[Plugin] Hidden Manager (08.Feb.2015)
• Page 1 of 2 • 1, 2
[Plugin] Hidden Manager (08.Feb.2015)I want to publish my first plugin.
I hope it can be useful to someone. Try it out. I look forward to your feedback. I tested the plugin in SketchUp Pro 2014, please report errors! Description: This plugin shows all the hidden elements in the model in a separete Window to control this Entities. You can from there select each item, or make them visible. Update: 08.Feb.2015 - Test: tested in Sketchup 2015 (do not install about the sketchucation store plugin, there is an old version) Update: 21.Mar.2014 - Bugfix: Strict Code Bug and some files renamed, tested in Sketchup 2014 Update: 16.Feb.2011 - Change to start the observer on activate and remove on deaktivate now. i hope the bugsplash from other Plugins (ImageTrimmer or Slicer etc...) is removed... Update: 17.Jan.2011 - Change the onmouseover in the list from hidden/visible to select/unselect Update: 20.Okt.2010 (Second) - Bugfix and support for open Groups und Components Last edited by schorradt on Sun Feb 08, 2015 10:54 am, edited 13 times in total.
__________________________
http://www.henryschorradt.de/
Re: [Plugin] Hidden Manager (19.Okt.2010)Congrats on your first plugin.
Could you please add a short description of what the plugin do? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Hidden Manager (20.Okt.2010)New Update and more Features...
Re: [Plugin] Hidden Manager (20.Okt.2010)oh sorry, i have postet a new Version now. This bug is corrected.
Well, the bug is still present. Thanks for the plugin Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Hidden Manager (20.Okt.2010)Please try to deactivate the Plugin and then reactivate. the Problem is the Entry in die Registry for the Plugin. I have fixed the bug in the "mx_hidemanager_loader.rb" ...
Re: [Plugin] Hidden Manager (20.Okt.2010)No feedback?! I am looking forward to your opinions
![]() __________________________
Well, I have tried again and have the same error as before. I did removed all of the plugin before re-installing the plugin. Ken Fight like your the third monkey on Noah's Ark gangway.
Re: [Plugin] Hidden Manager (20.Okt.2010)Works fine for me.
Got some thought on it: 1. It'd be helpful if the ComponentDefinition name was listed in the list. 2. Being able to disable the automatic hide/show feature when you mouse over an entitiy - it floods the undostack which I'd rather avoid. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Hidden Manager (20.Okt.2010)Are you sure you extracted all the files correctly?
(btw, for those who report it's not working, what SU version do you use? And what OS?) Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Hidden Manager (20.Okt.2010)Sketchup 8, Vista. I have the same error code as shown in Caleidos4D post.
Well sorry if I upset you but this manager is rather useless IMHO. Why? Because your model is itself a manager of your 3d elements. And if you'd turn on "show the hidden geometry" mode you can easily select\unhide\view it's properties without any additional tables. Re: [Plugin] Hidden Manager (20.Okt.2010)I don't see as a bad idea. It's like the Unhide By Name in 3dsMax. In complex models it can be easier to locate the object in a list instead of visually in the model.
All though I normally hide/unhide objects by layer, I occasionally hide objects temporarily - and some times several. Bringing up a list without leaving the current viewport is a nice thing. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Hidden Manager (20.Okt.2010)I also think it's a good idea, as you can see all your hidden objects at once. The only thing I miss is that hidden objects within groups or components are displayed but I don't know whether this can be done. Maybe similar to the Outliner as a tree structure?
Re: [Plugin] Hidden Manager (20.Okt.2010)Its a very interesting plugin! And as it is your first I feel like congatulating you for doing work that help the rest of us , have a better workflow.
I could really make use of it, but I am not going to download yet. You should really listen to Thom, if you don't mind me say, cause he is very experienced. This plugin can be "a must have" for everyone. Keep up the good work, and the feedback will come. CAntonis Re: [Plugin] Hidden Manager (20.Okt.2010)
yes... as Ken' post. i have windows 7 and sketchup 8 pro Re: [Plugin] Hidden Manager (20.Okt.2010)Thx for the feedback...
Is there a function to the undo function to prevent for the undo stack? Or a code snipped? The error is to be here, I can not find... __________________________
There is a way to make the previous or next transparent, but I've had bad experience with them, tricky to get right. Merging undo stack items can be unpredictable to deal with. And both would cause the wrong name to appear in the Edit>Undo menu. I'd not recommend them. Thomas Thomassen — SketchUp Monkey & Coding addict
.... ![]() Re: [Plugin] Hidden Manager (20.Okt.2010)okay ... i looking for another solution...
@Caleidos4D Sorry ,but in my testenvirement, i can´t see any errors ![]() __________________________
Honestly this was an unnecessarily rude response. It may be useless to you, but may be of great use to others whose work process is different from yours. I tend to hide some geometry to work on other items, being able to toggle a specific item into visibility without having to make all of them visible and the attendant slowdown of the program because of the huge overhead increase of all the sub geometry that also turns on when I show hidden geometry is a real boon. So, thanks for an interesting and I think, quite useful plugin. Great first effort, would that I were able to be able to reciprocate with a plugin of my own. In any case thank you. All the best and looking forward to your future efforts. Karl I created Dilbertville, sorry about that...
Re: [Plugin] Hidden Manager (17.Jan.2011)little change in this Plugin.
Re: [Plugin] Hidden Manager (17.Jan.2011)17 Of january is my nameday! And this is a wonderful present!Downloaded and gonna test it!
Thank U very much! Re: [Plugin] Hidden Manager (16.Feb.2011)Update: 16.Feb.2011
- Change to start the observer on activate and remove on deaktivate now. i hope the bugsplash from other Plugins (ImageTrimmer or Slicer etc...) is removed... __________________________
Re: [Plugin] Hidden Manager (16.Feb.2011)Error Loading File mx_hidemanager_loader.rb
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/mx_hidemanager_loader.rb:58: syntax error mx_hiddenmanager = SketchupExtension.new "Hidden Manager", File.join ("mx_hidemanager","mx_hidemanager.rbs") ^ C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/mx_hidemanager_loader.rb:58: syntax error mx_hiddenmanager = SketchupExtension.new "Hidden Manager", File.join ("mx_hidemanager","mx_hidemanager.rbs") ^ C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/mx_hidemanager_loader.rb:58: syntax error Re: [Plugin] Hidden Manager (16.Feb.2011)I'm sorry, but it works on my computer. I can find no error.
Perhaps the pathfunctions does not feature in Sketchup 7 !? __________________________
Re: [Plugin] Hidden Manager (16.Feb.2011)Henry:
mx_hiddenmanager = SketchupExtension.new "Hidden Manager", File.join ("mx_hidemanager","mx_hidemanager.rbs") This can confuse Ruby - you have space after the method name and the brackets. ( File.join ) On top of that you have that as one of the argument of another method call ( SketchupExtension.new ) where you don't use brackets. To avoid potential errors, always use brackets. But most important of all, never leave a space between the method name and the brackets. It's a bit odd that a SU7 user should report this error, because SU8's ruby is more strict. Regardless, this should work: mx_hiddenmanager = SketchupExtension.new( "Hidden Manager", File.join("mx_hidemanager","mx_hidemanager.rbs") ) Thomas Thomassen — SketchUp Monkey & Coding addict
