[Plugin] Point_Component v2.4 2009
Postby honoluludesktop » Sun Oct 24, 2010 9:04 am
component_pointer_v2.4.zip
[/attachment]
This release, v2.4 improves on pointing a component. It also includes the function to rotate an adjustable ligh beam for "IDX Ceiling Light #01". Right click on any component to rotate.
The current implementation for adjustable lighting is a beta release. It will only point once, on a flat ceiling, light mounted in a vertical position. Pointing whole components do not have these limitations.
I initially wrote this plugin a in order to point lights to aid rendering objects. Right click to select a component, select from the menu "point to component" or "point light fixture beam", then place, and click the mouse pointer on what ever you want the selected component to point its zaxis to. The component, or light beam will rotate on its origin. Most of the time, component axis is in the corner of it's bounding box, not in the center. Move the axis if necessary.
Last edited by honoluludesktop on Tue Aug 02, 2011 11:05 am, edited 12 times in total.
honoluludesktop
In Remembrance
Re: [Plugin} Point_Component
Postby Pixero » Sun Oct 24, 2010 12:27 pm
Thanks.
Pixero
Postby Chris Fullmer » Mon Oct 25, 2010 2:54 am
I like this one, thanks Honolulu!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby honoluludesktop » Mon Oct 25, 2010 4:21 am
Hi Chris, or any one, if you can help me with the above code so the the axis tilt's without rotation, we can improve the plugin.
honoluludesktop
In Remembrance
Postby unclebim » Mon Oct 25, 2010 12:20 pm
Thank you for your work, this plugin already came very handy for pointing Twilight spot lights inside SU, did the job in seconds as the axis center of the lights is centered, I just pointed the light without the fixture for a small change in the z-axis target.
unclebim
Re: [Plugin] Point_Component
Postby kc10 » Sat Nov 06, 2010 3:09 pm
sir sorry for being annoying to many questions. does this plugin works also for my idx?
kc10
Postby Gaieus » Sat Nov 06, 2010 3:33 pm
kc10 wrote:does this plugin works also for my idx?
It should as it is not rendering engine specific but points the SU component. Give it a try!
Re: [Plugin] Point_Component v2.4 2009
Postby honoluludesktop » Fri Dec 10, 2010 3:56 pm
Updated point component plugin includes beta code for pointing IDX light fixtures as an adjustable light for rendering purposes. IDX provides a free download for those who wish to test rotating the beam of a adjustable light fixture. Read the top post for "beta" limitations.
Unrendered image.
Rendered image with adjustable recessed light pointing on picture.
honoluludesktop
In Remembrance
Re: [Plugin] Point_Component v2.6 2009
Postby honoluludesktop » Tue Dec 21, 2010 5:24 pm
Update improves accuracy of rotated components.
honoluludesktop
In Remembrance
Postby carolinebg13 » Tue Jan 22, 2013 3:20 am
Hi Honolulu,
Thanks for posting the plug-in.
For some unknown reasons, I don't have a plugin folder in my computer. I have a MAC.
I am using Sketchup 8 Pro.
Here is what I see inside my computer:
my username - library - application support - Google Sketup 8 - Sketchup - and then these folders:
Autosave, Materials, Old colors
If I don't have a "Plugin" folder, what should I do?
Thank you so much in advance,
Kind regards,
Caroline
carolinebg13
Postby carolinebg13 » Tue Jan 22, 2013 3:57 am
Hi again Honolulu,
Would you happen to have this same plugin in a rbz file? Maybe it could work with my Sketchup 8 Pro?
Thanks again,
Caroline
carolinebg13
Postby Gaieus » Tue Jan 22, 2013 7:44 am
Hi Caroline,
Simply rename the ZIP file extension to RBZ and you can use the install extension function under SketchUp > Preferences > Extensions (in SU version 8)
Postby carolinebg13 » Tue Jan 22, 2013 1:28 pm
Thank you Gai for your quick response.
I tried the Sketchup - Preferences - Extensions - Install Extensions ; with renamed .rbz plugin in the zip file, as unfortunate as it is, there is an error message appearing saying "impossible to install extension"...
Would you happen to have an B plan? Thanks again!
Best regards,
Caroline
Gaieus wrote:Hi Caroline,
carolinebg13
Postby Gaieus » Tue Jan 22, 2013 2:38 pm
Did you rename the original ZIP extension to RBZ? Or something inside the ZIP files? (Sorry, it is not clear to me what you did)
Postby gbterstal » Fri May 03, 2013 12:35 am
Oh.. do I LOVE this plugin. I have been struggling with IDX Renditioner lights for weeks and was even planning to use another rendering tool JUST because of light placement. This tool saved me lots of time and money....
Thanks so much Honoluludesktop.
gbterstal
Postby Frederik » Fri May 03, 2013 9:27 am
gbterstal wrote:Thanks so much Honoluludesktop.
Just for the record...
HonoluluDesktop died a few years ago... August 5th 2011 in San Francisco...
viewtopic.php?f=179&t=40819
Cheers
Kim Frederik
Frederik
Thea Render Support
Thea Render Support
Return to Plugins
cron
Users browsing this forum: filipecadu, komac and 11 guests
