[Plugin] Editing: Show Geometry Only - v1.1
Postby TIG » Wed Oct 20, 2010 3:13 pm
(c) TIG 2010
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
___________________________________________________________________________
Script:
####hideContextInstances.rb
place it in the ../Plugins/ folder...
Usage:
This script adds a new function to the 'View' menu.
'Editing: Show Geometry Only'
It 'toggles'.
If it is active it is shown 'ticked'.
If it is inactive it is shown 'unticked'.
The default setting is 'inactive'.
The last setting is remembered with the saved model across sessions.
When it is 'active' if you edit a component-instance or a group then
every group/instance/image within its entities will be hidden from view -
only its raw geometry will be visible.
This may be more useful than 'Hide Rest of Model' [or similar tools] if
there are groups/instances/images that might obscure your view while
editing the instance's raw geometry...
Note that if the edited instance's entities contains no raw geometry at all
then there will be an 'empty' edit session.
Thus nested instances/groups will not be visible and therefore not
selectable, unless you toggle 'View'>'Hidden-Geometry' to be 'on'.
Then you can select 'hidden' instances/groups...
Set 'View'>'Hidden Geometry' to 'off' for an unobstructed view
otherwise.
Instances/groups in the current active_entities are only 'hidden' as you
edit 'down' through any nesting - as you 'open' each instance to edit.
As you edit back 'up' through the nesting they will then remain visible -
to hide them again you must redo the edit 'down' again from scratch...
Note that because it is a menu-item you can shortcut-key to it to 'toggle'.
Donations:
by PayPal to info @ revitrev.org
Version:
1.0 20101020 First Release.
1.1 20101020 Toggle now works both ways within an edit.
Global Moderator
Re: [Plugin] Editing: Show Geometry Only
Postby Rich O Brien » Wed Oct 20, 2010 3:44 pm
I'll be the first to say thanks!
Very useful :thumb:
Rich O Brien
Administrator
Postby DIEGO-RODRIGUEZ » Wed Oct 20, 2010 9:30 pm
tig thank you very much.
works very well.
a question.
possible, enable/disable plugins "Editing: Geometry Only Show" when I'm inside of the active geometry?
DIEGO-RODRIGUEZ
Banned
Re: [Plugin] Editing: Show Geometry Only - v1.1
Postby TIG » Wed Oct 20, 2010 10:44 pm
Should work when you are within an edit - toggle off > unhide & on > hide.......
Here's v1.1 that should definitely do this viewtopic.php?p=280810#p280810
Global Moderator
Postby DIEGO-RODRIGUEZ » Thu Oct 21, 2010 1:39 am
works perfect. TIG thank you very much
DIEGO-RODRIGUEZ
Banned
Postby JQL » Tue Jun 18, 2013 3:12 pm
This is excelent TIG! Many thanks!
Have you thought about show groups/components only?
JQL
Premium Member
Premium Member
Return to Plugins
Users browsing this forum: gabrieledebrito and 5 guests
