SketchUcation Plugin Store
[Plugin] Export 2d with Alpha (1.0.1) — 13 September 2010
Postby thomthom » Mon Sep 13, 2010 6:41 pm
Overview
Exports the current view with transparent background option (SU8) if you use the PNG format. Will also let you export only what is displayed on your screen - where SketchUp's native Export 2D function would export the whole model, regardless.
Access
View > Export 2D
Usage
Requirements
  • SketchUp 7 or newer - ( Other versions untested )
  • TT_Lib2
Download
tt_export.rb
Footprint
<Sketchup>/Plugins/
tt_export.rb
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Export 2d with Alpha (1.0.1) — 13 September 201
Postby Ben Ritter » Mon Sep 13, 2010 7:35 pm
Thomas, thank you once again and happy Monday.
Ben Ritter
Postby JClements » Mon Sep 13, 2010 8:48 pm
Thomas, this is great. I use the transparent PNG format for most all of my work so I can do compositing.
A few weeks ago I had to make a 4' x 3' poster. Layout couldn't export the PNG because, I think because of the all the textures I had combined with the anti-aliasing of LayOut's export filter). My old workaround was to make all layers Black and then turn on color by layer to produce a black and white mask for an Alpha Channel but that doesn't work with textures that are comprised of transparent PNGs. Hopefully, this script will address these type of textures.
This could be script my workaround for transparent PNG's. I will give it a test.
Thank you !
[Edit] P.S. I am going to change the name, however, to "tt_eportPNG.rb" ... incase you come up with some other export options
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Pixero » Mon Sep 13, 2010 8:55 pm
Thanks, but I'm curious...how does it work?
Was transparency there all along but the built in exporter couldn't handle it?
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby JClements » Mon Sep 13, 2010 9:35 pm
Thomas, so far so good. I exported a 4,000 x 2,000 pix file no problem. I haven't tried using sketchy edge styles with it yet.
Q- Would it be possible to read the aspect ratio of the users model window and give that as an option in your dropdown list?
If you'd like a model to do tests with I can arrange to send one that could push the script to it's limits. Let me know.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Sep 13, 2010 9:51 pm
Pixero wrote:Was transparency there all along but the built in exporter couldn't handle it?
Added with the SU8 API.
JClements wrote:Q- Would it be possible to read the aspect ratio of the users model window and give that as an option in your dropdown list?
I can read the aspect ratio - but I can't make the values in the inputbox interactively change. I'd have to make a webdialog for that.
JClements wrote:If you'd like a model to do tests with I can arrange to send one that could push the script to it's limits. Let me know.
I really have no control over what it can export. It simply calls the SU API: view.write_image - so I'm not doing anything different from what SU does - because it's all SU.
Global Moderator
SketchUp version: 8
License type: Pro
Postby CadFather » Mon Sep 13, 2010 10:10 pm
Master Thom Thom strikes again! :shock: (a true gem)
now i know why the name: it's two of you!! thank you, thank you
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Name: Max Coppoletta
Postby JClements » Mon Sep 13, 2010 10:16 pm
Thomas, if you could just display the aspect ratio that would be helpful. I could manually enter values using a calculator.
John
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby EscapeArtist » Mon Sep 13, 2010 10:29 pm
Great! I needed something like this last week, how did you know?
Thanks for another useful plugin! :thumb:
EscapeArtist
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: hobby
Postby thomthom » Mon Sep 13, 2010 10:33 pm
JClements wrote:Thomas, if you could just display the aspect ratio that would be helpful. I could manually enter values using a calculator.
John
I'll see what I can do. I am currently working on a system to make advanced inputboxes easier to make.
Global Moderator
SketchUp version: 8
License type: Pro
Postby JClements » Mon Sep 13, 2010 11:05 pm
Thomas. Not urgent by any means.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Pixero » Tue Sep 14, 2010 7:21 am
thomthom wrote:•SketchUp 7 or newer
thomthom wrote:Added with the SU8 API.
