[Plugin] Normal map maker
• Page 1 of 1
[Plugin] Normal map makerI got the inspiration from Chris Fullmer's version
Re: [Plugin] Normal map makerHow is this different?
For one thing, it uses a toolbar. for another thing, it can also preform the same operation on edge vectors. for a third thing, it doesn't remove the colors of the faces after it's done. for a forth thing, this plugin doesn't export an image of the normals, it's simply used for looking at the normals/vectors of faces/edges in 3D. Plus, a lot of things look cool with this plugin and a black background ![]() Re: [Plugin] Normal map makerI'd recommend you wrap your code into modules instead of leaving all that in the global namespace.
Re: [Plugin] Normal map makerCool, sounds like something fun to do late at night while listening to some heavy trance music or something hehehe.
• Page 1 of 1
