by Regular Polygon » Fri Jul 23, 2010 2:53 am
Hi folks, I couldn't resist one more plugin for creating simple shapes. This is an easy to use plugin that draws a torus. You just go to the menu item Draw -> Torus, enter the parameters in a dialog box, and place the newly created component in the model. You could draw a torus with the SketchUp Follow Me Tool, but it would take 5 minutes instead of 5 seconds. dialog torus.png This plugin will also draw a "twisted torus". OK, I made up the name. But it is the shape you would get if you could cut the tube, twist the ends, and glue them back together. To see the twist, the tube needs to have a polygonal cross section. But, you can control this aspect of the geometry by specifying just a few latitude lines for the torus. twisted sqr tori.png The examples above use a square torus. It is square because the tube has four latitude lines (the creased edges), with four sides (surfaces) in between, so the cross section is a square. The torus on the upper left has no twist. The next has one twist; if you follow one side around the torus, you will end up on the adjacent side after one revolution. The next torus has two twists, and so on, up to five twists. sides 12 twists 12.png You can have any number of sides and twists. In the example above, the torus has 12 sides, and 12 twists, so each side reconnects with itself after one revolution. There is more documentation on the usage for this plugin, and a link to download it, here: regularpolygon.org/plugins/torus.php. Thanks
Last edited by Regular Polygon on Thu Dec 08, 2011 8:18 am, edited 1 time in total.
Regular Polygon
- PluginStore Author
- Name: Regular Polygon
by jason_maranto » Fri Jul 23, 2010 3:17 am
I really dig all your plugins... but this one is unexpectedly cool.
Best, Jason.
jason_maranto
- Name: Jason Maranto
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: illustration, cartoons
- Level of SketchUp: Advanced
by boofredlay » Fri Jul 23, 2010 3:52 am
Cheers.
boofredlay
- Global Moderator
- Name: Eric Lay
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
by d12dozr » Fri Jul 23, 2010 6:56 am
Sweet shapes, I would think geometry teachers would like this. RP, how about a fractal generating plugin? ...you know, just for kicks
d12dozr
- Top SketchUcator
- Name: Marcus
- SketchUp version: 2015
- License type: Pro
- SketchUp use: product design
by shoeb_cars » Fri Jul 23, 2010 6:57 am
this plugin of yours is gonna make someone's life so damn easier.....i mean sketchup life..  cheers bro
shoeb_cars
- Name: shoeb_cars
by notareal » Fri Jul 23, 2010 7:41 am
 Sure, I can find a use for this. Thanks!
notareal
- Thea Render Support
- Name: notareal
by massimo » Fri Jul 23, 2010 7:46 am
Thanks once again
massimo
- Name: Massimo Siracusa
- SketchUp version: 2014
- License type: Pro
- SketchUp use: other
by meak » Fri Jul 23, 2010 9:05 am
genius! big thanks
meak
- Name: mickael cador
by pilou » Fri Jul 23, 2010 9:24 am
Geometric! Surface without edges
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
by Burkhard » Fri Jul 23, 2010 10:43 am
I need 12 second for a round torus with dimensions but your twisted torus is genius
Burkhard
- Premium Member
- Name: Burkhard
- License type: Pro
- SketchUp use: interior design
by Ben Ritter » Fri Jul 23, 2010 4:23 pm
Thank you very much!
Ben Ritter
- Name: Ben Ritter
- License type: Pro
by Regular Polygon » Fri Jul 23, 2010 9:33 pm
Thanks a lot everyone for all your positive feedback. d12dozr wrote:RP, how about a fractal generating plugin? ...you know, just for kicks
That's an idea. I can't think of anymore simple shapes to draw. Definitely would be just for fun.
Regular Polygon
by simon le bon » Fri Jul 23, 2010 11:03 pm
Hi Regular! Are you going to join the happy few set list of the ruby masters ? I didn't know today this plugin was existing. It is a new member : Arc who have told us about it regarding to an exercise we try to soluce. Your Torus plugin make things too much easy (bad for the exercise  ). Thank you for sharing >> make and endless spiral:
+++simon
simon le bon
- Name: Simon Bonnet
by Regular Polygon » Sat Jul 24, 2010 12:52 am
What a coincidence that our separate lines of work would meet like that! You are doing things I never imagined people would do with this plugin.
Last edited by Regular Polygon on Sat Jul 24, 2010 12:59 am, edited 1 time in total.
Regular Polygon
by Box » Sat Jul 24, 2010 12:59 am
It's a wonderful plug-in, ten minutes to whip up this.
- Name: Box
- SketchUp version: 2019
- License type: Pro
by Regular Polygon » Sun Jul 25, 2010 7:51 pm
Thanks Box -- I really like your new avatar.
Regular Polygon
by Box » Sun Jul 25, 2010 8:14 pm
That is thanks to you, it's one of your Toruses/Tori/torum.
- Name: Box
- License type: Pro
by halim » Mon Jul 26, 2010 1:13 pm
can anyone make setting for this examples
halim
- Name: halim
by Regular Polygon » Mon Jul 26, 2010 7:39 pm
Hi halim, The top torus with 20 twists had these settings: settings 20 twists.png The bottom six tori had these settings, except they each have a different twist parameter varying from 0-5. settings 0-5 twists.png P.S. Welcome to the forum!
Regular Polygon
by tomislavm » Fri Jul 30, 2010 12:46 pm
Thanks!
tomislavm
- SketchUp use: historical reconstruction
by ivreich » Tue Aug 07, 2012 6:01 am
Error Message
Hi RP
I downloaded this plugin but it gives me an error message when I try to run it:
I'm using the default torus parameters...
Joel
ivreich
- Name: Joel Lee
- License type: Pro
by Rich O Brien » Tue Aug 07, 2012 9:03 am
The error is related to Fredo's AdditionalFolder plugin. Are you running this from a folder other than the default plugins folder?
Rich O Brien
- Administrator
- Name: Rich O'Brien
- License type: Pro
- SketchUp use: engineering and mechanical design
by ivreich » Tue Aug 07, 2012 9:55 am
Rich O Brien wrote:The error is related to Fredo's AdditionalFolder plugin. Are you running this from a folder other than the default plugins folder?
Not at all. I've installed the plugin directly into SU's default Plugins folder. Would it help if I removed Fredo's AdditionalFolder plugin? Joel
ivreich
- Name: Joel Lee
- License type: Pro
by Rich O Brien » Tue Aug 07, 2012 9:59 am
I'd try it at least. Then we can identify a clash between plugins.
Rich O Brien
- Administrator
- License type: Pro
- Robot
Return to Plugins
