[Plugin] Contour Maker v1.6
Postby TIG » Thu Sep 23, 2010 8:15 pm
Here's Contour Maker updated.
After ~5 years someone pointed out that it doesn't make contours <z=0...
It now does... AND it's had a general tidy up - it was 5yrs old!
Usage:
First select a Group or Component Instance that has faces that could have
Contours added, then use the Plugins Menu Item 'Contours'.
A dialog asks for the vertical spacing (Z-blue) in current units.
The Contours always start their vertical spacing from Z=0 UP & DOWN.
It then makes a new layer for the contour-group. The layer is
named CONT-nnnnnnnn (where nnnnnnnn is based on the date/time).
It then calculates a series of horizontal slices through the
selection's faces to make the Contours as specified.
Get the latest version from the PluginStore
Download
6
Global Moderator
Re: [Plugin] Contour Maker v1.5
Postby mitcorb » Thu Sep 23, 2010 8:23 pm
TIG:
Where do we find the original instructions for use, if any?
mitcorb
Top SketchUcator
Postby TIG » Thu Sep 23, 2010 8:28 pm
mitcorb wrote:TIG:
Added them to the first post :roll:
Global Moderator
Postby mitcorb » Thu Sep 23, 2010 8:31 pm
Thanks, TIG:
Watch out, someday they will have you bronzed. :mrgreen:
mitcorb
Top SketchUcator
Postby Krisidious » Thu Sep 23, 2010 8:37 pm
thanks Tig...
By: Kristoff Rand
Home Designer
Unique House Plans
Krisidious
Postby Susy » Thu Sep 23, 2010 9:03 pm
Add Contour Maker on Axis (x) and (y)...
Already in the race the mouse... (Local Expression)
Susy
Postby massimo » Thu Sep 23, 2010 9:52 pm
Thanks TIG, seems to work fine. :)
It's possible to get rid of that mesh grid on the Z=0 level? Perhaps an option?
massimo
Postby TIG » Thu Sep 23, 2010 11:14 pm
massimo wrote:Thanks TIG, seems to work fine. :)
I see the problem.
Can you post the example SKP before Contouring...
So I can play with it...
I suspect some sort of 'Erase Coplanar Edges' is needed within the tool - but it will occur at any z-level if you have a mesh that you haven't used 'Erase Coplanar Edges' on and there are multiple faces - It simply uses what it's given... ;)
For now use an 'Erase Coplanar Edges' tool [there are several available] [i]before
you make the Contours and the problem will vanish with the coplanar edges...[/i]
Global Moderator
Postby massimo » Fri Sep 24, 2010 7:28 am
It was only a quick test and i don't have the file anymore. Anyway you can replicate that easily. It was a terrain mesh generated with the sandbox tools: from scratch+smoove and then smoothened.
For now use an 'Erase Coplanar Edges' tool [there are several available] before you make the Contours and the problem will vanish with the coplanar edges...
Sure. Thanks :)
massimo
Postby Gaieus » Fri Sep 24, 2010 12:03 pm
ThomThom's CleanUp plugin will get rid of those edges, too (and many more...)
Postby massimo » Fri Sep 24, 2010 12:41 pm
Already used that. ;) Thanks Gaieus.
massimo
Postby simon le bon » Fri Sep 24, 2010 3:44 pm
I see the problem.
For now use an 'Erase Coplanar Edges' tool [there are several available] before you make the Contours and the problem will vanish with the coplanar edges...[/i]
Hi Tig and Massimo and Gaieus :) ,
Here are 'Erase Coplanar Edges' tools:
thomthom_[Plugin] Cleanup (2.0.0)
For SU7.1 Doesn't work on my SU6 free.
a4chitect_ cleanup.rb
J.H. Aughey_CleanUP Model
Well! I have tried Tig's solution:
For now use an 'Erase Coplanar Edges' tool before you make the Contours and the problem will vanish with the coplanar edges...
but that doesn't work very well.
The simple working solution I have found is to avoid z=0. Moving the group up (or down), activate Contour Maker, Move the group back to the initial position.
Cheers, simon.
simon le bon
Postby MALAISE » Fri Sep 24, 2010 7:29 pm
Very useful for geological drawings
Thanks TIG :thumb: :thumb:
MALAISE
Postby TIG » Fri Sep 24, 2010 8:11 pm
Simon...
When you use the erase coplanar edges tool do you have hidden-geometry 'on'.
Then when you have the simplest mesh possible make the contours... :?:
Global Moderator
Postby simon le bon » Fri Sep 24, 2010 10:12 pm
Hi Tig, ;)
I had tried only with all edges unsmoothed.
So I just have tried with hidden geometry "on" as you say. The result is not bad but seems not the best.
