[Plugin] Rename Component Instance
Postby daiku » Tue Sep 07, 2010 3:32 pm
The normal way to rename a component instance is to use the entity info window. This script saves only one mouse click. But if you need to rename a lot of components, that can add up. Just activate the tool, and double-click on any component instance you wish to rename. CB.
daiku
PluginStore Author
PluginStore Author
Re: [Plugin] Rename Component Instance
Postby CadFather » Tue Sep 07, 2010 7:12 pm
Thanks Daiku - but why not just 1 click?
CadFather
PluginStore Author
PluginStore Author
Postby daiku » Tue Sep 07, 2010 7:50 pm
No good reason, really. Just seemed intuitive to me. Easy to change, though.
daiku
PluginStore Author
PluginStore Author
Postby Enachi » Wed Dec 21, 2011 7:54 pm
Daiku, I've got a question and maybe a challenge for you :)
I am looking for a similar script that would be able to change the names for a group of components, but the definition name and not the name, and what is most important to be able to set the order (SU does not accept two components with the same name, so the script might do it in an certain order...let's say you've got 100 components, and the script will name them component#1 ... component#2...an so on).
Thanks.
Enachi
Postby allmes » Tue Mar 19, 2013 1:57 pm
Dear daiku! Please add possibility to choose name from a combobox. As it is done in plugin makeNamedGroup...
Thank you very much!!!
allmes
Postby serland » Mon Jan 15, 2018 8:43 pm
Someone knows a way, plugin, app or whatever to auto rename instances with consecutive names?, example: select component#1, component#2 and component#3 (the three are the same component), one click > auto rename instances and you have on instance#1 = name#1, on instance #2 = name#2 and so on.
Thanks ;)
serland
Premium Member
Premium Member
Postby juju » Mon Jan 15, 2018 10:03 pm
take a look at EasyGroups
juju
Premium Member
Premium Member
Return to Plugins
Users browsing this forum: resetarionut, xanhxam and 11 guests
