[Plugin] Quadrilateralizer v1.1 20110215
Postby TIG » Mon Feb 14, 2011 2:03 pm
TIG (c) 2011
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
Script: Quadrilateralizer.rb
Usage:
Select faces. Note that other entity-types in the selection are ignored.
Run 'Quadrilateralizer' from the 'Plugins' menu.
If there are no faces in the selection there is an error-message, it exits.
If all selected faces are already quads then you are asked if you want to
split them further: 'Yes' to redivide selected quad faces or No' to abort.
If the selected faces are not equivalent to 'all connected faces' then you
are warned: 'Yes' to continue, 'No' to abort. It is recommended that all
connected faces are processed together [treble-click a face to select all]
to ensure that all connected faces become quadrilaterals; otherwise later
processing of these non-quad faces could result in the connected quads
being made into non-quads, or if all connected faces were selected the
non-quads would split but the previously made quads will be split again -
it could get messy - this might be what is required... but usually
processing all connected at once is the best method.
All selected faces are now split into quadrilaterals ['quads'].
Note that any preexisting quads in the selection will also be split
because splitting any adjacent non-quads will force these existing quads
into non-quads anyway.
UV texture mapping etc is kept.
It is one step undo-able.
The vertices of these quad faces can be adjusted with the Move tool...
Donations: By PayPal.com to info @ revitrev.org
Version:
1.0 20110214 First Release.
1.1 20110215 More info and percentage progress reported in Status Bar.
Global Moderator
Re: [Plugin] Quadrilateralizer v1.0 20110214
Postby Gaieus » Mon Feb 14, 2011 2:09 pm
OK, first to download so first to thank. I know why Pete asked for it...
:thumb:
Will it move vertices slightly to create quads from non co-planar tris for instance (or does it only subdivide)?
Postby solo » Mon Feb 14, 2011 2:13 pm
Sweet!! cannot wait to give it a run.
Thanks a bunch.
http://www.solos-art.com
solo
Global Moderator
Postby Gaieus » Mon Feb 14, 2011 2:19 pm
Some quads are created from tris in a way that they have co-linear edges. This may not be an issue in many apps but SDS2's smooth tool cannot handle these, Pete.
TIG: still great tool, thanks!
Postby TIG » Mon Feb 14, 2011 2:30 pm
Gaieus wrote:Some quads are created from tris in a way that they have co-linear edges. This may not be an issue in many apps but SDS2's smooth tool cannot handle these, Pete.
Most quads will not have co-linear sides [although thin slivers of triangles do approach co-linearity] - but those that do you can manually Move a vertex as desired.
The subdivision can produce unoptimized quads anyway that would benefit from some adjustments to some vertex locations...
This is only v1.0, I only starting thinking about writing it a couple of hours ago :roll:
Any feedback or suggestions on improvements welcomed...
Global Moderator
Postby chloesdad » Mon Feb 14, 2011 2:55 pm
Thank you very much TIG.
chloesdad
Postby TIG » Mon Feb 14, 2011 3:01 pm
I can envisage another tool to optimize selected coplanar quads...
It tests a faces for their vertices' 'concave-ness'/co-linearity and adjusts the concave/linear vertex location until it is just convex... I suspect this might involve a lot of tail-chasing as one faces concave vertex could be its neighbor's convex vertex :roll:
Alternatively if any of the Quadrilateralized faces have co-linear or concave vertices select all and Quadrilateralize them a second time - that should fix them - although the mesh will then be much finer :roll: BUT there's no such thing as as a free lunch...
Global Moderator
Postby CAntonis » Mon Feb 14, 2011 3:14 pm
Thanks so much TIG!
One question though: Is this gonna help exporting a model to other modelers with greater detail, is it just because quad faced geometry is better or both?
Downloaded already and I ll be checking for updates!!!!
Again THANKS A BOUNCH!
