SketchUcation Plugin Store
[Plugin] TECLA 0.1
[Plugin] TECLA 0.1
Postby bomastudio » Tue Nov 30, 2010 5:51 pm
Hi all,
I wrote a plugin for Architects: TECLA. It adds new tools for insert walls, floor, columns, like in ArchiCAD, AllPlan ecc. It's free. And it's is in beta stage. I wish it is usefull.
some video explain it better:
01_IMPORT DXF in SketchUp free version
02_BUILD CONTOUR FROM A GOOGLE EARTH MESH SITE
the link to the home page of the project
http://sites.google.com/site/teclait/
README:
TECLA is available as a setup.exe: this will be installed, as default, in the SketchUp 8/plugin/ folder. Here will be created a folder TECLA and two script: TECLA and TECLA_edit.
After TECLA is installed, the setup will lauch for you the installation process of WxSU, a required library for use TECLA: as default, wxSU has target SketchUp 7/plugin, so if your version of SU is 8 YOU NEED TO MANUALLY CORRECT THE PATH for 7 to 8, i.e:
form
... /Google SketchUp 7/plugin
to
... /Google SketchUp 8/plugin
The wxSu library must be installed outside the TECLA subfolder but INSIDE the plugin folder.
Good work!!
bomastudio
Operating system: Linux
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Advanced
Re: TECLA 0.1 release
Postby solo » Tue Nov 30, 2010 5:56 pm
Got a link?
My site
Quod gratis asseritur, gratis negatur.
solo
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby bomastudio » Tue Nov 30, 2010 6:01 pm
Sorry, posted the link! :D
bomastudio
SketchUp version: 8
Postby Didier Bur » Tue Nov 30, 2010 10:08 pm
An installation guide or readme file will be handy... or do I get it after running the setup (sorry, I don't like setup.exe's)
Do I need to download and install wxSU to run TECLA ?
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby utiler » Wed Dec 01, 2010 1:21 am
Sounds interesting Bomastudio.... Keen to have a look!!!
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby bomastudio » Wed Dec 01, 2010 3:15 pm
Didier Bur wrote:Hi,
Yes, after running the setup you will read (in italian only at the moment, sorry .... :? ) some readme.
Didier, this is the first time I publish some code, so I need more guide to be correct toward other programmers. For one of the tool (wall tool) I start studing one of your script (thank you very much, you're great!!). Where you suggest me to tell the world I start from your script?.
Didier Bur wrote:Do I need to download and install wxSU to run TECLA ?
My setup.exe will install for you, with the warning that you MUST CHOOSE THE SAME FOLDER for both TECLA and WxSU.
thank you very much for the future suggestion.
bomastudio
SketchUp version: 8
Postby bomastudio » Wed Dec 01, 2010 3:22 pm
utiler wrote:Sounds interesting Bomastudio.... Keen to have a look!!!
Thank you for your interest! Please, give me the more feedback you can!!
bomastudio
SketchUp version: 8
Postby archano » Wed Dec 01, 2010 5:44 pm
visto che di italiani sul sito se ne vedono pochi, i complimenti te li faccio nella ns bella lingua ... bel lavoro ..ora sono curioso di vedere gli altri moduli...!!! :thumb:
archano
Postby bomastudio » Wed Dec 01, 2010 6:18 pm
archano wrote:visto che di italiani sul sito se ne vedono pochi, i complimenti te li faccio nella ns bella lingua ... bel lavoro ..ora sono curioso di vedere gli altri moduli...!!! :thumb:
Grazie 1000!!!
Ho brutte notizie....gli altri moduli verranno non prima dell'anno prox!! :? Vorrei prima finire il modulo architettura.... al momento ho in progetto di finire l'importatore dxf (anche 3D), aggiungere gli strumenti porte/finestre e scale..... spero di aggiornare presto....
bomastudio
SketchUp version: 8
Postby Didier Bur » Wed Dec 01, 2010 6:31 pm
No, do as you like, it depends if my script was just a starting point or not...
