[Plugin] Lattice Maker
Postby TIG » Tue May 11, 2010 11:44 am
Copyright 2010-2013 (c), TIG
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
latticeMaker.rb
Description:
Takes a Selection of Faces and makes a Lattice, offset by a frame's given
width and depth, and pane inset, you can also assign limited Materials
to the frame/pane for ease of future selection/manipulation.
It is similar to EEbyRailsToLattice BUT works on selected Faces...
Usage:
Make a 3D Mesh - perhaps using EEbyRails or other tools - remember that
Faces need not be triangulated if all Edges' Vertices are 'coplanar', so
using similar profiles/rails will allow 'quad faces'. You can also
manually draw over faces to sub-divide them as required.
Edit the Group and Select the Faces to be converted into a Lattice -
any Edges etc in the Selection are ignored so you don't need to be too
careful. Note that the Selected Faces and their Edges that are not
required by non-selected Faces will be deleted and replaced by the new
Lattice Group - if you want to keep them make a copy of the original mesh
to one side beforehand...
Note that a Lattice frame is made in the direction away from a Face's
'front', so if you want the frames and pane to be formed in the other
direction 'Reverse' the Selected Faces beforehand.
Run 'Lattice Maker', from the Plugins Menu.
You are then prompted to chose the 'Lattice Properties':
'Width' - default is 50mm/2" - this is the width centered on the
lines so it's effectively a 100mm/4" 'frame' overall where faces abut.
[if <=0 it defaults]
'Depth' - default is 50mm/2", this is measured 'in' from the face
[if==0 there is no 'depth', if <0 it defaults].
'Pane Inset' - the amount the pane is inset from the frame's top-face -
default is 25.mm/1" [if ==0 there is no 'inset', if <0 it defaults;
it can never be more than the depth, and reverts to that if it is].
'Pane Thickness' - the thickness of the pane measured inset from the
pane's top face - default is 5mm/0.25" [if ==0 the pane is 'one sided'
(facing 'out'), if <0 it is 'outset', this -ve 'outset' cannot be > the
pane_inset, the pane_thickness is limited to the frame_depth-pane_inset].
It is best to give the pane a thickness if it is to be seen from both
sides and the lattice might be exported to a 3rd party renderer.
'Lattice Material' - default is <Default> - additional choices are 'Red',
'Orange', 'Yellow', 'Green', 'Blue', 'Violet', 'Black', 'White' or 'Gray'.
'Pane Material' - default is <None>** - additional choices are <Default>,
"Glass"***, 'Red', 'Orange', 'Yellow', 'Green', 'Blue', 'Violet',
'Black', 'White', 'Gray'.
**Note: if Pane Material == <None> then the faces that would form them
become 'holes' in the final lattice.
***The 'Glass' material will be made if it doesn't exist - it is colored
'bluish-light-gray' with 30% opacity.
The Faces' edges are now offset to suit, then pushpulled to suit and the
materials applied.
Note that faces that are too small to have a 'pane' are made 'solid'.
Download it from the 'SketchUcation PluginStore'
Download
OR AutoInstall using the 'SketchUcation Plugin Store' dialog from within SketchUp itself
26
Global Moderator
Re: {Plugin] Lattice Maker
Postby Slimdog » Tue May 11, 2010 12:18 pm
That looks like fun.
I will have to get around to it someday.
Thanks for sharing.
Steve
Slimdog
Postby mitcorb » Tue May 11, 2010 12:21 pm
Looks interesting. One to watch.
mitcorb
Top SketchUcator
Postby rickgraham » Tue May 11, 2010 12:50 pm
You never cease to amaze me with your plugins. Thank-you! :ecstatic:
Rick
rickgraham
Postby pilou » Tue May 11, 2010 2:08 pm
Can be very usefull for Stained glass! :fro:
You have the rythm! :shock: :thumb:
A "simple" Windowizer ?