CAntonis
Postby Didier Bur » Mon Feb 14, 2011 3:53 pm
Hi TIG,
When translating into french, I came across this (line 82):
Code: Select all
return nil if UI.messagebox("Quadrilateralizer:\n\nThe Selected Faces are NOT\nALL of the Connected Faces.\nDo you want to Continue ?",MB_YESNO)==7
Isn't this message confusing or wrong ?
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby TIG » Mon Feb 14, 2011 8:04 pm
Didier Bur wrote:Hi TIG,
Code: Select all
The selected-faces are not ALL of the connected-faces.
Do you want to continue?
Les choisir-faces ne sont pas tous les relier-faces.
Voulez-vous continuer ?
Global Moderator
Postby Didier Bur » Mon Feb 14, 2011 8:46 pm
Les faces choisies ne font PAS TOUTES partie des faces connectées :berserk:
Didier Bur
Didier Bur
Postby TIG » Mon Feb 14, 2011 9:04 pm
Didier Bur wrote:Les faces choisies ne font PAS TOUTES partie des faces connectées :berserk:
I couldn't have put it better myself!
Je n'aurais pas pu mieux dire moi-même! :D
Global Moderator
Postby Krisidious » Mon Feb 14, 2011 10:11 pm
you Rock Tig...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Ben Ritter » Mon Feb 14, 2011 10:40 pm
TIG, thank you.
Ben Ritter
Postby EarthMover » Mon Feb 14, 2011 11:46 pm
:thumb: :thumb: Thanks bro!
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Rich O Brien » Tue Feb 15, 2011 10:43 am
Thanks TIG....any chance of a progress bar?
Rich O Brien
Administrator
Re: [Plugin] Quadrilateralizer v1.1 20110215
Postby TIG » Tue Feb 15, 2011 11:08 am
Here's v1.1 viewtopic.php?p=309120#p309120
More info and percentage progress now reported in the Status Bar.
Global Moderator
Postby Rich O Brien » Tue Feb 15, 2011 11:09 am
That was quick :shock:
Rich O Brien
Administrator
Postby TIG » Tue Feb 15, 2011 11:11 am
Sorry it took so long I was at the corner-shop buying some milk when you posted :shock: ;)
Global Moderator
Postby Rich O Brien » Tue Feb 15, 2011 11:15 am
Now that you're around and idle, how about this ;)
Rich O Brien
Administrator
Postby Gaieus » Tue Feb 15, 2011 11:24 am
Thanks TIG. The more I think about this plugin, the more I like it. It can have so many areas to use.
Postby dedmin » Tue Feb 15, 2011 11:25 am
TIG wrote:Sorry it took so long I was at the corner-shop buying some milk when you posted :shock: ;)
So, if I drink more milk maybe I can start writing wonderful plugins as You do?
:roll: :enlight:
dedmin
Postby Gaieus » Tue Feb 15, 2011 11:27 am
Or eat more cookies (look at ThomThom). :roll:
Maybe both - but if you drink more beer, you will grow a red beard like Rich has (or a belly like me).
Postby dedmin » Tue Feb 15, 2011 11:28 am
Gaieus wrote:Or eat more cookies (look at ThomThom). :roll:
:lol: :lol: :lol:
dedmin
Postby troyhome » Thu Mar 10, 2011 1:46 am
thanks for this great plug!
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
Postby TIG » Fri Mar 11, 2011 5:15 pm
This new tool QuadsFrom2Tris viewtopic.php?p=315130#p315130 might help fix a few connected triangles into quads... rather than affect every preexisting quad in a surface by re-quadding it...
Global Moderator
Postby bagou01 » Wed Jun 27, 2012 2:16 pm
i'm sorry i'm a bit of a noob here, but i can't manage to get anything else then SU crashes with quadrilateralizer...
i tried on a simple face as well as on a complicated one, no way to have it done by my side :-/
bagou01
Postby greenskp » Sun Jun 16, 2013 4:56 pm
I loved it. Now i can use xNormal program.
greenskp
Premium Member
Premium Member
Return to Plugins
Users browsing this forum: deaneau, ermalbeluli, ikiyaskur, rutujadhote1822, shfkemfla and 9 guests
