SketchUcation Premium Membership
[Plugin] Make Fur (Updated - v.1.5a Thu Oct 28, 2010)
Postby tak2hata » Wed May 05, 2010 8:55 am
Hello ,All.
This Plugin is Fur Maker.
It is convenient to glowing grass etc.
How To Use:
Select Menu From "PLUGINS"--"Fur!(EN)"
Select Faces and Click "Fur!"
I am not good at English.
So Please look at the appended image.
NOTICE::This plugin make too much polygons so model will be large size.(Worst case It can not open.)Please use carefully.
Versions:
Since : 2010-04-21--- v0.0
....many revisions...
Rev : 2010-0624 -- v1.4c(test webdialog for mac)
    fixing webdialog problem on mac os.
    (referred to forum "[Web dialog] switch snippet for pc / mac" and jim's "protrude.rb")
    Russian translation by blajnov(Thanks) :D
Rev : 2010-0625 -- v1.4d(Test2 webdialog for mac)
    I wish this work on mac.Thanks Oxer and Mario.
Rev : 2010-0625 -- v1.4e
    Remove from context menu.
    "Crowd" Problem on mac do not fix yet.
Rev : 2010-1028 -- v1.5a
    Add preview button.(preview only points of density.)
    in the case of using Inputbox,
    first ,preview points,Press Enter or select "make fur" from context menu.
    Width of some buttons in webdialog increased.
    "Preview Fur"and"Back to Dialog" added to translation word
I change filename to "fur_en.rb".
remove older fur rubys from plugins folder.
fur_lang_**.txt is parameter name translate.
the usage like this.
    Density|DENSITY
    Length|LENGTH
This converts "Density" to "DENSITY".
language translate file copy to sketchup plugins directory.
If language file is not exist in plugins dir,then parameter name do not rewrite.
Current version
fur_en15a.zip
Older Version
fur_en_v14e.zip
Language traslation file---fur_lang_****.txt (only one file can Effective in sketchup plugins folder)
fur_lang_en.txt
fur_lang_jp.txt
Spanish translation by Oxer.http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=210#p247640
Franch translation by Daredevilhttp://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=195#p247400
Persian translation by Majidhttp://forums.sketchucation.com/viewtopic.php?f=320&t=28179
Viet nam translation by ktslambieng(100608updated)http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=300#p250660
Portuguese-BR (Brazil) translation by Paulower.http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=285#p249923
Chinese translation by hebeijianke.http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=300#p250314
Russian translation by blajnov.http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=315#p253618
German translation:Thanks Burkhard.http://forums.sketchucation.com/viewtopic.php?f=323&t=28092&start=330#p255389
How to Use.
add crowd mode.
by TAK2HATA
tak2hata
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Re: [Plugin] Make Fur
Postby Pilou » Wed May 05, 2010 9:21 am
Seems very cool! :enlight:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Level of SketchUp: Advanced
Postby thomthom » Wed May 05, 2010 9:26 am
Hey! Welcome to SCF.
Very nice plugin.
Got a couple of comments:
It does not create the grass in the active context. If I open a group or component and select faces it does not add the grass to that group. By design?
Why are there so many Groups generated? To cut down generation time? Just find it a bit odd that a patch will have grass in multiple locations:
As for the grass - would it be an idea to make each grass straw a component, and then use scaled and skewed instances of that strand?
Global Moderator
SketchUp version: 8
License type: Pro
Postby tak2hata » Wed May 05, 2010 10:00 am
Thank you for using this plugin.
Sorry, I will change to create in the active context
Yes.
Creating Too Much Polygon is very slow.
And to use code "entities.fill_from_mesh" must need blank Group.
This Plugin executes each selected faces.
Creating Group each new 800 polygons.
so it parts.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby thomthom » Wed May 05, 2010 10:14 am
Yea - creating geometry slows down as more entities are in the context you add to - I've noticed that myself.
But would it be faster to make each grass strand to be a ComponentInstance of a single ComponentDefinition? That way one can easily edit the grass afterwards as well.
Global Moderator
SketchUp version: 8
License type: Pro
Postby tak2hata » Wed May 05, 2010 10:29 am
It is nice idea !
I will examine it.
I think that time hangs for a moment to change this plugin.
thanks.
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby meak » Wed May 05, 2010 1:47 pm
:berserk: :ecstatic: :sketchstatic:
cool plugin
thanks, thanks,thanks.
+1 componentinstance! :mrgreen:
meak
Postby EarthMover » Wed May 05, 2010 2:28 pm
Nice! Autograss for sketchup!
Thomthom, is there is a simple code fix that we could implement to have the blades made as component instances, or does that involve some rewriting?
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Postby thomthom » Wed May 05, 2010 2:34 pm
Dunno - haven't looked at the code.
