SketchUcation Premium Membership
[Plugin] Editing: Hide Context - v1.1 20101019
Postby TIG » Tue Oct 19, 2010 9:50 pm
(c) TIG 2010
Permission to use, copy, modify, and distribute this software for
any purpose and without fee is hereby granted, provided the above
copyright notice appear in all copies.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
___________________________________________________________________________
Script:
##hideEverythingElse.rb
place it in the ../Plugins/ folder...
Usage:
This script adds a new function to the 'View' menu.
'Editing: Hide Context'
It 'toggles'.
If it is active it is shown 'ticked'.
If it is inactive it is shown 'unticked'.
The default setting is 'inactive'.
The last setting is remembered with the saved model across sessions.
When it is 'active' if you edit a component-instance or a group then
everything else in its context is hidden from view: unlike the built-in
'View'>'Component Edit'>'Hide Rest of Model' and
'View'>'Component Edit'>'Hide Similar Instances',
which will either show OR hide EVERYTHING both inside AND outside of the
editing context.
'Editing: Hide Context' is limited to hiding only objects in the edited
instance's context.
This may be more useful than 'Hide Rest of Model' if there is something
outside of the context that you still want to see [e.g. to snap to], but
you do want objects in the immediate context to be hidden temporarily as
they obscure your view...
Remember to set 'View'>'Hidden Geometry' to 'off' for an unobstructed view.
Note that because it is a menu-item you can shortcut-key to it.
Donations:
by PayPal to info @ revitrev.org
Version:
1.0 20101019 First Release.
1.1 20101020 Recast as 'Editing: Hide Context',hides editing context ONLY.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Editing: Hide Everything Else
Postby Pilou » Tue Oct 19, 2010 9:55 pm
Hide Everything Else except selected ?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby EarthMover » Tue Oct 19, 2010 10:44 pm
Very Nice. An "isolation mode" plugin. :thumb:
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Postby DIEGO-RODRIGUEZ » Tue Oct 19, 2010 11:20 pm
thanks tig.
I do not understand,
This plugin is like having clicked options:
- Hide the rest of the model.
- Hide similar components.
no?
not hide groups/compontes that are within group/componte active
DIEGO-RODRIGUEZ
Banned
Postby Panga » Wed Oct 20, 2010 7:43 am
Hi all,
Thanks TIG for this plugin ! Seeing it something came to my mind. Could it be possible that the isolated selection goes to the origin during the time of editing ? Then it comes back to his place when editing's over ? could that be a way to avoid the clipping issue in big models ? Just and idea..
Regards.
Panga
Premium Member
Premium Member
Postby TIG » Wed Oct 20, 2010 9:06 am
To clarify...
It works like 'View' >'Component Edit' >'Hide Rest of Model' and >'Hide Similar Instances' [in fact it uses those] BUT what it ALSO does is hide everything else during an editing session including other instances and geometry - something that the built-in tools don't.
So for example make several groups and group some of them, nest some of them.
Edit one and other objects might be in your way.
Toggle the 'View' >'Component Edit' to 'hide' the rest etc and now some objects will be temporarily hidden and your view will improve... but there might still be some nested objects obscuring your view.
Activate 'View' >'Editing: Hide Everything Else' and even those objects will be temporarily hidden. :geek:
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Wed Oct 20, 2010 10:00 am
DIEGO-RODRIGUEZ wrote:thanks tig.
Not hide groups/components that are within group/component active
I see the point - I will work on an alternative that is like 'View >'Component Edit' >'Hide Rest of Model' but ONLY hides what is in the current entities set... To hide everything you'd still use 'View >'Component Edit'... :roll:
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Editing: Hide Context - v1.1 20101019
Postby TIG » Wed Oct 20, 2010 11:20 am
Here's v1.1 viewtopic.php?p=280618#p280618
which I think addresses the issues raised.
Please read the notes on the linked page.
The toggle now hides everything in the editing context only... :geek:
Global Moderator
SketchUp version: 8
License type: Pro
Postby JuanV.Soler » Wed Oct 20, 2010 11:28 am
Thanks TIG, I am testing it.
Mind you are quick :D
cheers
_,_)))_,_
JuanV.Soler
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby Caleidos4D » Wed Oct 20, 2010 11:43 am
Thanks TIG!!! :thumb:
Caleidos4D
Postby DIEGO-RODRIGUEZ » Wed Oct 20, 2010 12:31 pm
thanks tig. very fast response.
I tried l plugin, but I can not understand how it works.
maybe my English is very bad and I did not explain well.
attached image and file the idea I have.
DIEGO-RODRIGUEZ
Banned
Postby TIG » Wed Oct 20, 2010 12:34 pm
Got you!
That's another tool 'Editing: Show Geometry Only'...
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Wed Oct 20, 2010 3:44 pm
Here is 'Editing: Show Geometry Only' viewtopic.php?p=280810#p280810
Global Moderator
SketchUp version: 8
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Plugins
Users browsing this forum: maverk78, moonsoo, rhyssch, sridhar, Venscape, xmano90 and 12 guests