++simon
simon le bon
Postby TIG » Fri Sep 24, 2010 10:16 pm
It does exactly what you tell it to do...
If you move the mesh up in the Z by 1mm the result will change... :roll:
The contours are 'true' - the mesh might not be exactly as you hope BUT the 'contours' represent what is there...
Global Moderator
Postby simon le bon » Fri Sep 24, 2010 11:08 pm
Ah OK!
I think I began to understand how Contour maker works.
:? simon
simon le bon
Re: [Plugin] Contour Maker v1.6
Postby TIG » Mon Sep 27, 2010 11:47 am
Here's v1.6 - viewtopic.php?p=273795#p273795
Minor corrections to syntax [arguments all inside () ] that has no affect on results but covers possible future deprecation...
Global Moderator
Postby mitcorb » Mon Sep 27, 2010 11:59 am
Hi,TIG:
Could you explain what you mean by possible future deprecation?
It suggests to me that other tools may not tolerate the use of this one?
mitcorb
Top SketchUcator
Postby TIG » Mon Sep 27, 2010 2:21 pm
A method's 'deprecation' is when a method or a part of a method is no longer 'used' or 'works'.
For example in many API examples in the guides it will say for things like:
entities.add_cline point1, point2
this works fine in past and current versions...
BUT the 'standard' way recommended in Ruby and guaranteed to stop faults is to use 'parenthesizes' to enclose all arguments, like this
entities.add_cline(point1, point2)
[Note NO space between the method and opening ( and the arguments are separated by ',']
This also gets over the occasional glitch that occurred in existing code with the new PC version of Ruby shipped with v8, for example in v7 this [probably] worked
my_command (x+y/2), z
in v8 it will fail because the first set of stuff inside the '()' is taken as all the arguments there are and the following ', z' throws an error, but changed to
my_command((x+y/2), z)
it then works for both versions and is also 'future-proof' as all of the arguments are now encapsulated inside the ()...
Global Moderator
Postby mitcorb » Mon Sep 27, 2010 3:33 pm
Thanks for your explanation, TIG
You are an amazing dude.
Another question. Could this tendency toward deprecation be the reason why older scripts that worked fine last year, suddenly do not work this week, even though the same SUversion is being used?
mitcorb
Top SketchUcator
Postby Didier Bur » Mon Sep 27, 2010 3:56 pm
Yes, especially since SU8 is out. The API "uses" a newer version of Ruby that is less permissive, concerning arguments within brackets, no spaces between function name and arguments, and such boring coding stuff. :bounce:
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby mitcorb » Mon Sep 27, 2010 7:08 pm
Didier wrote:
"...such boring coding stuff"
I am dragging this way off topic, but one more comment and I will quit.
I superficially understand that all of those punctuation marks and symbols are a way to organize the input, but why should input be so tedious? Just think about it, don't answer so that this thread can continue.
mitcorb
Top SketchUcator
Postby JGA » Mon Sep 27, 2010 10:21 pm
Thanks very much, it works well!
Regards,
JGA
JGA
Postby chenkl » Wed Sep 29, 2010 4:32 pm
Thanks TIG
chenkl
Postby pilou » Wed Sep 29, 2010 4:38 pm
Life is encapsuled (Life) :lol:
Keep the good work :fro:
Speedy Galerie
Top SketchUcator
Postby CAD Addict » Sat Oct 09, 2010 10:56 am
I haven't had time to try it, but I have a question.
Isn't it the same as the Sandbox tools can do?
What does it do better than the standrads sandbox?
CAD Addict
Postby TIG » Sat Oct 09, 2010 11:05 am
CAD Addict wrote:I haven't had time to try it...
Isn't it the same as [what] the Sandbox [does]...?
What does it do... better...?...
No, it's quite different!
The 'opposite' tool in fact...
The Sandbox tool takes contours supplied to it, that are already set at the correct heights, and makes a mesh surface from them.
The ContourMaker tool takes a mesh surface and it makes [grouped] contours from it.
Your mesh might not have been made from contour data at all, but contours can be very useful when visualizing a complex land-form - this tool lets you add them.
:ugeek:
Global Moderator
Postby irwanwr » Fri Dec 09, 2011 12:36 am
i'd like to try this plugin.
i'd like to see if i can draw (or model) a pond near a tent or a house perhaps.
i just love to draw :)
thank you :thumb:
irwanwr
Postby TIG » Fri Dec 09, 2011 12:15 pm
irwanwr wrote:i'd like to try this plugin.
thank you :thumb:
Get it from the link in the first post in this thread...
Global Moderator
Next
Return to Plugins
Users browsing this forum: dezmo, feyzahhhh, resetarionut, royarbabi and 11 guests