Speedy Galerie
Top SketchUcator
Postby eddy » Tue May 11, 2010 4:18 pm
cool plugin TIG
thanks, thanks,thanks. :thumb: :thumb: :thumb:
@ ++ Eddy
eddy
Postby thomthom » Tue May 11, 2010 6:31 pm
Very nice. :thumb:
PluginStore Author
PluginStore Author
Re: [Plugin] Lattice Maker
Postby honoluludesktop » Tue May 11, 2010 6:37 pm
WOW, Fantastic.
honoluludesktop
In Remembrance
Postby jchau2007 » Tue May 11, 2010 6:59 pm
TIG,
Another great plugin. As always, thank you. :thumb:
jchau2007
Postby xrok1 » Tue May 11, 2010 7:09 pm
:thumb: good one!
of course you realize we're going to have to see a bunch of furry lattices now! :puke:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby remus » Tue May 11, 2010 7:56 pm
...or latticed fur :D
remus
Postby xrok1 » Tue May 11, 2010 10:53 pm
or furred, latticed fur! :shock:
:roflmao:
xrok1
Postby pilou » Wed May 12, 2010 12:38 am
Maybe some fertilizer necessary! :lol:
Speedy Galerie
Top SketchUcator
Postby Panga » Wed May 12, 2010 7:07 am
Love that furred, latticed fur! :roflmao:
Panga
Premium Member
Premium Member
Postby dylan » Wed May 12, 2010 8:18 am
Thanks Tig.
dylan
Postby TIG » Wed May 12, 2010 10:08 am
Not sure this will catch on ?
Global Moderator
Postby rv1974 » Wed May 12, 2010 1:36 pm
must have tool for architects. Thank you Tig!
rv1974
Postby Jim » Wed May 12, 2010 5:16 pm
Thatched roofs are possible now?
Jim
Global Moderator
Postby olishea » Wed May 12, 2010 5:27 pm
TIG: will it catch on? of course it will!
have you seen this building? your plugins+fur will surely facilitate this process.
oli
olishea
Premium Member
Premium Member
Postby saturne45 » Wed May 12, 2010 10:39 pm
Great works mister TIG...
saturne45
Postby david_h » Wed May 12, 2010 11:23 pm
okay . . .this is a keeper! Thanks again!
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby MALAISE » Thu May 13, 2010 7:29 am
AN another incredible tool. Thx :ecstatic:
MALAISE
Postby seasdes » Thu May 13, 2010 8:23 am
Hello TIG
This is a very nice tool. Thank you.
The way it draws lattices at present is that the perimeter part are half the total width of the internal parts. Is there a way to make the external parts the same width as the internal parts (Ala Windowizer). Or, better still provide for user to specify different specific widths.
Seasdes
Using Sketchup Pro 2019
seasdes
Postby TIG » Thu May 13, 2010 10:09 am
seasdes wrote:Hello TIG
The way it draws lattices at present is that the perimeter part are half the total width of the internal parts. Is there a way to make the external parts the same width as the internal parts (A la Windowizer). Or, better still provide for user to specify different specific widths.
Seasdes
No. It's primarily intended to make full lattices, that would then have no perimeter 'edges'...
However, you can draw lines around the edges first offset by the frame width like this
Global Moderator
Postby pilou » Thu May 13, 2010 11:08 am
You can also use my alternative if you want a more detailled window ;)
Multiple face Offset by Remus is a very usefull plug :enlight:
Speedy Galerie
Top SketchUcator
Postby harshal kshatriya » Thu May 13, 2010 12:57 pm
hey man.......
really cool plugin...!!!
I love it...
every architect must have it...!!
Thanks again.. :thumb: :thumb: :thumb: :)
harshal kshatriya
Postby AcesHigh » Sat May 15, 2010 8:42 pm
LMAO at the furred latticed fur.
I wonder who will be the first to be a latticed furred latticed fur. :roflmao:
AcesHigh
Postby SU Reviewer » Mon May 17, 2010 6:42 pm
Great Plugin! This is so helpful in creating skylights and greenhouses :mrgreen:
A couple of suggestions for future a version. Try to create a button and maybe some more color options for the lattice, even a way to select custom colors/materials. And when creating the pane if it would be possible to add an option for pane thickness.
Living Einstein's dream through SketchUp.
"Imagination is a preview of life's coming attractions" - Albert Einstein
Joe Simhon ~ SketchUp Plugin Reviews
SU Reviewer
Postby broomstick » Mon May 17, 2010 9:06 pm
is this an update of lattice-izer? or a new plugin?
broomstick
Postby TIG » Mon May 17, 2010 11:02 pm
broomstick wrote:is this an update of latticeizer? or a new plugin?
'Lattice Maker' is an 'alternative' to my Latticeizer, based on my tools EEbyRailToLattice's methods - it does everything that that did, whilst outside of a group - its materials are now deliberately 'limited', BUT then they're easily swapped afterwards anyway... it will probably supersede it in time........ :geek:
Global Moderator
Next
Return to Plugins
Users browsing this forum: Bing [Bot], filipecadu, gjmm, Kferli13 and 10 guests
