[Plugin] SmartDrop Beta
Postby a4chitect » Mon Dec 24, 2007 1:11 am
Available in the PluginStore
Modif. notes : v 1.4: works even after using the TBD's Randor (different scales and rotations of entities)
Credits : TBD for the drop.rb and further inspiration randor.rb, cphilips for his small trick http://groups.google.com/group/sketchup ... 9554881c5a and the SU community
The latest version is available in the PluginStore
Download
4
a4chitect
PluginStore Author
PluginStore Author
Re: WIP: SmartDrop ruby
Postby Fletch » Mon Dec 24, 2007 1:38 am
could come in very handy indeed! thanks!
Fletch
Twilight Render
Postby tbd » Wed Dec 26, 2007 2:28 pm
nice work a4chitect
SketchUp Ruby Consultant | Podium 1.x developer
http://plugins.ro
tbd
Postby Fletch » Fri Jan 11, 2008 8:10 am
Note it changes the definition of group to add a .definition method.
This makes group more similar to componentInstance.
from your google group link... I find this fascinating as it's one the many little annoying things about SU that would have been fixed if they hadn't been bought by google... makes no sense why the axes work the way they do in SU6... either they should work like SU5, or allow you to adjust the axes w/out making them a component. obviously could be done. :roll:
a tool simply in the SU shell called 'reset axes' that only appeared for Groups would be very nice... since you can't do that in SU now.
Fletch
Twilight Render
Re: [Plugin] WIP: SmartDrop ruby
Postby xrok1 » Sat Mar 07, 2009 9:40 pm
this one definately deserves a bump :D
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby solo » Sat Mar 07, 2009 9:55 pm
I agree.
I never knew it existed, and what a great script it is.
http://www.solos-art.com
solo
Global Moderator
Postby xrok1 » Sat Mar 07, 2009 10:06 pm
i noticed that ver.1.4 also lets you undo with one action. :berserk: in ver.1 you had to undo each drop and each rotation.
xrok1
Postby NewOne » Sun Mar 08, 2009 12:18 am
Wow !! that's cool! :berserk:
You did it :D It was a discution about this viewtopic.php?f=180&t=14543&p=110383&hilit=+fish#p110359 but I never thought somebody will go on.
I see that the script drops only if object have a face on bottom. I tried to drop vertical planes or lines and did not worked.
NewOne
Postby xrok1 » Sun Mar 08, 2009 12:59 am
NewOne wrote:Wow !! that's cool! :berserk:
the original drop.rb will drop lines to intersection but they won't be rotated. ;)
xrok1
Postby pilou » Mon Mar 09, 2009 4:20 pm
Works cool with the Chris Fullmer "Select Lines by Length" + "Components onto faces" ! :enlight:
Speedy Galerie
Top SketchUcator
Postby majid » Mon Mar 09, 2009 8:45 pm
thanx for handy script. i tested old version and 1.4 version. old one workes fine , but recent one just unhides the component!!!! and nothing!
what is wrong whit me? or something about the script?
My V-Ray book for architects: https://goo.gl/cz1oRc
majid
Top SketchUcator
Postby caddict » Fri Mar 20, 2009 8:13 pm
very nice!! Thanks!!
caddict
Postby xrok1 » Mon Apr 26, 2010 4:32 pm
bump :mrgreen:
xrok1
Postby bagatelo » Tue Apr 27, 2010 4:12 am
bagatelo
Postby ckho1985 » Fri Oct 22, 2010 4:53 pm
i try to run it with Skup 8, however without success. anyone tried?
ckho1985
Postby shura » Fri Oct 22, 2010 11:01 pm
Hi ckho1985, maybe Chris Fullmers Components onto Faces works in SU8. It gives similar results.
xxx
shura
Postby ckho1985 » Sat Oct 23, 2010 12:05 am
I tried, but i found it is really difficult to use... or am I doing something wrong? i selected a grouped object and the face I want to drop on, however its not doing it.
I miss smartdrop, just one click then it sits.
ckho1985
Postby shura » Sat Oct 23, 2010 12:33 am
Like the name says, it has to be components, not groups. ;)
shura
Postby Chris Fullmer » Sat Oct 23, 2010 2:58 am
I just tried smart drop with SU 8, and it worked like a charm. What exactly about it is not working?
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby ckho1985 » Sat Oct 23, 2010 10:29 pm
Chris Fullmer wrote:I just tried smart drop with SU 8, and it worked like a charm. What exactly about it is not working?
that's very strange. I assume there would be just one file (smartdrop.rb) to copy right? However, on my SU8, the smartdrop function is not showing at all. any idea why?
ckho1985
Postby Chris Fullmer » Sat Oct 23, 2010 10:54 pm
You mean there is no command visible? You really need to specify what the problem is. For example, you try to run it, and SU crashes. You try to run it, and your entire model disappears. You try to run it and nothing seems to happen. You install it and SU no longer opens. You install it, but can not find how to start the plugin. Please help us understand what the problem is.
If you just can't figure out where to start it, it is in the right click menu when you have components selected.
Good luck,
Chris
SketchUp Team
SketchUp Team
Postby ckho1985 » Sat Oct 23, 2010 11:33 pm
Sorry Chris as i didnt clarify the matter. What I have done was copied the rb file into the plugin file. However, when I loadup SU. I could not find the smartdrop function, not in the plugin list, nor right click, nor help. I though there was an icon for the smartdrop tool, back in su7 (maybe I am wrong), and it wasnt there. btw, everything else was find, no crash no nothing.
um... I think I should repair my su8 and re-download the rb file.
ckho1985
Postby Rich O Brien » Sat Oct 23, 2010 11:43 pm
Rich O Brien
Administrator
Postby Niffler » Tue Nov 15, 2011 3:47 am
solo wrote:I agree.
Hey Solo,
You said you are for hire, is that right? I've been to your website and...how do you hire a god?!
Niffler ;-)
Niffler
Postby brookefox » Fri Apr 27, 2012 1:55 am
For me there are some issues.... job does not complete, perhaps owing to component bumping?
Merci, Pilou for your nice image tut, posted earlier. :enlight:
~ Brooke
brookefox
Postby brookefox » Fri Apr 27, 2012 1:59 am
Yes, component bumping appears to have been the problem.
~ Brooke
brookefox
Postby pilou » Fri Apr 27, 2012 2:07 am
Use the cool Thomthom RayTracer! :thumb:
Object must be in a box with an horizontal base : Drop by Bounds
So will work with your example!
careful than an inclined object yet droped don't block next following ;)
by Thomthom
Speedy Galerie
Top SketchUcator
Re: [Plugin] SmartDrop Beta issues
Postby mlefevre » Fri Jan 10, 2014 3:22 pm
I'm trying to drop a solar array onto a surface using this plugin and having some issues. The panels are touching end to end, and when I drop them to the surface, either individually or all together, some of the components will turn up on end and others will lay plat on the surface. Any thoughts?
I'm using SU 8 Pro.
Thanks!
mlefevre
Postby Mra » Tue Jul 29, 2014 7:48 am
Thanks for the plugin. But it changes the angle of objects?
So if I have a pole, I drop it to the surface but this plugin in makes it no longer vertical. Is there an option to change this?
Mra
Postby pelikan21 » Mon Oct 06, 2014 8:16 pm
Thanks for plugin. But I have some problem while adding this plugin from extension part of windows. I can't see anything related with smart drop while selecting some component in SketchUp.
pelikan21
Next
Return to Plugins
Users browsing this forum: breznica, carrjorl, Hantatiana, tridang10081 and 13 guests
