[Plugins]$ Create image(rotate)
• Page 1 of 2 • 1, 2
[Plugins]$ Create image(rotate)The script takes a snapshot and saves the image in the folder where the file resides. Skp
Before installation remove a script "animaciya_create.rb" from a folder "Plugins" Please, register (free) to access all the attachments on the forums.
Re: [Plugins] Create image(rotate)Hi,
Cool. It reminds me my old VR Object exporter here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=467 Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F) http://rld.crai.archi.fr/rubylibrarydepot/
I did not know that such a script exists
Re: [Plugins] Create image(rotate)Thank you Sahi!
Daniel S Please, register (free) to access all the attachments on the forums.
Re: [Plugins] Create image(rotate)thank you
Re: [Plugins] Create image(rotate)Modified script, added the ability to select each group the direction of rotation
In the first message Please, register (free) to access all the attachments on the forums.
Re: [Plugins] Create image(rotate)Thank you, Sahi! Super cool and couldn't be easier to use.
Hehe Is there a way to use this with a render engine, to make a photorealistic animation? Please, register (free) to access all the attachments on the forums. "There is a man in the world who will never be turned down... he is the man who delivers the goods."
Re: [Plugins] Create image(rotate)Modified script, added the rotation of the whole scene, as well as selecting the folder to save the
Re: [Plugins] Create image(rotate)Thanks Sahi,
I think this is going to be a very popular one Mike
Re: [Plugins] Create image(rotate)Wicked!!! Thank you so much
Re: [Plugins] Create image(rotate)For the test added to the script to choose the speed of rotation for each group (component)
It is necessary? In the first message Please, register (free) to access all the attachments on the forums.
Useful for gears "There is a man in the world who will never be turned down... he is the man who delivers the goods."
Re: [Plugins] Create image(rotate)Your work is so great
Can you provide a multi-language version Thank you
Re: [Plugins] Create image(rotate)This works really well, thanks. But is seems to take a long time to export the images, and why encrypt it?
In the first message is the source file (animaciya_create.rb>> not encrypted) animaciya_create_7.zip - Trial until 12/01/2010 - so it is encrypted Cost $ 8
Re: [Plugins]$ Create image(rotate)I love this...I have a rookie question...Can this be expoted and then impoted into a program such as Bryce and still rotate or only run in SketchUp...
Re: [Plugins]$ Create image(rotate)only run in SketchUp.
Re: [Plugins]$ Create image(rotate)fwiw, i'm getting a consistent bug splat with OS X.
all seems to go well until i click 'start' then splat.. everytime. dotdotdot
Re: [Plugins]$ Create image(rotate)There are mistakes, I'll work on them.
Use the button "Undo" and not "Pause"
Re: [Plugins]$ Create image(rotate)is it possible to "animate" something like a drawer comes out of a cabinet or a door opens?
You can open the box, (like open, click on the "Pause") then close the box, click on the "Start" as it will click on the "Pause"
Re: [Plugins]$ Create image(rotate)Thank you for your work
When the plugin running I used the orbit tool of the Skethup Then it stopped running Why?
i'm not sure if that was a reply to me or not but undo and pause make no difference whatsoever.. to rephrase my previous post-- this plugin does not work on macs dotdotdot
So it should be. You can not work in SketchUp two instruments simultaneously
I do not have macs So I could not set it up under the macs I'll try to fix it ..
Re: [Plugins]$ Create image(rotate)Updated plug-in in the first message. viewtopic.php?f=323&t=30131
Fixed bugs
Re: [Plugins]$ Create image(rotate)sorry but i still dont understand how to use it.
I want to rotate my model on Blue Axis and i dont know what to do next. I klick on start an then on stop and nothing happens. Same problem with "Save" i click on it and the window opens but after that there is no saved fiel
Re: [Plugins]$ Create image(rotate)Is this plug in still supported in sketchup 8? I don't see any recent posts and I'm considering purchasing it.
Re: [Plugins]$ Create image(rotate)In the above post Sahi says he updated the plugin. That was in November when SU 8 had been out for 2 months already.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
