[Plugin] Reports coordinates of a cpoint
Postby mmyoung » Fri Apr 09, 2010 1:13 am
Does anyone know of a Ruby that would report the coordinates of a construction point when it is selected? Would be very helpful in DTM work. Thanks
Michael Young
Albuquerque
OSX; SketchUp, Vectorworks, and Wings3D
(which play nicely together)
mmyoung
Premium Member
Premium Member
Re: [Plugin] Reports coordinates of a cpoint
Postby TIG » Fri Apr 09, 2010 12:55 pm
Here...
Copyright 2010 (c), TIG
All Rights Reserved.
THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
cpointtext.rb
This tool adds a piece of text with a leader to any selected Cpoints
[guide-points].
It is shown thus [0, 123, 4567].
The numerical values reflect the 'precision' of the model's units
settings - in the example above it's 0 - typical for 'mm' model.
If it were a 'meter' model then the precision might be 3, giving
[0.000, 0.123, 4.567].
To use it Select some Cpoints [other things selected will be ignored].
Type cpointtext in the Ruby Console to run it...
It's other use is to draw a Cpoint at a given 3d-point, to do this type
in the Ruby Console 'xyz' values or an actual point thus:
cpointtex 1,2,3.4 or cpointtex(1,2,3.4)
or
cpointtext [1,2,3.4] or cpointtex([1,2,3.4])
or
cpointtext point3d or cpointtext(point3d)
or
cpointtext vertex3d or cpointtext(vertex3d)
Note the space between the cpointtext and the first argument OR the
parentheses enclosing all arguments without a gap before the (
cpointtext(x,y,z) - this is the safer option.
You call this method from within other commands.
Units are in current units - i.e. inches, feet, mm, cm or m.
It draw a cpoint at that point's location with associated text...
Donations:
Are welcome [by PayPal], please use 'TIGdonations.htm' in the
../Plugins/TIGtools/ folder or PM @TIG...
Version:
1.0 20100409 First release.
1.1 20100411 If 3 arguments/array [x,y,z] draws cpoint+text, gsub! fixed.
1.2 20100412 Argument can also be a 'Point3d' or 'Vertex3d'. Now undoes.
cpointtext.rb
Global Moderator
Postby mmyoung » Sat Apr 10, 2010 12:57 am
TIG:
Brilliant. Thank you so much. This is saving my cookies.
And I love my cookies!
Michael Young
Albuquerque
mmyoung
Premium Member
Premium Member
Postby TIG » Mon Apr 12, 2010 12:07 am
Version 1.1 now available viewtopic.php?p=238662#p238662
Fixed a glitch with gsub! sometimes not reporting location correctly, and it now has option to take 3 arguments or an array [x,y,z] to add a cpoint and text...
Global Moderator
Postby mmyoung » Mon Apr 12, 2010 6:33 am
Ah! Thank you so much.
If any of you are not using SkUp for DTM work,
now you have no excuse!
Michael Young
Albuquerque
mmyoung
Premium Member
Premium Member
Postby Chris Fullmer » Mon Apr 12, 2010 8:16 am
whats dtm.
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby TIG » Mon Apr 12, 2010 11:55 am
Here's another update v1.2 viewtopic.php?p=238662#p238662
It now lets you pass a Point3d OR a Vertex3d as an argument as well as in raw x,y,z values or an array [x,y,z].
Now has one step undo for plain cpoint texting...
You can call it from other scripts so for example you could read a number of points an array of them, or say vertices from faces...
Global Moderator
Return to Plugins
Users browsing this forum: daica85 and 6 guests
