
  persp=false
  tr=Geom::Transformation.rotation(target, Z_AXIS, angle.degrees)
  up.transform!(tr)
  newcamera=Sketchup::Camera.new(eye, target, up, persp)
  view.camera=newcamera
  Sketchup.send_action("viewZoomExtents:")
end#class
Copy/paste it into a file named Rotateplanview.rb in the Plugins folder.
To use set up your Plan [Top] view, without Perspective and in the Ruby Console type Rotateplanview.new to rotate the camera 45 degrees clockwise, repeat to rotate it another 45 degrees etc. The extents are zoomed after each rotation.
To do other angles provide an angle value in degrees - e.g. Rotateplanview.new 10 rotates the view 10 degrees clockwise or Rotateplanview.new -30 rotates the view 30 degrees counterclockwise.
When you are happy with it save the view to a new Scene tab so you can return to it later.
Global Moderator
Postby leminilab » Thu Mar 03, 2011 5:14 pm
TIG wrote:Here some short code to do it
Code: Select all
  camera=view.camera
  up=camera.up
  eye=camera.eye
  persp=false
  up.transform!(tr)
end#class
:shock: TIG, Wow!
To have you replying to one of my question is an honor! I really admire you coding gurus!
You should all live together in a tiny house as a community along with ThomThom, Chris Fullmer, Whaaat (forgot how many A's...), Fredo6, Didier Bur...
Seriously, Michael Jackson would have replied, I wouldn't have been more honored!
I'll try this quickly! Thank you so much! (where's the worshipping smiley, the one that's on his knees... Whatever... You get the point! :D )
Nicolas
leminilab
Premium Member
Premium Member
Postby leminilab » Thu Mar 03, 2011 6:27 pm
Errr... I got an error message saying :
Rotateplanview.new
Error: #<NameError: (eval):54: uninitialized constant Rotateplanview>
(eval):54
What I did is copy the code you wrote in a notepad file and saved it as Rotateplanview.rb and pasted it in the plugins Folder.
Then I typed the trigger piece of code in the ruby console, hit enter and voilà!
:? <-- I have absolutely no idea what this error message mean...
leminilab
Premium Member
Premium Member
Postby TIG » Thu Mar 03, 2011 6:50 pm
Did you restart Sketchup ?
I suspect not :?
It should work after the script is auto-loaded - which is happens when Sketchup starts...
Global Moderator
Postby leminilab » Thu Mar 03, 2011 9:10 pm
TIG wrote:Did you restart Sketchup ?
I suspect not :?
Yes, I did restart Sketchup. Actually my computer froze a little bit and almost crashed while SU was open :?
leminilab
Premium Member
Premium Member
Postby TIG » Thu Mar 03, 2011 11:32 pm
Have you tried running it with the Ruby Console open to see if there are errors ?
Did it rotate the plan view even if it was flaky ?
Did you have a plan view set BEFORE using it ?
Global Moderator
Postby leminilab » Fri Mar 04, 2011 12:05 am
TIG wrote:Have you tried running it with the Ruby Console open to see if there are errors ?
It didn't rotate the view at all. :cry:
The ruby console was open and it returned this error again:
(eval):54
As you can see I already had a plan scene saved.
leminilab
Premium Member
Premium Member
[Plugin] rotate plan view v1.1
Postby TIG » Fri Mar 04, 2011 11:08 am
Clearly the code isn't loading properly for some reason I can't ascertain at a distance...
Here's a ready-made rb file that should work... please remove your attempt...
Here' v1.1
(c) TIG 2011
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
File:
Put the file Rotateplanview.rb in the Plugins folder.***
Usage:
return to it later.
Note: v1.1 includes a View Menu > 'Rotate Plan View' item and there is
also a 'Rotate Plan View' toolbar that can be activated from the
View > Toolbar menu, ***this needs the icon Rotateplanview.png in the
../Plugins/TIGtools subfolder.
If you use one of these tools this way you will get a dialog asking for
the angle, the default is +45 degrees. otherwise it works as above...
Donations: by PayPal to info @ revitrev.org
Version:
1.0 20110304 First issue.
1.1 20110316 Menu/Dialog/Toolbar item added.
Download/install this Plugin's latest RBZ from the PluginStore...
Download
Global Moderator
Postby leminilab » Fri Mar 04, 2011 1:06 pm
TIG wrote:Clearly the code isn't loading properly for some reason I can't ascertain at a distance...
Rotateplanview.rb
:berserk: :sketchstatic: :family: :ecstatic: :fro: :bounce: :enlight: :D :lol:
This is soooooooooooooooooooooooooooooooooooooooooooo great!