Didier Bur
SketchUp version: 8
License type: Pro
Postby archano » Wed Dec 01, 2010 6:43 pm
.. . visto che sono un utilizzatore di archicad fin dalla versione 7 non può che farmi piacere il tuo impegno nello sviluppo di strumenti simili per sketch il che mi permette, tra l'altro, anche un miglior utilizzo "scolastico" dello stesso.. :ecstatic:
archano
Postby bomastudio » Thu Dec 02, 2010 2:33 pm
archano wrote:.. . visto che sono un utilizzatore di archicad fin dalla versione 7 non può che farmi piacere il tuo impegno nello sviluppo di strumenti simili per sketch il che mi permette, tra l'altro, anche un miglior utilizzo "scolastico" dello stesso.. :ecstatic:
Cosa intendi per uso "scolastico"? Mi sembra interessante...
bomastudio
SketchUp version: 8
Postby tridem » Thu Dec 02, 2010 2:58 pm
Scusate se rompo, ma prima che lo faccia un moderatore.... ;)
please, it's not too kind for other users writing in italian, for matters of general interest is recommended you use english, otherwise we have an italian section in the forum (not so attended indeed... :? )
btw congrats bomastudio, it looks very interesting :thumb:
tridem
Postby srx » Thu Dec 02, 2010 4:04 pm
:thumb: Very interesting. Could you make it in English?
srx
SketchUp version: 7
Postby bomastudio » Thu Dec 02, 2010 5:44 pm
tridem wrote:Scusate se rompo, ma prima che lo faccia un moderatore.... ;)
right observation..... where is the italian section?
bomastudio
SketchUp version: 8
Postby bomastudio » Thu Dec 02, 2010 5:45 pm
srx wrote::thumb: Very interesting. Could you make it in English?
I'm working in this direction.... just a few days and it will be translated ....
bomastudio
SketchUp version: 8
Postby tridem » Thu Dec 02, 2010 5:52 pm
bomastudio wrote:.... where is the italian section?
if you want to see the national language sections, you have to join the related usergroup in the User Control Panel.
tridem
Postby dizain » Thu Dec 02, 2010 7:11 pm
Message:
Error loading Files wxSU-Example.rb
Ciao
David
dizain
Postby bomastudio » Fri Dec 03, 2010 12:07 pm
dizain wrote:Message:
When appear this message?
bomastudio
SketchUp version: 8
Postby dizain » Fri Dec 03, 2010 3:54 pm
when I open sketchup.
Winxp
Sketchup pro V7.1.6860
Ciao
David
dizain
Postby bomastudio » Fri Dec 03, 2010 4:55 pm
dizain wrote:when I open sketchup.
Winxp
Ciao
David
Any problem with TECLA? Did you try to use some tool?
bomastudio
SketchUp version: 8
Postby notareal » Fri Dec 03, 2010 7:00 pm
What I seen wxSU can be a little troublesome - personally I have not got problems with it. Perhaps look if some other plugin goes use it too with a conflicting way... Interesting point is that SU8 seems to tolerate wxSU better (at-least that was the experience with SU2Thea).
notareal
Thea Render
Postby dizain » Fri Dec 03, 2010 7:12 pm
I tried it a few tools, everything seems ok.
David
dizain
Postby bomastudio » Sat Dec 04, 2010 9:10 am
notareal wrote:What I seen wxSU can be a little troublesome - personally I have not got problems with it. Perhaps look if some other plugin goes use it too with a conflicting way... Interesting point is that SU8 seems to tolerate wxSU better (at-least that was the experience with SU2Thea).
Well, to be honest, I don't have any other plugins in my SU that use WxSU, so I can't tell if thay goes in conflict!
By the way, in TECLA every tool works in a ruby-module so I think that they doesn't have any problem, but only users can tell me if no .... :shock:
bomastudio
SketchUp version: 8
Postby Edson » Sat Dec 04, 2010 11:33 am
is this supposed to be a windows-only plugin? .exe files do not run on macs.
could this be installed manually?
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby bomastudio » Thu Dec 09, 2010 1:16 pm
not at the moment. I think that in a few weeks I can release an OSX version (manually installable I think ...)
Please, waiting for .... ;)
My work doesn't let me work fully to TECLA ....
bomastudio
SketchUp version: 8
Postby bomastudio » Sat Dec 18, 2010 2:59 pm
I'm translating TECLA to english. In a few days it will be available.
bomastudio
SketchUp version: 8
Postby bomastudio » Mon Jan 24, 2011 8:54 pm
good news: now I can read 3d DXF (3DFACE)
bomastudio
SketchUp version: 8
Re: [Plugin] TECLA 0.1 release
Postby chrisjk » Tue Jan 25, 2011 6:37 pm
This sounds very interesting but I use a Mac.. - looking forward to the OS X version!
Chris
chrisjk
Postby AcesHigh » Wed Feb 02, 2011 4:00 pm
1 - more than one month already passed :D is it already translated to english?
2 - can you post a video of the plugin in action?
AcesHigh
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Next
Return to Plugins
Users browsing this forum: Daniel S, karimtabbara, vutran2511 and 9 guests
