[Plugin] Face(s) to group(s)
Postby bentleykfrog » Fri Oct 22, 2010 11:18 am
I thought I'd re-write this script to provide an edge-condition for the grouping. Thanks to Didier and Gavvy for permission to publish this.
This is my first attempt at a sketchup ruby script though i've had some previous experience with OOP, so any advice/suggestions would be greatly appreciated.
The script can be accessed through the menu 'Plugins' -> 'Face(s) to Group(s)' or 'Context Menu (With Face Selected)' -> 'Face(s) to Group(s)'
First select some ungrouped geometry containing faces and run one of three commands:
    F2G: by Any Edge: Creates a single group for each face selected
    F2G: by Hard Edge: Creates a single group for each collection of faces defined by a hard edged outer loop
    F2G: by Hard + Hard Hidden: Creates a single group for collection of faces defined by either a hard edged outer loop or a hard hidden edged outer loop
The first option can create an incredible amount of groups if there is a large selection, and Sketchup tends to slow down at around 750 groups per context, so F2G: by Hard Edge and F2G: by Hard + Hard Hidden gives you some control of the division of each group. F2G: by Hard Edge combined with an intersect operation allows you to define the cutting planes for large geometry, ie.
    1. Group the selection of faces you want to divide
    2. Enter this group and change the face style to wireframe to select and hide all the edges inside the group
    3. Switch the style to any style other than wireframe and in a seperate group define some cutting planes to divide up the faces
    4. In the first group, select all geometry and run 'intersect faces' -> 'with model' from the context menu
    5. In the first group, select all geometry and run 'Face(s) to Group(s)' -> 'F2G: by Hard Edge' from the context menu
This should create groups seperated by the 'hard' edge created by the cutting planes.
In this version there are also some extra settings to change the edge style during the operation. They can be accessed by the menu 'Plugins' -> 'Face(s) to Group(s)':
    Preserve Edge Condition: Does exactly that, leaves the edges in the selection as they are
    Restore Hidden Edges: Turns all hidden edges into unhidden edges
    All Edges Hard: Turns all edges in the selection to unhidden, unsoft and unsmooth (ie a hard edge)
Changelog
  • 13th January 2011 (v0.51)
    • General Maintenance: Added sketchup 6 check for start_operation (thanks to Jim and Daarboven)
4
bentleykfrog
Re: [Plugin] each face to one group
Postby thomthom » Fri Oct 22, 2010 11:41 am
Could you please post this as a separate thread? That way it's easier to locate the plugin when it's at the top of the thread. When they are further down in the post list it's very hard to find.
PluginStore Author
PluginStore Author
Re: [Plugin] Face(s) to group(s)
Postby Gaieus » Fri Oct 22, 2010 12:18 pm
Topic split.
Postby wg19861110 » Sat Oct 23, 2010 4:57 pm
Think U!I learn more
wg19861110
Postby daarboven » Wed Jan 12, 2011 3:15 pm
I noticed this doesn't work with SU 6 because of this line:
Code: Select all
model.start_operation("Face(s) to Group(s)",true)
if you edit it to
Code: Select all
model.start_operation("Face(s) to Group(s)")
leaving out the second parameter it works in SU 6.
Thanks for the plug, anyway.
regards
daarboven
Postby Edson » Wed Jan 12, 2011 3:22 pm
what is a hard edge in sketchup?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Jim » Wed Jan 12, 2011 3:41 pm
daarboven wrote:I noticed this doesn't work with SU 6 because of this line:
Code: Select all
if you edit it to
Code: Select all
regards
Right. I have been using this:
Code: Select all
if Sketchup.version.to_f < 7.0
  Sketchup.active_model.start_operation("Operation")
else
  Sketchup.active_model.start_operation("Operation", true)
It ain't pretty, but it is clear and even explains a little about the reason.
Jim
Global Moderator
Postby bentleykfrog » Thu Jan 13, 2011 12:44 am
Code: Select all
if you edit it to
Code: Select all
regards
Code: Select all
else
Thanks for the tips Jim and Daarboven, I've updated the script to check for this.
bentleykfrog
Postby bentleykfrog » Thu Jan 13, 2011 12:48 am
Edson wrote:what is a hard edge in sketchup?
I presumed it was the opposite of a hidden, soft or smooth edge
bentleykfrog wrote:All Edges Hard: Turns all edges in the selection to unhidden, unsoft and unsmooth (ie a hard edge)
If there's better terminology for this I'll update the code.
bentleykfrog
Postby daarboven » Mon Jan 17, 2011 11:35 am
bentleykfrog wrote:
Code: Select all
if you edit it to
Code: Select all
regards
Code: Select all
else
Thanks for the update, and yes, the version conditional is much more readable!!! If the start_operation method would have default values for the parameters, older versions would have stayed out of trouble ;)
daarboven
Postby thomthom » Mon Jan 17, 2011 11:56 am
The second argument is optional. It just didn't exist in older versions.
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: eglont, FacundoMarro and 14 guests
