SketchUcation Premium Membership
[Plugin] SketchUp Calc (for Windows)
Postby Jim » Wed Sep 08, 2010 6:31 pm
In a nutshell, whenever the Measurements box is available, you can use this to evaluate an expression and send the result to SketchUp. To clarify, scalar values such as lengths and radius - it doesn't know about coordinate pairs, or length units.
Type in expressions just like you would write them, use parenthesis for grouping.
It uses VBScript to eval the textbox, so you can also use any Math that VBS supports including:
  • +, -, *, /, abs(), atn(), cos(), exp(), hex(), int(), fix(), log(), oct(), rnd(), round(), sgn(), sin(), sqr(), tan()
Use the Test button to make sure it uses the correct SketchUp Window. It looks for the first window that matches the title text. Sometimes, it finds non-Sketchup windows that happen to also match.
Once you're sure it's getting the right window, then anytime the Measurements is expecting a value, you can Alt-Tab to the calc, enter a calculation, and hit Send. The calculated value is sent, along with the ENTER key.
Installing - download the .zip, extract the single .hta file. It does not need to be located in any special place. Double-click to run it from anywhere, at any time.
Alpha version, ugly interface but that can be fixed. I just need to know if it works and if anyone's interested.
Thanks.
Download: SketchUpCalc0.3.zip
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: [Plugin] SketchUp Evaluator (alpha for Windows)
Postby Bertier » Sat Sep 11, 2010 6:28 pm
not working on my system
could be useful
thank you
Bertier
Postby Jim » Sat Sep 11, 2010 11:55 pm
Did it do anything at all? Did it open and show the window, or do nothing? Any other indications? Thanks.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Thu Sep 16, 2010 2:59 pm
Updated to V 0.3 - Does it work any better?
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Bertier » Thu Sep 16, 2010 10:12 pm
will give it a try and feedback
Bertier
Re: [Plugin] SketchUp Calc (for Windows)
Postby wiiiktor » Mon Nov 26, 2012 7:33 pm
Jim, thank You for a useful tool.
I have a question though, why it is not launched from the sketchup toolbar?
As this forum page is quite old (started in 2010) is there any su add-on making Measurements calculations that You know of, that is fully internal?
greets, Wiktor
wiiiktor
Name: Wiktor Migaszewski
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Return to Plugins
Users browsing this forum: CarolEaston, danielsangeo, Guaro, Jean-Franco, jennik_pr, romisharma1989, xavier9 and 17 guests
