[Plugin] Model Info
[Plugin] Model Info
Postby thomthom » Thu Dec 09, 2010 2:09 pm
Overview
Outputs the model statistics to either console or file.
Version 1.1.0
Count the triangles of each face. In tests this is more than three times slower - so it has been made into an extended function.
Counting triangles is more accurate indication to how complex the model is. As the following screenshot illustrate - the two scenes has identical number of faces, but the number of triangles required to generate the faces is significantly different due to the inner holes in the upper example.
Version 1.2.0
Outputs the component statistics.
Access
Plugins > Model Info
Features
  • Statistics to File
  • Statistics to Console
  • Extended Statistics to File (1.1.0)
  • Extended Statistics to Console (1.1.0)
Requirements
  • SketchUp 6 or newer - ( Other versions untested )
  • TT_Lib2 (v2.4.0)
Download
Footprint
<Sketchup>/Plugins/
tt_model_info.rb
PluginStore Author
PluginStore Author
Re: [Plugin] Model Info (1.0.0) — 09 Desember 2010
Postby Gaieus » Thu Dec 09, 2010 2:17 pm
Nifty! :thumb:
Postby solo » Thu Dec 09, 2010 2:19 pm
Thom, how about a call out on how many poly's have been used?
http://www.solos-art.com
solo
Global Moderator
Postby thomthom » Thu Dec 09, 2010 2:38 pm
You mean triangles?
PluginStore Author
PluginStore Author
Postby Rich O Brien » Thu Dec 09, 2010 2:53 pm
Doesn't Fredo have this?
viewtopic.php?t=30976
Rich O Brien
Administrator
Postby solo » Thu Dec 09, 2010 2:59 pm
Ah, cool one, never seen that before, thanks Rich.
Thom, I guess there is a lot more to it than just reporting amount of faces as SU does not use triangles, they are n-gons.
Kinda hard to figure out SU's limit due to this inconsistency, had it been triangle based one could get a clearer idea.
solo
Global Moderator
Postby Gaieus » Thu Dec 09, 2010 3:18 pm
If you export your model to 3ds or dae, it will get triangulated. When re-importing without merging co-planar faces, you get a clearer poly count with triangles.
Postby thomthom » Thu Dec 09, 2010 3:24 pm
solo wrote:Thom, I guess there is a lot more to it than just reporting amount of faces as SU does not use triangles, they are n-gons.
Can extract the internal triangulation. SU makes that available to the API. My Probe plugin lets you inspect how SU triangulates faces.
PluginStore Author
PluginStore Author
Re: [Plugin] Model Info (1.1.0) — 09 Desember 2010
Postby thomthom » Thu Dec 09, 2010 3:49 pm
Ok. Did a quick update - added triangle count if you choose Extended Model Info. (Note it's at least three times slower.)
PluginStore Author
PluginStore Author
Re: [Plugin] Model Info (1.1.1) — 09 Desember 2010
Postby glro » Thu Dec 09, 2010 4:47 pm
thomthom wrote:Overview
this is interesting...
when you choose statistics, you have 2 options:
> entire model (that's what you exported)
> components
could you do the same job, but for "components" instead, and precisely with the developped hierarchy?
glro
Postby thomthom » Thu Dec 09, 2010 8:47 pm
glro wrote:could you do the same job, but for "components" instead, and precisely with the developped hierarchy?
You mean the stats for a selected component?
What do you mean by the "developed hierachy"?
PluginStore Author
PluginStore Author
Postby glro » Thu Dec 09, 2010 9:30 pm
the stats for components, instead of "for the whole model"
this...
glro
Postby thomthom » Thu Dec 09, 2010 9:40 pm
Oooh... I never noticed that option before! :shock:
PluginStore Author
PluginStore Author
Postby glro » Thu Dec 09, 2010 10:03 pm
thomthom wrote:Oooh... I never noticed that option before! :shock:
if you choose this option, the statistics include the nestled components
the whole problem is: how to retrieve this information?
i think i might have a solution coming, but since it is not finished, i have to wait
glro
Postby thomthom » Thu Dec 09, 2010 10:10 pm
I can make it produce that info - just got to wait until next week. Moving apartment this weekend.
PluginStore Author
PluginStore Author
Postby thomthom » Mon Dec 13, 2010 1:19 pm
Version 1.2.0
PluginStore Author
PluginStore Author
Re: [Plugin] Model Info (1.2.0) — 13 Desember 2010
Postby Dave R » Mon Dec 13, 2010 3:20 pm
Thomthom, thank you for this cool plugin. I have noticed an odd thing, though. I copied and pasted a few components from a file called "spinet desk" to a new file and saved it as a new file. Evidently the plugin is still looking at the other, closed original file and giving the stats for that as well. Or is it possible the console isn't cleared when switching to a different SKP file? Is it possible to clear the contents of the console before processing and displaying a new run of the plugin?
Global Moderator
Postby thomthom » Mon Dec 13, 2010 3:30 pm
Dave R wrote:vidently the plugin is still looking at the other, closed original file and giving the stats for that as well. Or is it possible the console isn't cleared when switching to a different SKP file?
The console output is not interactive. Just a history of the output. You find the latest output at the bottom. Notice that in your screenshot it says "Drawer.skp" further down.
Dave R wrote:Is it possible to clear the contents of the console before processing and displaying a new run of the plugin?
I have a Windows hack I could add. Don't know how to do it for OSX. ...but you might have some that don't want it cleared... I'd rather not add too many options to this. It's just a quick and dirty plugin.
PluginStore Author
PluginStore Author
Postby Dave R » Mon Dec 13, 2010 3:41 pm
Understood. Thank you for this.
Global Moderator
Postby Ben Ritter » Mon Dec 13, 2010 5:29 pm
Thank you again TIG.
Ben Ritter
Postby f123f0507 » Sun Jul 21, 2013 5:08 am
f123f0507
Postby simMonster » Fri Nov 16, 2018 11:32 pm
Is it possible to extract the time spent on a sketchup file. If anyone has any idea how this could be possible, i would greatly appreciate it. I know there is a plugin that can be used but I need to extract the time spent on an old files.
simMonster
Postby Dave R » Mon Nov 19, 2018 1:31 pm
simMonster wrote:Is it possible to extract the time spent on a sketchup file. If anyone has any idea how this could be possible, i would greatly appreciate it. I know there is a plugin that can be used but I need to extract the time spent on an old files.
Unless you had something recording the start and stop time when you were working on the model, there wouldn't be any time information to extract. You're probably going to have to guess at how much time was spent on old models.
Global Moderator
Postby mtanure1234 » Fri Jun 28, 2019 2:39 am
Nice, but where i can see the file size? is there a plug in that can do this?
mtanure1234
Return to Plugins
cron
Users browsing this forum: Jio76, Kozmos, oscardiazrojas70, shuva and 11 guests
