[Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)
• Page 1 of 2 • 1, 2
[Plugin] Caleidos4D Ribbon Pubblic Beta 1.1 (29 oct 2010)(c) Caleidos4D 2010
Permission to use, copy, modify, and distribute this software for any purpose and without fee is hereby granted, provided the above copyright notice appear in all copies. THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. ___________________________________________________________________________ This is not a final version, I am not responsible for any loss or crash your files ----------------------------------------------------------------------------- EDIT 23-Sep-2011 New Download URL: DOWNLOAD Caleidos4D Ribbon Pubblic Beta 1.1 ( http://caleidos4d.blogspot.com/2011/08/ ... ta-11.html ) Usage: download/file.php?id=57357&mode=view A special thanks to Beta Tester: Jim (code original) Chris Fullmer rclub24 thomthom Mike Lucey TIG EarthMover Fredo6 DIEGO-RODRIGUEZ troyhome Caleidos4D Ribbon have only the calls of Plugins, the plugins are not distribuite inside .zip package, the plugins can be downloaded from their website. Changelog: Version 1.1 Language tooltips English Added Frame Materials Iframe detachable added more plugins Version 1.0 Initial The plugins list is: Main Ribbon Added Solid Inspector viewtopic.php?t=30504 Extended Standard Views viewtopic.php?t=19323 Smart Drop viewtopic.php?t=3474 Drop 1.52 http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=122 PurgeAll http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=307 Toggle Units: viewtopic.php?t=11745 Added Front Face: viewtopic.php?t=13380 Layers : viewtopic.php?t=2275 Selection Toys: viewtopic.php?t=14975 Added Frame Materials: Materials Tools viewtopic.php?t=17587 Frame Modelurs Joint Push Pull: viewtopic.php?t=6708 SmartPushPull: viewtopic.php?t=23341 extrude lines: http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=135 Shape Bender: viewtopic.php?t=18210 Round Corner: viewtopic.php?t=20485 Added Curviloft: viewtopic.php?t=28586 Added Tools on Surface viewtopic.php?t=11212 Frame Construction Workplane: viewtopic.php?t=31204 DeleteConLinesOnly: http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=105 DeleteConPointsOnly: http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=106 repair broken lines: http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=334 midpoint http://www.smustard.com/script/Midpoint Center point: http://rhin.crai.archi.fr/RubyLibraryDe ... .php?id=62 delete lines: ??? xline: http://www.smustard.com/script/Xline Construction-Toolbar: viewtopic.php?t=16202 Frame Shapes Shapes: http://download.sketchup.com/downloads/ ... shapes.zip drawhelix13: http://rhin.crai.archi.fr/RubyLibraryDe ... php?id=120 Frame 2D 2D Tools viewtopic.php?t=22091 Frame Projections Projection toolbar v2: viewtopic.php?t=20140 Frame Sculpture Scuplt tool: viewtopic.php?t=20781 Last edited by caleidos4d on Fri Sep 23, 2011 9:41 am, edited 5 times in total.
Re: Caleidos4D Ribbon Public Beta 1One reason I'll never switch to Windows is the new MS ribbon. I'm sorry, but I didn't like Microsoft's ribbon. I found it extremely confusing and counter-intuitive to work with, and I think it ruined Solidworks' otherwise excellent GUI (I'm a "trained in Solidworks" engineer).
But having got that off my chest ( ![]() ![]() Thanks. Tom My book "Let's SketchUp!" Download from here
Re: Caleidos4D Ribbon Pubblic Beta 1
I don't know since I haven't tried, but there is nothing that would prevent it from working. Caleidos4D , Nice interface, well done and thanks. Do you have a plan for providing language translations? I'm not sure how best to implement them in a WebDialog - I know Fredo, TIG, and ThomThom have code for this, so maybe someone could make a suggestion. Hi
Re: Caleidos4D Ribbon Pubblic Beta 1all I'm getting at the link is
"alterVista La risorsa richiesta è accessibile qui " Re: Caleidos4D Ribbon Pubblic Beta 1
I'll be porting VertexTools' translation system to TT_Lib2 - at the moment it has some bits locking it to VT only, but it's not hard to decouple it. Thomas Thomassen — SketchUp Monkey & Coding addict
you have to click "qui" IOviz.com
SU Pro 2017 PC Thea: latest vray4SU latest Re: Caleidos4D Ribbon Pubblic Beta 1
I know the answer to that! ![]() I'll try it. ![]() My book "Let's SketchUp!" Download from here
.... You like shiny things? ![]()
Re: Caleidos4D Ribbon Pubblic Beta 1sorry for my bad English, but would you be so kind to explain how to use? The interface looks interesting but I can not do anything with it
Thank you very much Re: Caleidos4D Ribbon Pubblic Beta 1will this mount up in a side monitor? I have three and don't like losing space on top.