Global Moderator
SketchUp version: 8
License type: Pro
Postby xrok1 » Wed May 05, 2010 3:05 pm
thats pretty sweet! thank you. :ecstatic:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby EarthMover » Wed May 05, 2010 3:16 pm
Nice render results...great job with the UI!
I guess one could also just use the plugin to create a small patch of grass, convert it to a component and then spray it into the areas needed.
Some of my 3D crap
EarthMover
Top SketchUcator
Postby thomthom » Wed May 05, 2010 3:34 pm
Suggestions:
Make the type box and Option box.
I like that it inherits the colour of the face it sits on. An nice option would be if it could generate a given set of material variants (0 to n) and use that.
Global Moderator
SketchUp version: 8
License type: Pro
Postby xrok1 » Wed May 05, 2010 3:56 pm
8-) this is greaaaat!
xrok1
Postby rickgraham » Wed May 05, 2010 4:05 pm
Umm my dialog box for furmaker is blank. :?:
Rick
rickgraham
Postby thomthom » Wed May 05, 2010 4:06 pm
xrok1 wrote:8-) this is greaaaat!
Nice patch. Is that just one plain colour for the grass?
Global Moderator
SketchUp version: 8
License type: Pro
Postby solo » Wed May 05, 2010 4:07 pm
:shock:
This looks interesting....
Thanks mate.
My site
Quod gratis asseritur, gratis negatur.
solo
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Wed May 05, 2010 4:17 pm
solo wrote::shock:
Thanks mate.
Render comp?? :D
Global Moderator
SketchUp version: 8
License type: Pro
Postby xrok1 » Wed May 05, 2010 4:26 pm
ground cover>Vegetation_Grass1
xrok1
Postby Jeff Hammond » Wed May 05, 2010 4:36 pm
rickgraham wrote:Umm my dialog box for furmaker is blank. :?:
Rick
same here..
no fur for osx :|
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Ben Ritter » Wed May 05, 2010 5:57 pm
Quite fun to play around with. Thank you so much.
Could you provide a brief description of each setting. Some are painfully obvious, others not so much, for me at least.
Ben
Ben Ritter
Postby rickgraham » Wed May 05, 2010 6:12 pm
Rick
same here..
no fur for osx :|
Wonder how hard it would be to make it Mac-friendly? This looks like something that would have great benefit for myself and my line of work.
Rick
rickgraham
Postby xrok1 » Wed May 05, 2010 6:14 pm
hmmm! :D
would be nice to be able to pre-select the material though. i had to paint the branches green and then back to brown after.
xrok1
Postby SU Reviewer » Wed May 05, 2010 6:24 pm
Great Plugin! I'm in the process of reviewing it for my site. But I keep running into an issue, whenever I select my settings and then click the "Fur" button it creates the fur on the wrong side of the face. Always facing down. Is there a way to fix this?
Thanks for your efforts!
Living Einstein's dream through SketchUp.
"Imagination is a preview of life's coming attractions" - Albert Einstein
Joe Simhon ~ SketchUp Plugin Reviews
SU Reviewer
Postby solo » Wed May 05, 2010 6:26 pm
Make sure your face is orientated correctly.
My site
solo
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby tak2hata » Wed May 05, 2010 6:30 pm
Hi, Jeff and rick.
I update Fur_en.rb
The WebDialog has problem in Mac OSX.
So I put another menu for the correspondence of this problem.
The menu named "fur!(MAC)".
Using InputBox Dialog.
How in this?
by TAK2HATA
tak2hata
SketchUp version: 8
License type: Pro
Postby thomthom » Wed May 05, 2010 6:39 pm
SU Reviewer wrote:Great Plugin! I'm in the process of reviewing it for my site.
Very nice site. I've not seen it before. New?
Global Moderator
SketchUp version: 8
License type: Pro
Postby dale » Wed May 05, 2010 6:53 pm
Yes, Wow thanks for this. I got a feeling some real interesting things will happen with this plugin.
Just monkeying around....
dale
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby xrok1 » Wed May 05, 2010 7:03 pm
how can we access the component instance option? also did you consider the color preselect or a don't copy material option?
also if it would remember settings from 1 usage to the next would be great. a drop down with saved presets would be even better. :oops:
xrok1
Postby rickgraham » Wed May 05, 2010 7:07 pm
tak2hata wrote:Hi, Jeff and rick.
I update Fur_en.rb
How in this?
Works great now, many thanks!
If I can make one little suggestion - I'm not sure if the PC guys are the same or not, but when the dialog box comes up, it is right in the middle of the screen and I have to move it each time. Is there a way to have come in some place other than center? And I would love to see documentation of what the various controls do.
Again, thanks for the great plugin.
Rick
rickgraham
Postby xrok1 » Wed May 05, 2010 7:20 pm
i knew i should have popped that before it got out of hand! :shock:
who would have ever imagined fur for SU????????????????????????????? :sketchstatic:
xrok1
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Next
Return to Plugins
Users browsing this forum: Dave R, guanjin, thach and 14 guests