So...how do I get this to work with SU 7.1?
It exports without transparency and always the whole model.
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Sep 14, 2010 7:26 am
Pixero wrote:So...how do I get this to work with SU 7.1?
Transparency? You can't.
Pixero wrote:and always the whole model.
hmm, not on my machine - remember to Hide Rest of Model. WYSIWYG.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pixero » Tue Sep 14, 2010 7:59 am
thomthom wrote: Transparency? You can't.
:cry:
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby rv1974 » Tue Sep 14, 2010 9:19 am
Is there some way to separate shadows pass?
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Sep 14, 2010 9:46 am
No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pixero » Tue Sep 14, 2010 10:41 am
thomthom wrote:No - I have no control of how it's generated. As you see from the sample I posted the shadows even comes from the whole model, not just what is visible.
This can help for a shadow pass: http://rhin.crai.archi.fr/RubyLibraryDe ... emplate.rb
And maybe a modification of my Shadow control script (http://www.pixero.com/downloads_sketchup.html) could be made to set everything not selected to: e.casts_shadows = false
Pixero
Premium Member
Premium Member
Name: Jan Sandström
SketchUp version: 8
License type: Pro
Postby archworks » Wed Nov 24, 2010 3:25 pm
Congratulations - one of the best for su 2d app
archworks
Postby Gaieus » Wed Nov 24, 2010 4:33 pm
Hey, I did not see this, great plugin, thanks Thom! :thumb: :thumb: :thumb:
_______
Edit; to me, it does not export with transparent background... Nor does it export only the active context. :(
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby thomthom » Wed Nov 24, 2010 6:04 pm
Gaieus wrote:Edit; to me, it does not export with transparent background... Nor does it export only the active context. :(
What version of SU did you use?
Got a screencapture?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed Nov 24, 2010 6:34 pm
Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
Humpmetwice
Postby thomthom » Wed Nov 24, 2010 6:47 pm
humpmetwice wrote:Have I put something in the wrong spot or something cause when I go to view/export 2D the settings comes up but then it doesn't give me a file type to save it as?
After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Humpmetwice » Wed Nov 24, 2010 7:16 pm
thomthom wrote:After the Settings window and you click OK you should get a File Dialog asking you what name to give the file. You must specify the file extension yourself.
I know and it doesn't give me any file type to save it as at all.
Humpmetwice
Postby thomthom » Wed Nov 24, 2010 7:29 pm
You have to type the file type yourself - there is no list of file types because the SketchUp Ruby API doesn't let me provide one.
So if you want to save a jpg file just enter "myfile.jpg" in the file dialog.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Thu Nov 25, 2010 11:37 pm
The most recent one; SU 8.
Here is a screen capture; now with a different codec than the one you could not open the other day if you remember...
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 26, 2010 9:18 am
That baffles me. I have no idea why this happens. Exactly the same works for me... :?: :? :?:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Fri Nov 26, 2010 9:51 am
Well, sigh... I can always use LO for exporting png's with transparent background...
Maybe it's an XP thing?
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 26, 2010 9:54 am
I don't know. Haven't got an XP machine at hand right now. Could be an SketchUp bug...
Global Moderator
SketchUp version: 8
License type: Pro
Postby Gaieus » Fri Nov 26, 2010 10:35 am
Well, you know where to report it (and who has all sorts of machines). I have no clue about the ins and outs of ruby. I could never make a proper bug report on plugins!
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Nov 26, 2010 11:08 am
Just to narrow it down to a simple test case - can you try this one-liner?
Code: Select all
Sketchup.active_model.active_view.write_image( { :filename=>'C:\test.png', :width=>640, :height=>480, :antialias=>false, :transparent=>true } )
Global Moderator
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Next
Return to Plugins
Users browsing this forum: fgauger, jmorrison2, rohitac, walid1988 and 17 guests