yup, works on a 2nd monitor. had some java errors.. but it's a beta so... Re: Caleidos4D Ribbon Pubblic Beta 1
Thank you... one of my biggest problems is that I don't remember all of my plugins... I do work I don't need to be doing because I forget I don't have to do it any more. toolbars help me remember... a ribbon that's grouping the plugins might be even better. can't wait to try it. Re: Caleidos4D Ribbon Pubblic Beta 1the hover tips are in Italian? French?
is there a way to change the resolution size of the ribbon? mine doesn't fit inside of 1024? is there a way to make your own ribbon preset? Re: Caleidos4D Ribbon Pubblic Beta 1
Thank you Jim, I am honored to know that you liked my work, And thanks to you and Mover2 if My ribbon is born ![]() For translate: in the next version, I will translate the tooltips in English but I also accept suggestions ![]() Re: Caleidos4D Ribbon Pubblic Beta 1
Italian ![]() ![]() Re: Caleidos4D Ribbon Pubblic Beta 1Ciao Caleidos4D,
Ti ringrazio per il tuo lavoro, ho istallato il plugin ma non riesco a farlo funzionare come dovrebbe. Puoi aiutarmi? Allego immagine della schermata dove non si vede l'area del disegno. Ciao e di nuovo grazie. David Hello Caleidos4D, Thank you for your work, I installed the plugin but I can not get it working as it should. Can you help? I attach a screen shot where you see the drawing area. Hello and thanks again. David Re: Caleidos4D Ribbon Pubblic Beta 1Did you resize the window?
Hi ![]() you have to resize the ribbon and the SketchUp window, to match your monitor ![]() Re: Caleidos4D Ribbon Pubblic Beta 1Work in progress:
in next release I will fix it the size of monitors in 1024 and the iframe, They will also be floating ![]() Re: Caleidos4D Ribbon Pubblic Beta 1Hi,
I wanted to try out as a precaution in Sketchup 8. But can not find this plugin. Am I doing something wrong? Charly He who makes no mistakes, makes nothing
Solved, found it in the plugin menu. It is very interesting extension. Many thanks to Caleidos4D. Charly He who makes no mistakes, makes nothing
Like this? ![]() Is that a handle on the front, to remove the beer? ![]() My book "Let's SketchUp!" Download from here
Re: Caleidos4D Ribbon Pubblic Beta 1But hey, so far, so good!
Re: Caleidos4D Ribbon Pubblic Beta 1Just a question. The whole thing does not make really sense when there is no way to stop starting the toolbars while starting Sketchup.
When I disabled the tools in the preferences, the toolbars in the ribbon does'nt work. If they are enabled the toolbars floating my window again ( on Mac ) so I have to enable all Toolbars manually. Is there a way to force the Toolbars to disappear/quit at once?
Re: Caleidos4D Ribbon Pubblic Beta 1thanx for your job, but still nothing is happenig at my side!!! plz help
My V-Ray book for architects: https://goo.gl/cz1oRc
Re: Caleidos4D Ribbon Pubblic Beta 1what seems to be the issue Majid?
Re: Caleidos4D Ribbon Pubblic Beta 1Majid: it looks as though you have maximized the toolbar window - just resize to back to a fitting size.
Re: Caleidos4D Ribbon Pubblic Beta 1almost nothing is working for me:)... cant create shapes...etc..etc..and nothing is displayed... this is the issue
![]() My V-Ray book for architects: https://goo.gl/cz1oRc
