[Plugin] TT_Lib²
Overview
This is not a standalone plugin. It is only needed by some plugins.Documentation
http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT.htmlRemove older TT_Lib² versions if you already have TT_Lib² installed.
Guide: How to install RBZ Files
Version 2.1.0
- Added module:
TT::UVQ
- Added class:
TT::UV_Plane
- Added method:
TT::Entities.bounds
- Added class:
TT::Gizmo::Manipulator
- Added module:
TT::Selection
- Fixed:
Ray.test
- Added module:
Thomas, we missed you at the Basecamp. Many people asked about you. Hopefully, there can be Europe Basecamp in the future for the loyal people on the other side of the Atlantic.
Regard, John
Thanks John - I really wished I could have been there.
Been fun to see some of the pictures, the faces behinds the nicknames. Looking forward to more and hopefully video from the talks. -
Version 2.1.1
- Fixed bug:
Ray.test
(Workaround for SU8.0 bug)
- Fixed bug:
Thanks!
Version 2.2.0
- Added module:
TT::Bounds
- Added module:
Version 2.3.0
- Added method:
TT::Geom3d.spiral_sphere
- Fixed:
TT::Ray.test
- Added method:
Version 2.4.0
- Added module:
TT::Binary
- Added class:
TT::JSON
- Added module:
TT::GUI
- Added class:
TT::Window
- Added class:
TT::Inputbox
- Added module:
TT::System
- Added module:
TT::Locale
- Added module:
TT::Cursor
- Added module:
Great job you do here Thomas, i do not how you find the a time ( amazing)
I have the select curve tool and i have TT_lib in one folder,TT_lib selectcurve in another and in that in its own folder TT_lib2 and tt_select_curve on its own in the plug in folder with all the above . (that was complicated) i get a message cannot find ? could you help me please my fine friend ( ps great glasses) regards Phil -
Maybe when you unzipp the file you have one path folder more
TT_Lib2-2.4.0) / TT_Lib2 /...
It was my case !
At any time I forget to keep only TT_Lib2/... !!!
TT_Lib2-2.4.0 must be not taken because that make one path folder more
And after with only in Plugins folder TT_Lib2/... all works fineThat what i want and all works fine!
I Select all then Plugins/ Thomthom Plugins/Guide Tools/ CPoint at Arc Center and all points are drawn!
Bravo ThomThom! (works fine in the V6) -
I have the select curve tool and i have TT_lib in one folder,TT_lib selectcurve in another and in that in its own folder TT_lib2 and tt_select_curve on its own in the plug in folder with all the above . (that was complicated) i get a message cannot find ? could you help me please my fine friend ( ps great glasses) regards Philhm.. didn't notice this message until now.
As Pilou said, check that you have file files in the correct location. At the bottom of each page for them plugins there is an example of their footprint in the Plugins folder.
Hello Thomthom
Someone say thank you -
I'm getting this error when starting SU.
I have the latest version ov Selection Toys along with TT_Lib version 1 and 2.4.0.
SU 7.1 Windows. -
SelectionToys does not use TT_Lib2 at all.
You need to ensure you have the correction version of TT_Lib (1.x) and that it's installed correctly.
Reinstalling the latest 1.x version helped.
By the way I'm tired of rearrangeing my toolbars once again. How does the save toolbar in SU8 work?
Poorly.
View->Toolbars->Save Positions
View->Toolbars->Restore Positions
I've found it to not work so well when adding/removing plugins with toolbars...
Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
I have some docs generated. But the comments are not complete. It's still taking shape and some things will be changed.
I'll try to make a note on the modules that are WIP and include more examples. If you have questions about particulars just let me know and I can push them up on the update list.For the brave, here is the current output: http://www.thomthom.net/software/sketchup/tt_lib2/doc/ (for TT_Lib 2.5 mind you)
(Anyone knows how to modify YARDs templates so the constant lists will be more compact?)