For your info and for the sake of my own public humiliation, I had pasted the rb file in my SKetchup 8 plugins folder... And was usin SU7! :oops: :oops: :oops: :oops:
Thank you so much! :thumb:
leminilab
Premium Member
Premium Member
Postby Gaieus » Fri Mar 04, 2011 1:33 pm
:roflmao:
Postby leminilab » Fri Mar 04, 2011 5:51 pm
TIG, this is really a must for me! Thank you so much! This should be a default option in Sketchup.
And it really saved my life on this :
Oh and by the way Gaieus, I had read one of your post on a google forum (http://www.google.com/support/forum/p/s ... 63b7&hl=en) before posting my question but for some reason I couldn't make my head to apply your suggestions to my situation...
I just didn't understand if this post relates to my problem or not... (I know it's scary... I scare myself very often :?)
Again, I wish my the world would be as effective and generous as this community... :roll:
Thanks everyone!
Nicolas
leminilab
Premium Member
Premium Member
Re: [Plugin] (by TIG) rotate plan view
Postby cobb89 » Wed Mar 16, 2011 1:46 pm
how can i use this rotate plan view plugin??
cobb89
Banned
Postby Rich O Brien » Wed Mar 16, 2011 1:51 pm
Rich O Brien
Administrator
Postby Dave R » Wed Mar 16, 2011 2:34 pm
Thank you, TIG. This offers some interesting options for scene creation.
Global Moderator
Postby Rich O Brien » Wed Mar 16, 2011 2:35 pm
No problem Dave, glad I could help... 8-)
Rich O Brien
Administrator
Postby cobb89 » Wed Mar 16, 2011 3:39 pm
can anyone create a toolbar button for this plugin??
cobb89
Banned
Postby TIG » Wed Mar 16, 2011 3:41 pm
As well as a toolbar you'd need a dialog for the angle ?
Global Moderator
Postby Dave R » Wed Mar 16, 2011 3:44 pm
Seems to me entering the text into the console works very nicely. And I don't have to find room for another toolbar.
Oh, and Rich, I very happy to have your assistance while your wife is ironing. ;)
Global Moderator
Postby Rich O Brien » Wed Mar 16, 2011 3:48 pm
Prioritize Dave...Prioritize ;)
Rich O Brien
Administrator
Postby cobb89 » Wed Mar 16, 2011 4:19 pm
TIG wrote:As well as a toolbar you'd need a dialog for the angle ?
yeah....whatever is possible.... :roll:
cobb89
Banned
Re: [Plugin] (TIG) Rotate Plan View v1.1 20110316
Postby TIG » Wed Mar 16, 2011 4:59 pm
Here's v1.1 viewtopic.php?p=313264#p313264
It includes View menu item and toolbar with dialog entry of angles - the Ruby Console version works as before for those of you not wishing clutter... The toolbar only gets made if there's a png file so that's a simple way to stop that being created if you don't want it!
Global Moderator
Postby Michaelv » Wed Mar 16, 2011 6:06 pm
TIG, can I use it to include into a tool I'm working on. It's an easy simple rotate tool, and I'd like to include this as planview rotation when hovering over the origin.
Michaelv
Postby TIG » Wed Mar 16, 2011 8:18 pm
Michaelv wrote:TIG, can I use it to include into a tool I'm working on. It's an easy simple rotate tool, and I'd like to include this as planview rotation when hovering over the origin.
No problem, just give some acknowledgment in the header :D
Global Moderator
Postby cobb89 » Mon Mar 21, 2011 1:31 pm
TIG wrote:Here's v1.1 viewtopic.php?p=313264#p313264
Thanks a lot!! :D
cobb89
Banned
Postby Bob James » Sat Apr 02, 2011 8:21 pm
It seems that whenever I go to parallel projection and top view the scene is never at the angle I want it, so this plugin is really handy.
Okay, so I'm lazy, but it would be very nice to speed up workflow if the plugin did the preliminary steps automatically: set camera to parallel projection and set to top view 8-)
Bob James
Premium Member
Premium Member
Postby EarthMover » Sat Apr 02, 2011 9:15 pm
Great idea and very useful. Thanks TIG!! :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby dan19936 » Tue Apr 26, 2011 9:32 pm
Also available is the free Camera Controls by Smustard
http://www.smustard.com/script/CameraControls
Dan
dan19936
Postby jwliii » Tue Feb 19, 2013 4:21 pm
Great Great Great - Donated!
jwliii
Postby seasdes » Thu Feb 28, 2013 12:03 pm
This is a wonderful tool. I was made aware of it by Dave.
Is there a way to lock the scene so that it cannot be accidentally dragged away from its intended orientation?
Using Sketchup Pro 2019
seasdes
Next
Return to Plugins
cron
Users browsing this forum: No registered users and 5 guests
