(c) TIG 2010
Explodes a Group, BUT unlike built-in .explode method, which puts Exploded Entities that are on 'Layer0' onto the Layer of the original Group, this keeps all of the Exploded Entities' Layers unchanged.
Usage: explodegroup2layers()
If no argument is given then the current Selection is used and any Groups in it are processed.
If an argument is given and it's a Group then that is processed.
e.g. explodegroup2layers(group)
If an argument is given and it's an Array then any Groups in that Array are processed.
e.g. explodegroup2layers([group1,group2,group3])
Probably most useful inside other tools to keep exploded entities on the expected layers.
[Plugin] Explode Group to Layers
• Page 1 of 1
Re: [Plugin] Explode Group to LayersThis is run via the Ruby Console? Any chance of a little pictorial? I have tried it throught the Console but the second option has my head in a vice
Re: [Plugin] Explode Group to LayersNormally you'll just select some groups and type explodegroups2layers in the Console.
When it's called within another tool you can set it to run on a selection explodegroups2layers() or on one group explodegroups2layers(group) or on an array of groups explodegroups2layers([gp1,gp2,gp3]). Most users will use it the first way. the optional 'arguments' make it more flexible for use within other tools... ![]() TIG
Re: [Plugin] Explode Group to LayersI'm looking for a plugin that creates a new layer for each object in the scene or in the selection, either component or group, without considering subgroups. Has anyone done something like this?
• Page 1 of 1
