Quickly wrote a tool to rotate components around their axis.
Access
Tools -> Pivot around Axis
(Supports ThomThom's Menu)
Usage
- Select an Component
- Activate the tool
- Click an axis and drag up/down to rotate about that axis
[Plugin] Pivot Around Axis (1.0.0) — 20 May 2010
• Page 1 of 1
[Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Overview
Quickly wrote a tool to rotate components around their axis. Access Tools -> Pivot around Axis (Supports ThomThom's Menu) Usage
Please, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Awesome, Thomas! Simple to use and extremely useful for positioning. (Thinking positionable figures and lego.)
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010I'm not happy about the controls, up and down. I want the position of the cursor in 3D space to affect the rotation.
But it's one for later, this one was a quicky. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Thomas, Nice. Having wrote a very limited "point a component" plugin (limited to pointing the zaxis), I am amazed at what you consider a "quickie". Thanks!!!
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010So add a move, & scale function and you will have an universal manipulator
No possible to adapt the mouse movement after the axe clicked with the arrow keys?
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Yeah--what Pilou says--universal manipulator.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010I started that plugin once, but ended stopping because I don't like to use the universal tool. Is that something that people all really want? Thom is on his way there with this one!
Chris
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Why we cannot enter number for rotation by keyboard?
The files above make me very happy too, because I set keyboard keys... but "Pivot Around Axis" may be useful. Please, register (free) to access all the attachments on the forums.
This plugin does that: viewtopic.php?f=323&t=20346 But it does not default to the component axis unfortunately. (which was what I needed)
Good idea.
Another good idea. I might just come back to this plugin and improve it. Though currently VertexEdit is my top priority. This pivot plugin was one I needed at the office.
Me for instance. But the object of this plugin was to manipulate components while anchored to their axis, something I really miss in SU. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010I wanted to test what happened if I tried to pivot a 2d cutout component...
SU just accepted it. And the face it was stuck to appeared to deform as well, without any edges appearing. But of course when you run Fix Problems: Please, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Nice work, mate.
All those cookies, you might seriously consider a dental plan coverage.
No need! This book is all I need: Besides, virtual cookies are low on sugar. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010It's just very natural to want to enter the exact angle in the VCB after rotating the component.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Yup. I added a couple of things today, like being able to rotate groups. And click on other instances to adjust another object without existing the tool. Will hook up the VCB shortly.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010It'S pity it Can not enter values
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010I was thinking about a new possibility for this tool. It would be like this: we selected the object, we activated the tool, and they appear in the screen a circular menu around the object with possibilities of we can rotate the object in predefine angles , as for instance, in 45 degrees. In the image example, only the dog house is geometry, the rest is the menu. For rotate the object, we chose desired arrow.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010I new to installing plug-ins to sketchup. I've installed your script into the plugins folder but nothing is showing up in the tools menu after restarting sketchup. I'm using SU 7.1.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Have you installed "ThomThom's Menu" ? If you did - then the location is different than the default Tools menu.
Re: [Plugin] Pivot Around Axis (1.0.0) — 20 May 2010Thank-you -- fits a need I've had perfectly.
Best, Jason. I create video tutorial series about several 2D & 3D graphics programs.
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
• Page 1 of 1
